Slow Speed
Good Morning Liz,
Good morning RiverDog,
Thanks for reaching out. I tried running diagnostics on your site but can't communicate with the modem. Do you occasionally leave the modem disconnected?
- Liz5 years agoModerator
Thanks for the clarification RiverDog. I ran the diagnostic right before posting a little over half an hour ago. Tried running it again now and still can't reach the modem. I can dispatch a complimentary tech at the earliest available slot to review your site and address any issues. Do you have a preference for morning or afternoon visits?
Ah, hold on, the diagnostics did finally complete. Looks like you're currently under the Fair Access Policy and have been so since June 29. Does that line up with when you noticed the slower speeds?
- RiverDog5 years agoSophomoreNo I've been having problems since before March, You can look at the speed tests on your website. If I can add an attachment I'll enclose a PDF. Due to health problems any tech visits would be better in the afternoon.
Thanks.
I'm seeing something connected to the modem called "Archer_C7" with bad device health with high packet loss according to the diagnostics. Is that the computer you're using? Do you have another device to test with the modem or on the network to see if speeds are consistently slower than normal on other devices?
For your convenience I've sent you a complimentary token to apply to troubleshoot while outside of the Fair Access Policy.
