Modem issues after power surge
Hi Gigix2,
Thanks for posting and welcome to the community! Thanks for confirming that your modem was still plugged in. I tried to run diagnostics on your site, but I'm not able to make a connection; looks like that surge got your modem. I'm sending you our latest modem model, no need to return your HT1100. Here's our guide to replacing and getting started with your new modem. Please expect the modem to arrive in a few days.
When did this start happening? Since around 8PM EST or so last night, Gen5, on the Echostar 19 satellite, has been having intermittent issues. It's known, and they are working on it.
The notice about the issue is on the right side of the HughesNet Community.
- Gigix2FreshmanIt happened about an hour ago and I do not have Gen 5
Gigix2 wrote:
It happened about an hour ago and I do not have Gen 5Ah. Okay.
It may very well be that something bad happened to the modem or radio when you had the power surge. Are you showing any state codes on the following page?
http://192.168.0.1/limited.html#!/state_code/state_code_monitor
If so, what codes are showing?
- Gigix2FreshmanI can not open that link on my cell. Is it supposed to be open through Hughes net connection?
- LizModerator
Hi Gigix2,
- Gigix2FreshmanThank you so much, I appreciate it.
