Data usage report.
The only detailed information available is information provided by the Hughesnet Usage Meter under the Usage History tab.
OR by going to My Account > Usage and then click History
From what I have seen, the Usage History doesn't show your data at the start of the day, but what you have remaining at the end of each day.
Hughesnet can't provide you information on what devices are using data, nor how much data you use on a website on a day by day basis.
If you wish to perform some troubleshooting, please let us know.
Look it's not a Two Faced Blade. People need the tools. Most ISP's to my knowledge collect data anyways all they have to do a is track how much GB or preferable MB are being used from their server for each individual which, in essence, is the usage meter currently but what they don't want to show us is the min to min or hour to hour usage. I can and do track my data using a different software. But how am I supposed to guarantee that my software is working? How will HughesNet verify a discrepancy if my software says 3 GB are missing and their software says otherwise? They won't because there software and usage meter data is what they go off of....... Do you see the problem with that?
In short.
They haven't provided all the tools to monitor my system I can't see how much data I'm using only At the end of the day, I'll get to finally find out if I went over or went under my daily data schedule.. awesome!!!! Not
This Usage meter needs a major update. And if you're fine with not being able to accurately tell how much data is going out at one time then you either have a huge wallet and don't care if you go over your data allotment. or you never use enough to go over your data allotment.
for people who actually need to track their data usage at given hours or when running updates or uploading videos, we need a Usage meter that works from HughesNet so that we don't have to use a third party software to make sure ill have enough data to do my work and when using other software from another company there is bound to be some discrepancies in how things are tracked.. all the more reason for HugesNet to update there Meter.
SO Please provide me my full data usage report. Thanks.
I agree, it is nonsense that we cannot get an hour by hour usage report.
- Gwalk9008 years agoHonorary Alumnus
You both make valid points but the answer is not as simple as it seems.
I was going to respond here but it is such a common issue I decided to start a new post instead.
The topic is here:
My post got so long that time got short so it is a work in progress but there is enough there now to consider.
