Footer links issue
Amanda , the first time I noticed the issue and posted the OP, I had both right clicked and left clicked, and both actions were redirecting me to the page I had clicked from. Later, when GabeU posted, the issue had almost solved itself. I could left click but not right click.
The issue persists for right clicking on all the browsers I've tried. It works for left clicking, though.
Solving this may be more trouble than it's worth, and so I'm fine if it doesn't get solved or if the community team doesn't want to deal with it. 😊 It's just a curious issue because it didn't use to happen.
I've also bookmarked the links (and I know the link for the legal node by heart....LOL).
My plan was to refer subscribers to the footer as a shortcut to the the linked pages, but I can just post the relevant link.
Thank you very much for all the help, especially for helping on what's no doubt a very minor issue. 🤪
Hiya,
So we think it is linked to just a couple of lines of code, you are correct. There are some backend components that are not critical, but it can likely be fixed, we just need to do a little tweaking or re-arranging. Thanks again!
- 11 months ago
