I think I know what to do about Slow Speeds . . .
Calling tech support is helpful only to a certain extent, because the phone reps are Tier 1 and can only do so much. Posting the issue to this community is a much better approach, as the HN reps in this community have a direct line to the network engineers, and if the speed issue is on HN's side, they can often fix it. Unfortunately, speed issues can also be on the subscriber's side of the modem, which can be frustrating as many subscribers have limited technical knowledge and don't understand why they're having problems and why they are being asked to do troubleshooting on their side.
Subscribers should first check the system control center to make sure there are no state codes other than 0.0.0. If the code is 0.0.0, this means the equipment is working and this points to a problem with devices, hardware, software, usage, number of users, time of day, and many other variables. If there are codes other than 0.0.0, those indicate issues.
To have speed issues addressed in this community, subscribers will first need to follow the procedure detailed here: https://community.hughesnet.com/t5/Tech-Support/Think-you-have-slow-speeds/m-p/110034#M74607
- ageofpiece5 years agoFreshmanThanks for getting back to me. I’m skeptical the issue of slow internet can be expediently addressed via this forum. Perhaps the change I saw in my speeds after the call was coincidence? Also the added url where we have to compile our speeds over a period of time to me is not acceptable, pardon me for saying so. This seems a way to pass off addressing the issue. What we pay for is 25mbps. That’s what we should get.
ageofpiece wrote:
I’m skeptical the issue of slow internet can be expediently addressed via this forum. Perhaps the change I saw in my speeds after the call was coincidence?Nobody said it was coincidence. Nor did anyone say that people can't get help via a phone rep. Plenty of people do. It's just that the help here tends to be better, especially when an issue is more involved. Tier 1 reps who are reading from a screen vs corporate reps who have been with the company for years and have direct access to the engineers. Your issue was likely a simple, quick fix. I'll forgive your naivety when it comes to this support community.
ageofpiece wrote:
Also the added url where we have to compile our speeds over a period of time to me is not acceptable, pardon me for saying so. This seems a way to pass off addressing the issue.The testing protocol is a way to first, establish the issue, and second, give the reps and engineers pertinent info. It's a troubleshooting tool, not a way to "pass off addressing the issue". SMH.
"If you're working with us in the community or social media, only testmy.net results are accepted to be considered for escalation to corporate engineering." - Did you happen to miss that part?
ageofpiece wrote:
What we pay for is 25mbps. That’s what we should get.Yes, you do, but that doesn't mean speed won't fluctuate, and 25Mbps is not guaranteed.
- ageofpiece5 years agoFreshmanI’ll try and reach out to support within the forums in the future. If tech support is as quick to get back to me as you’ve been to respond it seems like a good option, although could do with less attitude. Didn’t encounter than over phone tech support. Secondly, Gabe; having customers “run a set of 3-5 tests per day during different parts of the day” hardly seems like addressing why speeds are like maybe 500kbps in the moment. I called because I wanted speed now. That protocol is to do what, establish the obvious that speeds are slower during high traffic times? I don’t even need the 25mbps I could deal with 5 even. And I’ll forgive you for getting seemingly upset over this.
It may indeed have been a coincidence. As for the testing, they need to know what's happening on your side of the modem. Since they don't live with you, they expect you to do some troubleshooting. So would other ISPs; it's a common practice because the techs don't live with the subscribers and can only see their side of the equation.
