Good morning everyone,
Thank you,
After a couple of trouble free days shopping on Amazon, the problem returned. I followed the same procedure as before and it appears to have resolved the issue, for the time being. I did a trace to Amazon while connected thru the router, both before and after the fix.
Before:
And After:
Unfortunately, I forgot to do a trace without the router prior to the fix, but I did take a trace without the router after.
Personally, I have no idea what the rest of you might see in these tea leaves. If the problem persists, I'll continue to remove steps from the solution to narrow it down.
Same here, after a few days of trouble-free Amazon shopping, I'm unable to utilize the service, once more. It's frustrating having to reboot the modem over and over. Also, I noticed other web sites having similar problems until I reboot the modem, then they all appear normal again. I gather it's a technical glitch on the HughesNet end?
