- bos24207 years agoJunior
bos2420 wrote:Put that on a USB stick, and plugged that into the back of the smart TV. Worked like a charm.
Does your TV have a special program built in that reads and plays what you have on the flash drive? I have a smart TV, and it has a USB port, as well. I wonder if that would work for me. It would eliminate me having to play the items on my HDMI connected laptop.
I should try to find a .mp4 clip or something somewhere, put it on one of my flash drives, and just give it a try. Now, to find something. :p
