I have the same problem with AOL and also Yahoo. Also a couple other sites. I finally troubleshooted and found it was Hughesnet that was the issue. I could get the sites at work, at ISP's other than Hughesnet, and my Android. Very frustrating. Haven't found a solution.
You're piggybacking on an old thread that the mods ought to lock, since it's old and solved. If you have an issue you'd like to report or troubleshoot, you need to start a new topic. Go to Tech Support and click on "start a topic."
Issues logging on to specific sites are known and engineers are working on it. See this response.
