Yeah, everything is updated enough I believe, and since its a widespread issue I don't think the older computer's oldness is as much an issue...
I just had it trying to do a 25MB test, and it ended up freezing up somewhere in the middle and not finishing at all. Ive checked all avenues for something hogging the data, but I don't think theres anything, and even if there was, this is...beyond the pale unless theyve implemented an Ultra-Throttle
Hope to hear something from tech soon!
Yeah, things do look super slow, even for FAP. You may want to stop running tests unless a rep directs you to do so. I don't think these tests you're running under FAP would be useful, plus you're going to end up screaming uncontrollably and pulling your hair out. :)
- 11 months ago
- 11 months ago
