Yes, very frustrating, especially when my ability to work remotely depends on it. I am required to work on that Dell laptop (something else I was trying to explain that didn't seem to get across). The laptop has VPN installed that I HAVE to use to access the platforms I work in. Internet requirements are at least 25 Mbps download and 5 upload, and I cannot work in a library, cafe, etc., on a shared network.
The ethernet issue is related to a general issue, which is that upload speeds are still pretty dang slow. I also tried to explain--or stress, actually in various terms--to the rep who helped me upgrade that I needed a minimum speed of 5 Mbps upload. She said that it did. I kept saying "it needs to be a minimum, at least, no less than." Yes, yes, yes, ok...
I don't understand because the download speed is significantly faster, but I'm below 5, sometimes above (about 6.5 the fastest so far) on upload. Meanwhile average upload speeds in my city are about 20 Mbps. Yesterday, I did a download test and got 2.1 (wth?!?) Just now it's 91.6 download but only 3.7 upload.
The ethernet seems to have a negligible effect, disappointingly. I thought the solution was that I needed to upgrade the cable from 5e to 6 or higher, so a rushed to buy one.
I_Andrade,
Thanks for reaching out! Having slower speeds via an ethernet connection is odd, and understandably frustrating. Previous call notes do not mention an ethernet-connected speed issue. Did the agent attempt to address this, and did you discuss it with them?
In regards to the upload speeds, Hughesnet plans offer upload speeds of up to 5mbps, We unfortunately cannot guarantee a constant speed of 5mbps upload. Do you remember when you spoke with an agent that stated this?
Remy
- I_Andrade3 months agoSophomore
Hi, thanks for responding. The initial contact where I upgraded the service was 9/11 or 9/12. I recall emphasizing that point about minimum upload speed repeatedly because it didn't seem like the agent was understanding me and, as I mentioned, it is important. I upgraded the service solely for this remote work contract.
On the second contact when I called about the ethernet, the first thing I mentioned was an ethernet connectivity issue (i.e., slow connection, upgraded to Cat 6 to no effect), so if it wasn't in the call notes, then somehow that point didn't get across. The agent immediately began walking me through steps to check the basic connection, which is how I ended up renaming the networks. After hanging up in frustration with that person, I tried to check settings that might somehow be affecting the ethernet connection and didn't see anything.
I am careful to disconnect all other devices from the network while I'm using the Dell laptop for work. The last speed test on that laptop (ethernet connected) I did before starting work yesterday, the upload was 5.6 Mbps. The Cat 6 cable works, but it doesn't help with speed much, not sure about overall stability of the connection vs. WIFI. If that speed could just be stable at or above 5, all would be okay.
So far, I've been able to complete all tasks but with some hiccups and delays. Once I got disconnected from the VPN and had to close everything and start over. Fortunately, recoveries haven't caused too much delay that would be noticed. The uncertainty is stressful though.
- GabeU3 months agoDistinguished Professor IV
Just something to keep in mind is that using a VPN with HughesNet can cause noticeable slow downs with the service. I don't know this for a fact, but I believe it's because of the latency being around 600ms or so. I just mean in addition to the typical slowdown that VPN use causes in general.
Regarding the upload, unfortunately being above 5Mbps is something they can't guarantee. System load affects it, so it might be around 5Mbps one minute, then drop some the next, then be back up again the next. The speed will vary throughout the day, but will probably be the lowest during prime time in the evenings, when the highest number of subscribers are trying to stream.
As for the ethernet issue, I've been following this thread since you started it, and that one's a head scratcher, that's for sure. One thing I'd try is to see if there is an updated driver for your network adapter, though with network adapters being so common and integrated and Windows itself usually providing the driver for them that's unlikely. Still, it might be worth a check.
I don't personally have HughesNet anymore, so I'm not familiar with the newer modems, but they still have multiple lan ports on them it might be worth trying the others. And your Cat6 cable should be fine. Cat 6 is pretty much the standard these days.
- Remy3 months agoModerator
I_Andrade,
I sent you a private message in response to your reply so we can help figure out a solution for this. Please let me know if you've received it!
Remy
Hi Remy, I responded to your email.
