modem overheatind power light red
aria,
Thanks for reaching out! I see it's your first post. Welcome to the Community! I was able to find the account connected to your Community profile, making it simple to check into the account. I'm going to be sending you a replacement modem, to hopefully fix the overheating issue. Please be sure there is nothing surrounding the modem, and that it's in a well-ventilated area. In the meantime, if the modem begins to overheat again, please unplug it from the outlet. Please expect the replacement soon; you can use its box to return the old modem. For your convenience, the return label is included in the outer pouch.
Remy
The reps here can check your modem remotely to see what's going on. Hang in there until they check and they will give you next steps, which may include sending you a replacement modem.
