Slow Speed
Good Morning Liz,
Maybe it's a dish misalignment...the HN reps on this site can run remote diagnostics to see how everything is working. Not sure what to tell you about the password...I hope someone else here will have some ideas.
Dish alignment was one of the possible problems or it could be the modem. This has been operational since Jan 2018. I was a network admin for many years, things break...
Things sure do break. The admins will be able to run remote diagnostics and you can go from there. I hope you hear soon.
