slow speed
new modem,Problem solved,Moden done the trick.Happy camper now
Just in case, check to make sure you aren't out of data. If you have data, try power cycling your HughesNet modem, which can sometimes help. To do so, unplug the modem, wait for at least a minute, then plug it back in. Then wait for at least five minutes, which gives the modem time to be fully back up and ready, and try your activity again.
No need to post links to individual tests -- use your My Results URL: https://testmy.net/quickstats/john%20black
And remember to use the right test sizes.
If you're testing for troubleshooting purposes, please follow these instructions. Only results from tests run as instructed will be accepted by the HughesNet reps in this support community.
- john126 years agoJunior
will not run a 12 mb test,after about 3mb it stops and this comes up (Secure Connection Failed) Tried three times.
Go to this page: http://192.168.0.1/#!/home/status
What's the number next to State Code?
