Data tokens vs plan upgrade
Can I not upgrade my plan mid month for the $10 more? I have to buy the hugely more expensive tokens? Pretty sure I’m going to use all 10gb this month but not sure. What’s the best thing to do? Don’t want to have to buy the expensive tokens
Upgrading might be better for you, but you will still have to learn to budget your data, or you'll run out of data on any of the plans.
Quinatt wrote:
First month with hughesnet. On the 10gb plan and I see that the upgrade to 10gb more is only $10 more. Then I see to purchase 10gb tokens is $30??
Can I not upgrade my plan mid month for the $10 more? I have to buy the hugely more expensive tokens? Pretty sure I’m going to use all 10gb this month but not sure. What’s the best thing to do? Don’t want to have to buy the expensive tokens - GabeUDistinguished Professor IV
Right now there is actually deal going for extra tokens. You may have gotten an email about it today. When you buy 10GB of tokens you get an extra 5GB for free.
When you upgrade your plan mid month, which you can do, the fee will be prorated for this month, so if it's halfway through it should be somewhere around $5 (if the 20GB plan is only $10 more), which will be added to the next bill since you've likely already paid for this month's.
My advice would be to upgrade your plan, as $10 for 10GB more is still a much better deal, especially if you're going to be needing more data than you presently have every month.
- QuinattFreshmanOk that’s a relief to know. I guess the only reason for buying the 10gb for $30 would be for someone already with a big plan. Good to know.
Would steaming a YouTube video even be possible once the data is used up and it drops to a slower speed? Probably different for each service, depending on your signal strength to begin with?
Thanks for your replies. Satellite internet is a pretty terrifying thing for people who aren’t wealthy- QuinattFreshmanActually, that’s confusing. Why would upgrading to 20gb mid-month from 10gb be prorated to half the price? You’re still getting 10gb more regardless of the fact you only get 15 days less to use it. Maybe I’m not understanding correctly.
