Something interesting I noticed. With my Dell laptop, which can only utilize the 2.4Ghz band, the speeds were the same as my desktop. Since the software upgrade to the modem, the speeds on my lapto...
russyoung2676
8 years agoSophomore
I was going to start a new topic but this is along the same lines as my issue. With my desktop hard wired high 40s and with my wifi devices on 5ghz high 40s. I switch wifi to 2.4 my speed gets cut in almost half mid to high 20s. I would just stay on 5.0 but if I literally go more then 15ft away into my living room I loose signal strength unlike the good range I have on 2.4. So I thought I had a fix, I hooked up an external router to my hugesnet modem and it still stayed at mid to high 20s. What am I missing?
