Slow Speed
Good Morning Liz,
Dish alignment was one of the possible problems or it could be the modem. This has been operational since Jan 2018. I was a network admin for many years, things break...
Things sure do break. The admins will be able to run remote diagnostics and you can go from there. I hope you hear soon.
