Speed tests
"I'm reasonably sure of who it is you're referring to, and when the person can get some tests in using the protocol, which is designed and required for specific reasons, some of which have already been mentioned in this thread, the person will receive help. The tests already run are either too far apart, too close together, and/or there are too few during a testing "session"."
Well, in her latest post she said after some hardware problems were fixed, she had two days of normal service, but it didn't last. I personally think this was probably caused by the "infant mortality" of one of the components that was replaced. Does she need to run a new set of speed tests to find out? :>)>
My mistake. I thought you were referring to another member. One who had Gen4, then upgraded to Gen5, and had more than a year's worth of speed tests.
I was under the impression that the person you are now referring to was a new customer, not only from memory, but due to the 20 days of data resets mentioned, which only new customers, or those upgrading to Gen5 from legacy systems, get.
- gaines_wright7 years agoTutorHello
"My mistake. I thought you were referring to another member who had Gen4, then upgraded to Gen5, and had more than a year's worth of speed tests."
I'm getting confused now, :>)> I had to go back and read my original posts That was was the member in my original post.
LOL! This whole thread is turning into "A Comedy of Errors". Understandable, since both members had handles started with the letter 'v'. I just hope they're not identical twins.
"I was under the impression that the person you are now referring to was a new customer, not only from memory, but due to the 20 days of data resets mentioned, which only new customers, or those upgrading to Gen5 from legacy systems, get."
That's correct. Well, at least I think it is. :>)>
I guess gen4 doesn't qualify as a legacy system. When I upgraded from gen4 to gen5 I certainly didn't get it. I hate it, when a company treats new customers better than old ones. It seems to happen quite often though. A friend of mine who upgraded to gen5 didn't get a break on data either. If his wife finds out about this, she'll be on the phone raising cain until she gets something.
I'm certainly not going to be the one to tell her. :>)>
Just a misunderstanding. And somehow I don't think they're identical twins :p
I found out about the Legacy to Gen4/5 vs Gen4 to Gen5 thing the hard way. When I upgraded to Gen4 from my old legacy plan I couldn't figure out why my data wasn't being depleted, and after asking about it I was told about the 20 days of resets by Corrosive, who I then probably aggravated with my subsequent questions about such. It took a second for me to understand what he meant. No, I didn't bother to read the Welcome email from HughesNet that explains the resets. Does anyone really read that? It was still sitting in my HughesNet email, which, though I set up, I had never used, and didn't even sign back into until months after I had upgraded to Gen4. It was the second of two emails, the first being a HughesNet Welcome email from Dec 2004, when I first got HughesNet and first set up the HughesNet email. So, two emails. One sitting there for nearly ten years, unread, and the other for a few months, also unread.
Then, when I then upgraded from Gen4 to Gen5, I expected the same 20 days of resets, only to be disappointed in finding out that, because of the similarity in the systems, you don't get them. At that point it didn't really matter, though, as everything of mine was already up to date, and I think that's why they don't do it for Gen4 to Gen5 upgrades. Being new, or coming from a legacy plan, might mean that you have some devices that aren't up to date, due to having no internet, or a very restricted amount with the daily refill plan, whereas coming from Gen4 you most likely already have everything current. Still, it would have been nice to stream a bunch of shows for a few weeks.
- pgustaf2497 years agoNew Poster
On 3/13/19 I ran a speed test using speedof.me and had a download speed of 6.7 Mbps. I immediately turned around and did a Hughesnet seed test and the result was 41 Mbps. Upload speeds were similar. Just FYI.
Speedofme and similar apps are not reliable for satellite internet. Please use testmy.net for your speed tests, especially if you need support with speed issues, as testmy.net is required in order to escalate speed issues to corporate engineers.
