Last night DL was consistently under 1 mbps, up was 2.5 to 4 This morning, DL has ranged from sub 1 to 10. I have been on 4 chats and they just stop replying or disconnect. One rebooted modem a fe...
What she is probably waiting for is for you to run the required tests the required way. Right now, the file sizes are incorrect; they need to be 25MB for download tests and 4MB for upload tests.
Don't expect a reply until you have run the tests the right way, as explained here. You may want to focus your efforts on getting the troubleshooting and testing right.
For immediate responses, there's chat and phone customer service, but you've been through that and it hasn't worked for you, so stay here, run the tests the way they're supposed to, and wait for a response, which may be next week if you've done the required testing as required.
bronccat wrote:
I DM Liz as I am not sure how to get her attention?
Right, as stated above I started running the ethernet test and will do se every 2 or 3 hours. 25 mb down (first was at 1130) and 4 Up.
My question is - and not to be a smart**bleep** - but how will she magically know that I have run the tests "correctly" and know I am now worthy of a response?
MrBuster I'm not using auto - I was running smaller tests before I was hooked to ehternet. Since 1143 (or whenever) I have been running 25 DL and 4 UL.
She will know because she will check the URL to your results list. And because she's an all powerful, all seeing entity. Or a magical pixie. HN neither confirms nor denies.
You can use that '@' sign like you did for me to notify folks -- also, she will probably check this thread this thread again on Monday.
I think maratsade just responding about the smaller tests that were recent, so I was not sure if maybe testmy was backing your size down. I think she will have what she wants with a good batch of these tests.
edit: I see maratsade responded before I was done typing....
the OP needs to get the sizes right or the testing may be rejected by the engineers; Liz is just a conduit. Hopefully the OP will get all the moving pieces right. :)
If I'm on the mountain, this is all I have. I'll be back there first of next week. I had hoped all of this would get resolved on here before I left but with the ethernet connection issue my timing sucked lol
A little LOL... I almost ran a test here (just bc I'm new to "test.my" and realized it would look crazy. I know the location would show but didn't want to muddy the waters ;-)
"}},"componentScriptGroups({\"componentId\":\"custom.widget.GoogleTagTracker\"})":{"__typename":"ComponentScriptGroups","scriptGroups":{"__typename":"ComponentScriptGroupsDefinition","afterInteractive":{"__typename":"PageScriptGroupDefinition","group":"AFTER_INTERACTIVE","scriptIds":[]},"lazyOnLoad":{"__typename":"PageScriptGroupDefinition","group":"LAZY_ON_LOAD","scriptIds":[]}},"componentScripts":[]},"component({\"componentId\":\"custom.widget.MixPanelTracker\"})":{"__typename":"Component","render({\"context\":{\"component\":{\"entities\":[],\"props\":{}},\"page\":{\"entities\":[\"message:128262\"],\"name\":\"ForumReplyPage\",\"props\":{},\"url\":\"https://community.hughesnet.com/discussions/TechSupport/speed-issues-cant-stay-on-chat-for-help/128262/replies/128615\"}}})":{"__typename":"ComponentRenderResult","html":" "}},"componentScriptGroups({\"componentId\":\"custom.widget.MixPanelTracker\"})":{"__typename":"ComponentScriptGroups","scriptGroups":{"__typename":"ComponentScriptGroupsDefinition","afterInteractive":{"__typename":"PageScriptGroupDefinition","group":"AFTER_INTERACTIVE","scriptIds":[]},"lazyOnLoad":{"__typename":"PageScriptGroupDefinition","group":"LAZY_ON_LOAD","scriptIds":[]}},"componentScripts":[]},"component({\"componentId\":\"custom.widget.custom_Footer\"})":{"__typename":"Component","render({\"context\":{\"component\":{\"entities\":[],\"props\":{}},\"page\":{\"entities\":[\"message:128262\"],\"name\":\"ForumReplyPage\",\"props\":{},\"url\":\"https://community.hughesnet.com/discussions/TechSupport/speed-issues-cant-stay-on-chat-for-help/128262/replies/128615\"}}})":{"__typename":"ComponentRenderResult","html":""}},"componentScriptGroups({\"componentId\":\"custom.widget.custom_Footer\"})":{"__typename":"ComponentScriptGroups","scriptGroups":{"__typename":"ComponentScriptGroupsDefinition","afterInteractive":{"__typename":"PageScriptGroupDefinition","group":"AFTER_INTERACTIVE","scriptIds":[]},"lazyOnLoad":{"__typename":"PageScriptGroupDefinition","group":"LAZY_ON_LOAD","scriptIds":[]}},"componentScripts":[]},"messages({\"constraints\":{\"solution\":{\"eq\":true},\"topicId\":{\"eq\":\"message:128262\"}},\"first\":10,\"sorts\":{\"postTime\":{\"direction\":\"ASC\"}}})":{"__typename":"MessageConnection","edges":[{"__typename":"MessageEdge","cursor":"MjUuM3wyLjF8aXwxMHwzOToxfGludCwxMjg5MTUsMTI4OTE1","node":{"__ref":"AcceptedSolutionMessage:message:128915"}}],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null},"totalCount":1},"cachedText({\"lastModified\":\"1739990369000\",\"locale\":\"en-US\",\"namespaces\":[\"shared/client/components/users/UserAvatar\"]})":[{"__ref":"CachedAsset:text:en_US-shared/client/components/users/UserAvatar-1739990369000"}],"cachedText({\"lastModified\":\"1739990369000\",\"locale\":\"en-US\",\"namespaces\":[\"shared/client/components/ranks/UserRankLabel\"]})":[{"__ref":"CachedAsset:text:en_US-shared/client/components/ranks/UserRankLabel-1739990369000"}],"cachedText({\"lastModified\":\"1739990369000\",\"locale\":\"en-US\",\"namespaces\":[\"components/tags/TagView/TagViewChip\"]})":[{"__ref":"CachedAsset:text:en_US-components/tags/TagView/TagViewChip-1739990369000"}],"cachedText({\"lastModified\":\"1739990369000\",\"locale\":\"en-US\",\"namespaces\":[\"components/messages/AcceptedSolutionButton\"]})":[{"__ref":"CachedAsset:text:en_US-components/messages/AcceptedSolutionButton-1739990369000"}],"cachedText({\"lastModified\":\"1739990369000\",\"locale\":\"en-US\",\"namespaces\":[\"components/messages/LinearReplyList\"]})":[{"__ref":"CachedAsset:text:en_US-components/messages/LinearReplyList-1739990369000"}],"cachedText({\"lastModified\":\"1739990369000\",\"locale\":\"en-US\",\"namespaces\":[\"components/messages/MessageView/MessageViewInline\"]})":[{"__ref":"CachedAsset:text:en_US-components/messages/MessageView/MessageViewInline-1739990369000"}],"cachedText({\"lastModified\":\"1739990369000\",\"locale\":\"en-US\",\"namespaces\":[\"shared/client/components/common/Pager/PagerLoadMore\"]})":[{"__ref":"CachedAsset:text:en_US-shared/client/components/common/Pager/PagerLoadMore-1739990369000"}],"cachedText({\"lastModified\":\"1739990369000\",\"locale\":\"en-US\",\"namespaces\":[\"components/customComponent/CustomComponent\"]})":[{"__ref":"CachedAsset:text:en_US-components/customComponent/CustomComponent-1739990369000"}],"message({\"id\":\"message:128915\"})":{"__ref":"AcceptedSolutionMessage:message:128915"},"message({\"id\":\"message:128611\"})":{"__ref":"ForumReplyMessage:message:128611"},"cachedText({\"lastModified\":\"1739990369000\",\"locale\":\"en-US\",\"namespaces\":[\"shared/client/components/nodes/NodeIcon\"]})":[{"__ref":"CachedAsset:text:en_US-shared/client/components/nodes/NodeIcon-1739990369000"}],"message({\"id\":\"message:128616\"})":{"__ref":"ForumReplyMessage:message:128616"},"message({\"id\":\"message:128617\"})":{"__ref":"ForumReplyMessage:message:128617"},"message({\"id\":\"message:128619\"})":{"__ref":"ForumReplyMessage:message:128619"},"message({\"id\":\"message:128621\"})":{"__ref":"ForumReplyMessage:message:128621"},"message({\"id\":\"message:128624\"})":{"__ref":"ForumReplyMessage:message:128624"},"message({\"id\":\"message:128685\"})":{"__ref":"ForumReplyMessage:message:128685"},"message({\"id\":\"message:128686\"})":{"__ref":"ForumReplyMessage:message:128686"},"message({\"id\":\"message:128687\"})":{"__ref":"ForumReplyMessage:message:128687"},"message({\"id\":\"message:128727\"})":{"__ref":"ForumReplyMessage:message:128727"},"message({\"id\":\"message:128731\"})":{"__ref":"ForumReplyMessage:message:128731"},"message({\"id\":\"message:128733\"})":{"__ref":"ForumReplyMessage:message:128733"},"message({\"id\":\"message:128734\"})":{"__ref":"ForumReplyMessage:message:128734"},"message({\"id\":\"message:128736\"})":{"__ref":"ForumReplyMessage:message:128736"},"message({\"id\":\"message:128737\"})":{"__ref":"ForumReplyMessage:message:128737"},"message({\"id\":\"message:128738\"})":{"__ref":"ForumReplyMessage:message:128738"},"message({\"id\":\"message:128653\"})":{"__ref":"ForumReplyMessage:message:128653"},"message({\"id\":\"message:128655\"})":{"__ref":"ForumReplyMessage:message:128655"},"message({\"id\":\"message:128656\"})":{"__ref":"ForumReplyMessage:message:128656"},"message({\"id\":\"message:128673\"})":{"__ref":"ForumReplyMessage:message:128673"},"message({\"id\":\"message:128683\"})":{"__ref":"ForumReplyMessage:message:128683"},"message({\"id\":\"message:128625\"})":{"__ref":"ForumReplyMessage:message:128625"},"message({\"id\":\"message:128647\"})":{"__ref":"ForumReplyMessage:message:128647"},"message({\"id\":\"message:128649\"})":{"__ref":"ForumReplyMessage:message:128649"},"message({\"id\":\"message:128651\"})":{"__ref":"ForumReplyMessage:message:128651"},"message({\"id\":\"message:128652\"})":{"__ref":"ForumReplyMessage:message:128652"}},"Theme:customTheme1":{"__typename":"Theme","id":"customTheme1"},"User:user:-1":{"__typename":"User","id":"user:-1","uid":-1,"login":"Anonymous","email":"","avatar":null,"rank":null,"kudosWeight":1,"registrationData":{"__typename":"RegistrationData","status":"ANONYMOUS","registrationTime":null,"confirmEmailStatus":false,"registrationAccessLevel":"VIEW","ssoRegistrationFields":[]},"ssoId":null,"profileSettings":{"__typename":"ProfileSettings","dateDisplayStyle":{"__typename":"InheritableStringSettingWithPossibleValues","key":"layout.friendly_dates_enabled","value":"true","localValue":"true","possibleValues":["true","false"]},"dateDisplayFormat":{"__typename":"InheritableStringSetting","key":"layout.format_pattern_date","value":"MM-dd-yyyy","localValue":"MM-dd-yyyy"},"language":{"__typename":"InheritableStringSettingWithPossibleValues","key":"profile.language","value":"en-US","localValue":null,"possibleValues":["en-US","es-ES"]},"repliesSortOrder":{"__typename":"InheritableStringSettingWithPossibleValues","key":"config.user_replies_sort_order","value":"DEFAULT","localValue":"DEFAULT","possibleValues":["DEFAULT","LIKES","PUBLISH_TIME","REVERSE_PUBLISH_TIME"]}},"deleted":false},"CachedAsset:pages-1744705855429":{"__typename":"CachedAsset","id":"pages-1744705855429","value":[{"lastUpdatedTime":1744705855429,"localOverride":null,"page":{"id":"BlogViewAllPostsPage","type":"BLOG","urlPath":"/category/:categoryId/blog/:boardId/all-posts/(/:after|/:before)?","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1744705855429,"localOverride":null,"page":{"id":"CasePortalPage","type":"CASE_PORTAL","urlPath":"/caseportal","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1744705855429,"localOverride":null,"page":{"id":"CreateGroupHubPage","type":"GROUP_HUB","urlPath":"/groups/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1744705855429,"localOverride":null,"page":{"id":"CaseViewPage","type":"CASE_DETAILS","urlPath":"/case/:caseId/:caseNumber","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1744705855429,"localOverride":null,"page":{"id":"InboxPage","type":"COMMUNITY","urlPath":"/inbox","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1744705855429,"localOverride":null,"page":{"id":"HelpFAQPage","type":"COMMUNITY","urlPath":"/help","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1744705855429,"localOverride":null,"page":{"id":"IdeaMessagePage","type":"IDEA_POST","urlPath":"/idea/:boardId/:messageSubject/:messageId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1744705855429,"localOverride":null,"page":{"id":"IdeaViewAllIdeasPage","type":"IDEA","urlPath":"/category/:categoryId/ideas/:boardId/all-ideas/(/:after|/:before)?","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1744705855429,"localOverride":null,"page":{"id":"LoginPage","type":"USER","urlPath":"/signin","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1744705855429,"localOverride":null,"page":{"id":"BlogPostPage","type":"BLOG","urlPath":"/category/:categoryId/blogs/:boardId/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1744705855429,"localOverride":null,"page":{"id":"ThemeEditorPage","type":"COMMUNITY","urlPath":"/designer/themes","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1744705855429,"localOverride":null,"page":{"id":"TkbViewAllArticlesPage","type":"TKB","urlPath":"/category/:categoryId/kb/:boardId/all-articles/(/:after|/:before)?","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1744705855429,"localOverride":null,"page":{"id":"OccasionEditPage","type":"EVENT","urlPath":"/event/:boardId/:messageSubject/:messageId/edit","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1744705855429,"localOverride":null,"page":{"id":"OAuthAuthorizationAllowPage","type":"USER","urlPath":"/auth/authorize/allow","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1744705855429,"localOverride":null,"page":{"id":"PageEditorPage","type":"COMMUNITY","urlPath":"/designer/pages","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1744705855429,"localOverride":null,"page":{"id":"PostPage","type":"COMMUNITY","urlPath":"/category/:categoryId/:boardId/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1744705855429,"localOverride":null,"page":{"id":"ForumBoardPage","type":"FORUM","urlPath":"/category/:categoryId/discussions/:boardId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1744705855429,"localOverride":null,"page":{"id":"TkbBoardPage","type":"TKB","urlPath":"/category/:categoryId/kb/:boardId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1744705855429,"localOverride":null,"page":{"id":"EventPostPage","type":"EVENT","urlPath":"/category/:categoryId/events/:boardId/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1744705855429,"localOverride":null,"page":{"id":"UserBadgesPage","type":"COMMUNITY","urlPath":"/users/:login/:userId/badges","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1744705855429,"localOverride":null,"page":{"id":"GroupHubMembershipAction","type":"GROUP_HUB","urlPath":"/membership/join/:nodeId/:membershipType","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1744705855429,"localOverride":null,"page":{"id":"MaintenancePage","type":"COMMUNITY","urlPath":"/maintenance","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1744705855429,"localOverride":null,"page":{"id":"IdeaReplyPage","type":"IDEA_REPLY","urlPath":"/idea/:boardId/:messageSubject/:messageId/comments/:replyId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1744705855429,"localOverride":null,"page":{"id":"UserSettingsPage","type":"USER","urlPath":"/mysettings/:userSettingsTab","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1744705855429,"localOverride":null,"page":{"id":"GroupHubsPage","type":"GROUP_HUB","urlPath":"/groups","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1744705855429,"localOverride":null,"page":{"id":"ForumPostPage","type":"FORUM","urlPath":"/category/:categoryId/discussions/:boardId/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1744705855429,"localOverride":null,"page":{"id":"OccasionRsvpActionPage","type":"OCCASION","urlPath":"/event/:boardId/:messageSubject/:messageId/rsvp/:responseType","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1744705855429,"localOverride":null,"page":{"id":"VerifyUserEmailPage","type":"USER","urlPath":"/verifyemail/:userId/:verifyEmailToken","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1744705855429,"localOverride":null,"page":{"id":"AllOccasionsPage","type":"OCCASION","urlPath":"/category/:categoryId/events/:boardId/all-events/(/:after|/:before)?","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1744705855429,"localOverride":null,"page":{"id":"EventBoardPage","type":"EVENT","urlPath":"/category/:categoryId/events/:boardId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1744705855429,"localOverride":null,"page":{"id":"TkbReplyPage","type":"TKB_REPLY","urlPath":"/kb/:boardId/:messageSubject/:messageId/comments/:replyId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1744705855429,"localOverride":null,"page":{"id":"IdeaBoardPage","type":"IDEA","urlPath":"/category/:categoryId/ideas/:boardId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1744705855429,"localOverride":null,"page":{"id":"CommunityGuideLinesPage","type":"COMMUNITY","urlPath":"/communityguidelines","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1744705855429,"localOverride":null,"page":{"id":"CaseCreatePage","type":"SALESFORCE_CASE_CREATION","urlPath":"/caseportal/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1744705855429,"localOverride":null,"page":{"id":"TkbEditPage","type":"TKB","urlPath":"/kb/:boardId/:messageSubject/:messageId/edit","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1744705855429,"localOverride":null,"page":{"id":"ForgotPasswordPage","type":"USER","urlPath":"/forgotpassword","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1744705855429,"localOverride":null,"page":{"id":"IdeaEditPage","type":"IDEA","urlPath":"/idea/:boardId/:messageSubject/:messageId/edit","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1744705855429,"localOverride":null,"page":{"id":"TagPage","type":"COMMUNITY","urlPath":"/tag/:tagName","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1744705855429,"localOverride":null,"page":{"id":"BlogBoardPage","type":"BLOG","urlPath":"/category/:categoryId/blog/:boardId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1744705855429,"localOverride":null,"page":{"id":"OccasionMessagePage","type":"OCCASION_TOPIC","urlPath":"/event/:boardId/:messageSubject/:messageId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1744705855429,"localOverride":null,"page":{"id":"ManageContentPage","type":"COMMUNITY","urlPath":"/managecontent","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1744705855429,"localOverride":null,"page":{"id":"ClosedMembershipNodeNonMembersPage","type":"GROUP_HUB","urlPath":"/closedgroup/:groupHubId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1744705855429,"localOverride":null,"page":{"id":"CommunityPage","type":"COMMUNITY","urlPath":"/","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1744705855429,"localOverride":null,"page":{"id":"ForumMessagePage","type":"FORUM_TOPIC","urlPath":"/discussions/:boardId/:messageSubject/:messageId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1744705855429,"localOverride":null,"page":{"id":"IdeaPostPage","type":"IDEA","urlPath":"/category/:categoryId/ideas/:boardId/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1744705855429,"localOverride":null,"page":{"id":"BlogMessagePage","type":"BLOG_ARTICLE","urlPath":"/blog/:boardId/:messageSubject/:messageId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1744705855429,"localOverride":null,"page":{"id":"RegistrationPage","type":"USER","urlPath":"/register","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1744705855429,"localOverride":null,"page":{"id":"EditGroupHubPage","type":"GROUP_HUB","urlPath":"/group/:groupHubId/edit","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1744705855429,"localOverride":null,"page":{"id":"ForumEditPage","type":"FORUM","urlPath":"/discussions/:boardId/:messageSubject/:messageId/edit","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1744705855429,"localOverride":null,"page":{"id":"ResetPasswordPage","type":"USER","urlPath":"/resetpassword/:userId/:resetPasswordToken","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1744705855429,"localOverride":null,"page":{"id":"TkbMessagePage","type":"TKB_ARTICLE","urlPath":"/kb/:boardId/:messageSubject/:messageId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1744705855429,"localOverride":null,"page":{"id":"BlogEditPage","type":"BLOG","urlPath":"/blog/:boardId/:messageSubject/:messageId/edit","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1744705855429,"localOverride":null,"page":{"id":"ManageUsersPage","type":"USER","urlPath":"/users/manage/:tab?/:manageUsersTab?","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1744705855429,"localOverride":null,"page":{"id":"ForumReplyPage","type":"FORUM_REPLY","urlPath":"/discussions/:boardId/:messageSubject/:messageId/replies/:replyId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1744705855429,"localOverride":null,"page":{"id":"PrivacyPolicyPage","type":"COMMUNITY","urlPath":"/privacypolicy","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1744705855429,"localOverride":null,"page":{"id":"NotificationPage","type":"COMMUNITY","urlPath":"/notifications","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1744705855429,"localOverride":null,"page":{"id":"UserPage","type":"USER","urlPath":"/users/:login/:userId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1744705855429,"localOverride":null,"page":{"id":"HealthCheckPage","type":"COMMUNITY","urlPath":"/health","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1744705855429,"localOverride":null,"page":{"id":"OccasionReplyPage","type":"OCCASION_REPLY","urlPath":"/event/:boardId/:messageSubject/:messageId/comments/:replyId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1744705855429,"localOverride":null,"page":{"id":"ManageMembersPage","type":"GROUP_HUB","urlPath":"/group/:groupHubId/manage/:tab?","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1744705855429,"localOverride":null,"page":{"id":"SearchResultsPage","type":"COMMUNITY","urlPath":"/search","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1744705855429,"localOverride":null,"page":{"id":"BlogReplyPage","type":"BLOG_REPLY","urlPath":"/blog/:boardId/:messageSubject/:messageId/replies/:replyId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1744705855429,"localOverride":null,"page":{"id":"GroupHubPage","type":"GROUP_HUB","urlPath":"/group/:groupHubId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1744705855429,"localOverride":null,"page":{"id":"TermsOfServicePage","type":"COMMUNITY","urlPath":"/termsofservice","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1744705855429,"localOverride":null,"page":{"id":"CategoryPage","type":"CATEGORY","urlPath":"/category/:categoryId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1744705855429,"localOverride":null,"page":{"id":"ForumViewAllTopicsPage","type":"FORUM","urlPath":"/category/:categoryId/discussions/:boardId/all-topics/(/:after|/:before)?","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1744705855429,"localOverride":null,"page":{"id":"TkbPostPage","type":"TKB","urlPath":"/category/:categoryId/kbs/:boardId/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1744705855429,"localOverride":null,"page":{"id":"GroupHubPostPage","type":"GROUP_HUB","urlPath":"/group/:groupHubId/:boardId/create","__typename":"PageDescriptor"},"__typename":"PageResource"}],"localOverride":false},"CachedAsset:text:en_US-components/context/AppContext/AppContextProvider-0":{"__typename":"CachedAsset","id":"text:en_US-components/context/AppContext/AppContextProvider-0","value":{"noCommunity":"Cannot find community","noUser":"Cannot find current user","noNode":"Cannot find node with id {nodeId}","noMessage":"Cannot find message with id {messageId}","userBanned":"We're sorry, but you have been banned from using this site.","userBannedReason":"You have been banned for the following reason: {reason}"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/common/Loading/LoadingDot-0":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/common/Loading/LoadingDot-0","value":{"title":"Loading..."},"localOverride":false},"Rank:rank:19":{"__typename":"Rank","id":"rank:19","position":20,"name":"Junior","color":"009900","icon":null,"rankStyle":"TEXT"},"User:user:116956":{"__typename":"User","id":"user:116956","uid":116956,"login":"bronccat","deleted":false,"avatar":{"__typename":"UserAvatar","url":"https://community.hughesnet.com/t5/s/ssqng67387/m_assets/avatars/default/avatar-10.svg?time=0"},"rank":{"__ref":"Rank:rank:19"},"email":"","messagesCount":75,"biography":null,"topicsCount":3,"kudosReceivedCount":12,"kudosGivenCount":25,"kudosWeight":1,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2020-10-14T21:36:30.569-04:00","confirmEmailStatus":null},"followersCount":null,"solutionsCount":0,"entityType":"USER","eventPath":"community:ssqng67387/user:116956"},"Category:category:HNSupport":{"__typename":"Category","id":"category:HNSupport","entityType":"CATEGORY","displayId":"HNSupport","nodeType":"category","depth":1,"title":"Hughesnet Support Community","shortTitle":"Hughesnet Support Community","parent":{"__ref":"Category:category:top"}},"Category:category:top":{"__typename":"Category","id":"category:top","entityType":"CATEGORY","displayId":"top","nodeType":"category","depth":0,"title":"Top","shortTitle":"Top"},"Forum:board:TechSupport":{"__typename":"Forum","id":"board:TechSupport","entityType":"FORUM","displayId":"TechSupport","nodeType":"board","depth":2,"conversationStyle":"FORUM","repliesProperties":{"__typename":"RepliesProperties","sortOrder":"PUBLISH_TIME","repliesFormat":"threaded"},"tagProperties":{"__typename":"TagNodeProperties","tagsEnabled":{"__typename":"PolicyResult","failureReason":null}},"requireTags":true,"tagType":"PRESET_ONLY","description":"Tips and tricks to getting the most out of your Hughesnet internet and Hughesnet Voice services.","title":"Tech Support","shortTitle":"Tech Support","parent":{"__ref":"Category:category:HNSupport"},"ancestors":{"__typename":"CoreNodeConnection","edges":[{"__typename":"CoreNodeEdge","node":{"__ref":"Community:community:ssqng67387"}},{"__typename":"CoreNodeEdge","node":{"__ref":"Category:category:HNSupport"}}]},"userContext":{"__typename":"NodeUserContext","canAddAttachments":false,"canUpdateNode":false,"canPostMessages":false,"isSubscribed":false},"theme":{"__ref":"Theme:customTheme1"},"boardPolicies":{"__typename":"BoardPolicies","canViewSpamDashBoard":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.feature.moderation_spam.action.access_spam_quarantine.allowed.accessDenied","key":"error.lithium.policies.feature.moderation_spam.action.access_spam_quarantine.allowed.accessDenied","args":[]}},"canArchiveMessage":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.content_archivals.enable_content_archival_settings.accessDenied","key":"error.lithium.policies.content_archivals.enable_content_archival_settings.accessDenied","args":[]}},"canPublishArticleOnCreate":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.forums.policy_can_publish_on_create_workflow_action.accessDenied","key":"error.lithium.policies.forums.policy_can_publish_on_create_workflow_action.accessDenied","args":[]}}},"avatar":{"__ref":"AssociatedImage:{\"url\":\"https://community.hughesnet.com/t5/s/ssqng67387/images/bi0xMS1qUHA3ZXA?image-coordinates=0%2C0%2C130%2C130\"}"},"eventPath":"category:HNSupport/community:ssqng67387board:TechSupport/"},"ForumTopicMessage:message:128262":{"__typename":"ForumTopicMessage","uid":128262,"subject":"Speed issues, can't stay on chat for Help","id":"message:128262","revisionNum":1,"repliesCount":123,"author":{"__ref":"User:user:116956"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:TechSupport"},"conversation":{"__ref":"Conversation:conversation:128262"},"readOnly":true,"editFrozen":false,"moderationData":{"__ref":"ModerationData:moderation_data:128262"},"body@stripHtml({\"truncateLength\":200})":"Last night DL was consistently under 1 mbps, up was 2.5 to 4 This morning, DL has ranged from sub 1 to 10. I have been on 4 chats and they just stop replying or disconnect. One rebooted modem a fe...","body@stringLength":"293","rawBody":"Last night DL was consistently under 1 mbps, up was 2.5 to 4 This morning, DL has ranged from sub 1 to 10.
I have been on 4 chats and they just stop replying or disconnect. One rebooted modem a few times.
I have no phone here, need assistance please. Should I email?","kudosSumWeight":0,"postTime":"2020-10-17T10:59:13.442-04:00","images":{"__typename":"AssociatedImageConnection","edges":[],"totalCount":0,"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"attachments":{"__typename":"AttachmentConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"tags":{"__typename":"TagConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[{"__typename":"TagEdge","cursor":"MjUuM3wyLjF8b3wxMHxfTlZffDE","node":{"__typename":"Tag","id":"tag:Performance","text":"Performance","time":"2017-03-09T08:01:18.409-05:00","lastActivityTime":null,"messagesCount":null,"followersCount":null}}]},"timeToRead":1,"currentRevision":{"__ref":"Revision:revision:128262_1"},"latestVersion":null,"metrics":{"__typename":"MessageMetrics","views":39748},"visibilityScope":"PUBLIC","canonicalUrl":null,"seoTitle":null,"seoDescription":null,"isEscalated":null,"placeholder":false,"originalMessageForPlaceholder":null,"messagePolicies":{"__typename":"MessagePolicies","canModerateSpamMessage":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","key":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","args":[]}}},"archivalData":null,"customFields":[]},"Conversation:conversation:128262":{"__typename":"Conversation","id":"conversation:128262","solved":true,"topic":{"__ref":"ForumTopicMessage:message:128262"},"lastPostingActivityTime":"2020-11-03T16:35:05.927-05:00","lastPostTime":"2020-11-03T16:35:05.927-05:00","unreadReplyCount":123,"isSubscribed":false},"ModerationData:moderation_data:128262":{"__typename":"ModerationData","id":"moderation_data:128262","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"Revision:revision:128262_1":{"__typename":"Revision","id":"revision:128262_1","lastEditTime":"2020-10-17T10:59:13.442-04:00"},"ForumReplyMessage:message:128615":{"__typename":"ForumReplyMessage","id":"message:128615","conversation":{"__ref":"Conversation:conversation:128262"},"author":{"__ref":"User:user:116956"},"revisionNum":1,"uid":128615,"depth":35,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:TechSupport"},"subject":"Re: Speed issues, can't stay on chat for Help","readOnly":true,"editFrozen":false,"moderationData":{"__ref":"ModerationData:moderation_data:128615"},"parent":{"__ref":"ForumReplyMessage:message:128611"},"body":"
My question is - and not to be a smart**bleep** - but how will she magically know that I have run the tests \"correctly\" and know I am now worthy of a response?
OK, maybe I'm being a little smart**bleep**ed.
","body@stringLength":"398","rawBody":"
","kudosSumWeight":0,"repliesCount":68,"postTime":"2020-10-25T13:17:31.480-04:00","images":{"__typename":"AssociatedImageConnection","edges":[],"totalCount":0,"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"attachments":{"__typename":"AttachmentConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"timeToRead":1,"currentRevision":{"__ref":"Revision:revision:128615_1"},"latestVersion":null,"metrics":{"__typename":"MessageMetrics","views":8164},"visibilityScope":"PUBLIC","isEscalated":null,"placeholder":false,"originalMessageForPlaceholder":null,"messagePolicies":{"__typename":"MessagePolicies","canModerateSpamMessage":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","key":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","args":[]}}},"customFields":[],"descendants":{"__typename":"MessageConnection","edges":[{"__typename":"MessageEdge","cursor":"MjUuM3wyLjF8aXwyNXwzOToxfGludCwxMjg2MTYsMTI4NjE2","node":{"__ref":"ForumReplyMessage:message:128616"}},{"__typename":"MessageEdge","cursor":"MjUuM3wyLjF8aXwyNXwzOToxfGludCwxMjg2MTYsMTI4NjE3","node":{"__ref":"ForumReplyMessage:message:128617"}},{"__typename":"MessageEdge","cursor":"MjUuM3wyLjF8aXwyNXwzOToxfGludCwxMjg2MTYsMTI4NjE5","node":{"__ref":"ForumReplyMessage:message:128619"}},{"__typename":"MessageEdge","cursor":"MjUuM3wyLjF8aXwyNXwzOToxfGludCwxMjg2MTYsMTI4NjIx","node":{"__ref":"ForumReplyMessage:message:128621"}},{"__typename":"MessageEdge","cursor":"MjUuM3wyLjF8aXwyNXwzOToxfGludCwxMjg2MTYsMTI4NjI0","node":{"__ref":"ForumReplyMessage:message:128624"}},{"__typename":"MessageEdge","cursor":"MjUuM3wyLjF8aXwyNXwzOToxfGludCwxMjg2MTYsMTI4NjI1","node":{"__ref":"ForumReplyMessage:message:128625"}},{"__typename":"MessageEdge","cursor":"MjUuM3wyLjF8aXwyNXwzOToxfGludCwxMjg2MTYsMTI4NjQ3","node":{"__ref":"ForumReplyMessage:message:128647"}},{"__typename":"MessageEdge","cursor":"MjUuM3wyLjF8aXwyNXwzOToxfGludCwxMjg2MTYsMTI4NjQ5","node":{"__ref":"ForumReplyMessage:message:128649"}},{"__typename":"MessageEdge","cursor":"MjUuM3wyLjF8aXwyNXwzOToxfGludCwxMjg2MTYsMTI4NjUx","node":{"__ref":"ForumReplyMessage:message:128651"}},{"__typename":"MessageEdge","cursor":"MjUuM3wyLjF8aXwyNXwzOToxfGludCwxMjg2MTYsMTI4NjUy","node":{"__ref":"ForumReplyMessage:message:128652"}},{"__typename":"MessageEdge","cursor":"MjUuM3wyLjF8aXwyNXwzOToxfGludCwxMjg2MTYsMTI4NjUz","node":{"__ref":"ForumReplyMessage:message:128653"}},{"__typename":"MessageEdge","cursor":"MjUuM3wyLjF8aXwyNXwzOToxfGludCwxMjg2MTYsMTI4NjU1","node":{"__ref":"ForumReplyMessage:message:128655"}},{"__typename":"MessageEdge","cursor":"MjUuM3wyLjF8aXwyNXwzOToxfGludCwxMjg2MTYsMTI4NjU2","node":{"__ref":"ForumReplyMessage:message:128656"}},{"__typename":"MessageEdge","cursor":"MjUuM3wyLjF8aXwyNXwzOToxfGludCwxMjg2MTYsMTI4Njcz","node":{"__ref":"ForumReplyMessage:message:128673"}},{"__typename":"MessageEdge","cursor":"MjUuM3wyLjF8aXwyNXwzOToxfGludCwxMjg2MTYsMTI4Njgz","node":{"__ref":"ForumReplyMessage:message:128683"}},{"__typename":"MessageEdge","cursor":"MjUuM3wyLjF8aXwyNXwzOToxfGludCwxMjg2MTYsMTI4Njg1","node":{"__ref":"ForumReplyMessage:message:128685"}},{"__typename":"MessageEdge","cursor":"MjUuM3wyLjF8aXwyNXwzOToxfGludCwxMjg2MTYsMTI4Njg2","node":{"__ref":"ForumReplyMessage:message:128686"}},{"__typename":"MessageEdge","cursor":"MjUuM3wyLjF8aXwyNXwzOToxfGludCwxMjg2MTYsMTI4Njg3","node":{"__ref":"ForumReplyMessage:message:128687"}},{"__typename":"MessageEdge","cursor":"MjUuM3wyLjF8aXwyNXwzOToxfGludCwxMjg2MTYsMTI4NzI3","node":{"__ref":"ForumReplyMessage:message:128727"}},{"__typename":"MessageEdge","cursor":"MjUuM3wyLjF8aXwyNXwzOToxfGludCwxMjg2MTYsMTI4NzMx","node":{"__ref":"ForumReplyMessage:message:128731"}},{"__typename":"MessageEdge","cursor":"MjUuM3wyLjF8aXwyNXwzOToxfGludCwxMjg2MTYsMTI4NzMz","node":{"__ref":"ForumReplyMessage:message:128733"}},{"__typename":"MessageEdge","cursor":"MjUuM3wyLjF8aXwyNXwzOToxfGludCwxMjg2MTYsMTI4NzM0","node":{"__ref":"ForumReplyMessage:message:128734"}},{"__typename":"MessageEdge","cursor":"MjUuM3wyLjF8aXwyNXwzOToxfGludCwxMjg2MTYsMTI4NzM2","node":{"__ref":"ForumReplyMessage:message:128736"}},{"__typename":"MessageEdge","cursor":"MjUuM3wyLjF8aXwyNXwzOToxfGludCwxMjg2MTYsMTI4NzM3","node":{"__ref":"ForumReplyMessage:message:128737"}},{"__typename":"MessageEdge","cursor":"MjUuM3wyLjF8aXwyNXwzOToxfGludCwxMjg2MTYsMTI4NzM4","node":{"__ref":"ForumReplyMessage:message:128738"}}],"pageInfo":{"__typename":"PageInfo","hasNextPage":true,"endCursor":"MjUuM3wyLjF8aXwyNXwzOToxfGludCwxMjg2MTYsMTI4NzM4","hasPreviousPage":false,"startCursor":null}}},"CachedAsset:theme:customTheme1-1744705855003":{"__typename":"CachedAsset","id":"theme:customTheme1-1744705855003","value":{"id":"customTheme1","animation":{"fast":"150ms","normal":"250ms","slow":"500ms","slowest":"750ms","function":"cubic-bezier(0.07, 0.91, 0.51, 1)","__typename":"AnimationThemeSettings"},"avatar":{"borderRadius":"50%","collections":["default"],"__typename":"AvatarThemeSettings"},"basics":{"browserIcon":{"imageAssetName":"rebrand-favicon-1721032736485.png","imageLastModified":"1721032741408","__typename":"ThemeAsset"},"customerLogo":{"imageAssetName":"HughesnetLogo-1721027846492.png","imageLastModified":"1721027849927","__typename":"ThemeAsset"},"maximumWidthOfPageContent":"1200px","oneColumnNarrowWidth":"800px","gridGutterWidthMd":"30px","gridGutterWidthXs":"10px","pageWidthStyle":"WIDTH_OF_BROWSER","__typename":"BasicsThemeSettings"},"buttons":{"borderRadiusSm":"100vw","borderRadius":"100vw","borderRadiusLg":"100vw","paddingY":"5px","paddingYLg":"7px","paddingYHero":"var(--lia-bs-btn-padding-y-lg)","paddingX":"22px","paddingXLg":"24px","paddingXHero":"56px","fontStyle":"NORMAL","fontWeight":"400","textTransform":"NONE","disabledOpacity":0.5,"primaryTextColor":"var(--lia-bs-white)","primaryTextHoverColor":"var(--lia-bs-white)","primaryTextActiveColor":"var(--lia-bs-white)","primaryBgColor":"var(--lia-bs-primary)","primaryBgHoverColor":"hsl(var(--lia-bs-primary-h), var(--lia-bs-primary-s), calc(var(--lia-bs-primary-l) * 0.85))","primaryBgActiveColor":"hsl(var(--lia-bs-primary-h), var(--lia-bs-primary-s), calc(var(--lia-bs-primary-l) * 0.7))","primaryBorder":"1px solid transparent","primaryBorderHover":"1px solid transparent","primaryBorderActive":"1px solid transparent","primaryBorderFocus":"1px solid var(--lia-bs-white)","primaryBoxShadowFocus":"0 0 0 1px var(--lia-bs-primary), 0 0 0 4px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","secondaryTextColor":"var(--lia-bs-gray-900)","secondaryTextHoverColor":"hsl(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), calc(var(--lia-bs-gray-900-l) * 0.95))","secondaryTextActiveColor":"hsl(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), calc(var(--lia-bs-gray-900-l) * 0.9))","secondaryBgColor":"var(--lia-bs-gray-200)","secondaryBgHoverColor":"hsl(var(--lia-bs-gray-200-h), var(--lia-bs-gray-200-s), calc(var(--lia-bs-gray-200-l) * 0.96))","secondaryBgActiveColor":"hsl(var(--lia-bs-gray-200-h), var(--lia-bs-gray-200-s), calc(var(--lia-bs-gray-200-l) * 0.92))","secondaryBorder":"1px solid transparent","secondaryBorderHover":"1px solid transparent","secondaryBorderActive":"1px solid transparent","secondaryBorderFocus":"1px solid transparent","secondaryBoxShadowFocus":"0 0 0 1px var(--lia-bs-primary), 0 0 0 4px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","tertiaryTextColor":"var(--lia-bs-gray-900)","tertiaryTextHoverColor":"hsl(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), calc(var(--lia-bs-gray-900-l) * 0.95))","tertiaryTextActiveColor":"hsl(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), calc(var(--lia-bs-gray-900-l) * 0.9))","tertiaryBgColor":"transparent","tertiaryBgHoverColor":"transparent","tertiaryBgActiveColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.04)","tertiaryBorder":"1px solid transparent","tertiaryBorderHover":"1px solid hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.08)","tertiaryBorderActive":"1px solid transparent","tertiaryBorderFocus":"1px solid transparent","tertiaryBoxShadowFocus":"0 0 0 1px var(--lia-bs-primary), 0 0 0 4px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","destructiveTextColor":"var(--lia-bs-danger)","destructiveTextHoverColor":"hsl(var(--lia-bs-danger-h), var(--lia-bs-danger-s), calc(var(--lia-bs-danger-l) * 0.95))","destructiveTextActiveColor":"hsl(var(--lia-bs-danger-h), var(--lia-bs-danger-s), calc(var(--lia-bs-danger-l) * 0.9))","destructiveBgColor":"var(--lia-bs-gray-200)","destructiveBgHoverColor":"hsl(var(--lia-bs-gray-200-h), var(--lia-bs-gray-200-s), calc(var(--lia-bs-gray-200-l) * 0.96))","destructiveBgActiveColor":"hsl(var(--lia-bs-gray-200-h), var(--lia-bs-gray-200-s), calc(var(--lia-bs-gray-200-l) * 0.92))","destructiveBorder":"1px solid transparent","destructiveBorderHover":"1px solid transparent","destructiveBorderActive":"1px solid transparent","destructiveBorderFocus":"1px solid transparent","destructiveBoxShadowFocus":"0 0 0 1px var(--lia-bs-primary), 0 0 0 4px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","__typename":"ButtonsThemeSettings"},"border":{"color":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.08)","mainContent":"DARK","sideContent":"DARK","radiusSm":"3px","radius":"5px","radiusLg":"9px","radius50":"100vw","__typename":"BorderThemeSettings"},"boxShadow":{"xs":"0 0 0 1px hsla(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), var(--lia-bs-gray-900-l), 0.08), 0 3px 0 -1px hsla(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), var(--lia-bs-gray-900-l), 0.16)","sm":"0 2px 4px hsla(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), var(--lia-bs-gray-900-l), 0.12)","md":"0 5px 15px hsla(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), var(--lia-bs-gray-900-l), 0.3)","lg":"0 10px 30px hsla(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), var(--lia-bs-gray-900-l), 0.3)","__typename":"BoxShadowThemeSettings"},"cards":{"bgColor":"var(--lia-panel-bg-color)","borderRadius":"var(--lia-panel-border-radius)","boxShadow":"var(--lia-box-shadow-xs)","__typename":"CardsThemeSettings"},"chip":{"maxWidth":"300px","height":"30px","__typename":"ChipThemeSettings"},"coreTypes":{"defaultMessageLinkColor":"#005DAC","defaultMessageLinkDecoration":"none","defaultMessageLinkFontStyle":"NORMAL","defaultMessageLinkFontWeight":"400","defaultMessageFontStyle":"NORMAL","defaultMessageFontWeight":"400","defaultMessageFontFamily":"var(--lia-bs-font-family-base)","forumColor":"#4099E2","forumFontFamily":"var(--lia-bs-font-family-base)","forumFontWeight":"var(--lia-default-message-font-weight)","forumLineHeight":"var(--lia-bs-line-height-base)","forumFontStyle":"var(--lia-default-message-font-style)","forumMessageLinkColor":"var(--lia-default-message-link-color)","forumMessageLinkDecoration":"var(--lia-default-message-link-decoration)","forumMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","forumMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","forumSolvedColor":"#148563","blogColor":"#1CBAA0","blogFontFamily":"var(--lia-bs-font-family-base)","blogFontWeight":"var(--lia-default-message-font-weight)","blogLineHeight":"1.75","blogFontStyle":"var(--lia-default-message-font-style)","blogMessageLinkColor":"var(--lia-default-message-link-color)","blogMessageLinkDecoration":"var(--lia-default-message-link-decoration)","blogMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","blogMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","tkbColor":"#4C6B90","tkbFontFamily":"var(--lia-bs-font-family-base)","tkbFontWeight":"var(--lia-default-message-font-weight)","tkbLineHeight":"1.75","tkbFontStyle":"var(--lia-default-message-font-style)","tkbMessageLinkColor":"var(--lia-default-message-link-color)","tkbMessageLinkDecoration":"var(--lia-default-message-link-decoration)","tkbMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","tkbMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","qandaColor":"#4099E2","qandaFontFamily":"var(--lia-bs-font-family-base)","qandaFontWeight":"var(--lia-default-message-font-weight)","qandaLineHeight":"var(--lia-bs-line-height-base)","qandaFontStyle":"var(--lia-default-message-link-font-style)","qandaMessageLinkColor":"var(--lia-default-message-link-color)","qandaMessageLinkDecoration":"var(--lia-default-message-link-decoration)","qandaMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","qandaMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","qandaSolvedColor":"#3FA023","ideaColor":"#FF8000","ideaFontFamily":"var(--lia-bs-font-family-base)","ideaFontWeight":"var(--lia-default-message-font-weight)","ideaLineHeight":"var(--lia-bs-line-height-base)","ideaFontStyle":"var(--lia-default-message-font-style)","ideaMessageLinkColor":"var(--lia-default-message-link-color)","ideaMessageLinkDecoration":"var(--lia-default-message-link-decoration)","ideaMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","ideaMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","contestColor":"#FCC845","contestFontFamily":"var(--lia-bs-font-family-base)","contestFontWeight":"var(--lia-default-message-font-weight)","contestLineHeight":"var(--lia-bs-line-height-base)","contestFontStyle":"var(--lia-default-message-link-font-style)","contestMessageLinkColor":"var(--lia-default-message-link-color)","contestMessageLinkDecoration":"var(--lia-default-message-link-decoration)","contestMessageLinkFontStyle":"ITALIC","contestMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","occasionColor":"#D13A1F","occasionFontFamily":"var(--lia-bs-font-family-base)","occasionFontWeight":"var(--lia-default-message-font-weight)","occasionLineHeight":"var(--lia-bs-line-height-base)","occasionFontStyle":"var(--lia-default-message-font-style)","occasionMessageLinkColor":"var(--lia-default-message-link-color)","occasionMessageLinkDecoration":"var(--lia-default-message-link-decoration)","occasionMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","occasionMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","grouphubColor":"#333333","categoryColor":"#949494","communityColor":"#FFFFFF","productColor":"#949494","__typename":"CoreTypesThemeSettings"},"colors":{"black":"#000000","white":"#FFFFFF","gray100":"#F7F7F7","gray200":"#F7F7F7","gray300":"#E8E8E8","gray400":"#D9D9D9","gray500":"#CCCCCC","gray600":"#949494","gray700":"#707070","gray800":"#545454","gray900":"#333333","dark":"#545454","light":"#F7F7F7","primary":"#005DAC","secondary":"#333333","bodyText":"#000000","bodyBg":"#F7F7F8","info":"#409AE2","success":"#41C5AE","warning":"#FCB116","danger":"#DE3700","alertSystem":"#FF6600","textMuted":"#707070","highlight":"#FFFCAD","outline":"var(--lia-bs-primary)","custom":["#00223A","#0096FA","#0E4275","#005DAC","#1C475A","#00223A","#0E4275","#FF0000","#0099AA","#582596","#660099","#0000FF","#0066FF","#006600","#009900","#00CC00","#33CC00"],"__typename":"ColorsThemeSettings"},"divider":{"size":"3px","marginLeft":"4px","marginRight":"4px","borderRadius":"50%","bgColor":"var(--lia-bs-gray-600)","bgColorActive":"var(--lia-bs-gray-600)","__typename":"DividerThemeSettings"},"dropdown":{"fontSize":"var(--lia-bs-font-size-sm)","borderColor":"var(--lia-bs-border-color)","borderRadius":"var(--lia-bs-border-radius-sm)","dividerBg":"var(--lia-bs-gray-300)","itemPaddingY":"5px","itemPaddingX":"20px","headerColor":"var(--lia-bs-gray-700)","__typename":"DropdownThemeSettings"},"email":null,"emoji":{"skinToneDefault":"#ffcd43","skinToneLight":"#fae3c5","skinToneMediumLight":"#e2cfa5","skinToneMedium":"#daa478","skinToneMediumDark":"#a78058","skinToneDark":"#5e4d43","__typename":"EmojiThemeSettings"},"heading":{"color":"var(--lia-bs-body-color)","fontFamily":"Montserrat","fontStyle":"NORMAL","fontWeight":"700","h1FontSize":"34px","h2FontSize":"28px","h3FontSize":"18px","h4FontSize":"18px","h5FontSize":"18px","h6FontSize":"18px","lineHeight":"1.3","subHeaderFontSize":"11px","subHeaderFontWeight":"500","h1LetterSpacing":"normal","h2LetterSpacing":"normal","h3LetterSpacing":"normal","h4LetterSpacing":"normal","h5LetterSpacing":"normal","h6LetterSpacing":"normal","subHeaderLetterSpacing":"2px","h1FontWeight":"var(--lia-bs-headings-font-weight)","h2FontWeight":"var(--lia-bs-headings-font-weight)","h3FontWeight":"var(--lia-bs-headings-font-weight)","h4FontWeight":"var(--lia-bs-headings-font-weight)","h5FontWeight":"var(--lia-bs-headings-font-weight)","h6FontWeight":"var(--lia-bs-headings-font-weight)","__typename":"HeadingThemeSettings"},"icons":{"size10":null,"size12":"12px","size14":"14px","size16":"16px","size20":"20px","size24":"24px","size30":"30px","size40":"40px","size50":"50px","size60":"60px","size80":"80px","size120":"120px","size160":"160px","__typename":"IconsThemeSettings"},"imagePreview":{"bgColor":"var(--lia-bs-gray-900)","titleColor":"var(--lia-bs-white)","controlColor":"var(--lia-bs-white)","controlBgColor":"var(--lia-bs-gray-800)","__typename":"ImagePreviewThemeSettings"},"input":{"borderColor":"var(--lia-bs-gray-600)","disabledColor":"var(--lia-bs-gray-600)","focusBorderColor":"var(--lia-bs-primary)","labelMarginBottom":"10px","btnFontSize":"var(--lia-bs-font-size-sm)","focusBoxShadow":"0 0 0 3px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","checkLabelMarginBottom":"2px","checkboxBorderRadius":"3px","borderRadiusSm":"100vw","borderRadius":"100vw","borderRadiusLg":"100vw","formTextMarginTop":"4px","textAreaBorderRadius":"20px","activeFillColor":"var(--lia-bs-primary)","__typename":"InputThemeSettings"},"loading":{"dotDarkColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.2)","dotLightColor":"hsla(var(--lia-bs-white-h), var(--lia-bs-white-s), var(--lia-bs-white-l), 0.5)","barDarkColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.06)","barLightColor":"hsla(var(--lia-bs-white-h), var(--lia-bs-white-s), var(--lia-bs-white-l), 0.4)","__typename":"LoadingThemeSettings"},"link":{"color":"var(--lia-bs-primary)","hoverColor":"hsl(var(--lia-bs-primary-h), var(--lia-bs-primary-s), calc(var(--lia-bs-primary-l) - 10%))","decoration":"none","hoverDecoration":"underline","__typename":"LinkThemeSettings"},"listGroup":{"itemPaddingY":"15px","itemPaddingX":"15px","borderColor":"var(--lia-bs-gray-300)","__typename":"ListGroupThemeSettings"},"modal":{"contentTextColor":"var(--lia-bs-body-color)","contentBg":"var(--lia-bs-white)","backgroundBg":"var(--lia-bs-black)","smSize":"440px","mdSize":"760px","lgSize":"1080px","backdropOpacity":0.3,"contentBoxShadowXs":"var(--lia-bs-box-shadow-sm)","contentBoxShadow":"var(--lia-bs-box-shadow)","headerFontWeight":"700","__typename":"ModalThemeSettings"},"navbar":{"position":"FIXED","background":{"attachment":null,"clip":null,"color":"var(--lia-bs-white)","imageAssetName":"","imageLastModified":"0","origin":null,"position":"CENTER_CENTER","repeat":"NO_REPEAT","size":"COVER","__typename":"BackgroundProps"},"backgroundOpacity":0.8,"paddingTop":"15px","paddingBottom":"15px","borderBottom":"1px solid var(--lia-bs-border-color)","boxShadow":"var(--lia-bs-box-shadow-sm)","brandMarginRight":"30px","brandMarginRightSm":"10px","brandLogoHeight":"30px","linkGap":"10px","linkJustifyContent":"flex-start","linkPaddingY":"5px","linkPaddingX":"10px","linkDropdownPaddingY":"9px","linkDropdownPaddingX":"var(--lia-nav-link-px)","linkColor":"var(--lia-bs-body-color)","linkHoverColor":"var(--lia-bs-primary)","linkFontSize":"var(--lia-bs-font-size-sm)","linkFontStyle":"NORMAL","linkFontWeight":"400","linkTextTransform":"NONE","linkLetterSpacing":"normal","linkBorderRadius":"var(--lia-bs-border-radius-sm)","linkBgColor":"transparent","linkBgHoverColor":"transparent","linkBorder":"none","linkBorderHover":"none","linkBoxShadow":"none","linkBoxShadowHover":"none","linkTextBorderBottom":"none","linkTextBorderBottomHover":"none","dropdownPaddingTop":"10px","dropdownPaddingBottom":"15px","dropdownPaddingX":"10px","dropdownMenuOffset":"2px","dropdownDividerMarginTop":"10px","dropdownDividerMarginBottom":"10px","dropdownBorderColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.08)","controllerBgHoverColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.1)","controllerIconColor":"var(--lia-bs-body-color)","controllerIconHoverColor":"var(--lia-bs-body-color)","controllerTextColor":"var(--lia-nav-controller-icon-color)","controllerTextHoverColor":"var(--lia-nav-controller-icon-hover-color)","controllerHighlightColor":"hsla(30, 100%, 50%)","controllerHighlightTextColor":"var(--lia-yiq-light)","controllerBorderRadius":"var(--lia-border-radius-50)","hamburgerColor":"var(--lia-nav-controller-icon-color)","hamburgerHoverColor":"var(--lia-nav-controller-icon-color)","hamburgerBgColor":"transparent","hamburgerBgHoverColor":"transparent","hamburgerBorder":"none","hamburgerBorderHover":"none","collapseMenuMarginLeft":"20px","collapseMenuDividerBg":"var(--lia-nav-link-color)","collapseMenuDividerOpacity":0.16,"__typename":"NavbarThemeSettings"},"pager":{"textColor":"var(--lia-bs-link-color)","textFontWeight":"var(--lia-font-weight-md)","textFontSize":"var(--lia-bs-font-size-sm)","__typename":"PagerThemeSettings"},"panel":{"bgColor":"var(--lia-bs-white)","borderRadius":"var(--lia-bs-border-radius)","borderColor":"var(--lia-bs-border-color)","boxShadow":"none","__typename":"PanelThemeSettings"},"popover":{"arrowHeight":"8px","arrowWidth":"16px","maxWidth":"300px","minWidth":"100px","headerBg":"var(--lia-bs-white)","borderColor":"var(--lia-bs-border-color)","borderRadius":"var(--lia-bs-border-radius)","boxShadow":"0 0.5rem 1rem hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.15)","__typename":"PopoverThemeSettings"},"prism":{"color":"#000000","bgColor":"#f5f2f0","fontFamily":"var(--font-family-monospace)","fontSize":"var(--lia-bs-font-size-base)","fontWeightBold":"var(--lia-bs-font-weight-bold)","fontStyleItalic":"italic","tabSize":2,"highlightColor":"#b3d4fc","commentColor":"#62707e","punctuationColor":"#6f6f6f","namespaceOpacity":"0.7","propColor":"#990055","selectorColor":"#517a00","operatorColor":"#906736","operatorBgColor":"hsla(0, 0%, 100%, 0.5)","keywordColor":"#0076a9","functionColor":"#d3284b","variableColor":"#c14700","__typename":"PrismThemeSettings"},"rte":{"bgColor":"var(--lia-bs-white)","borderRadius":"var(--lia-panel-border-radius)","boxShadow":" var(--lia-panel-box-shadow)","customColor1":"#bfedd2","customColor2":"#fbeeb8","customColor3":"#f8cac6","customColor4":"#eccafa","customColor5":"#c2e0f4","customColor6":"#2dc26b","customColor7":"#f1c40f","customColor8":"#e03e2d","customColor9":"#b96ad9","customColor10":"#3598db","customColor11":"#169179","customColor12":"#e67e23","customColor13":"#ba372a","customColor14":"#843fa1","customColor15":"#236fa1","customColor16":"#ecf0f1","customColor17":"#ced4d9","customColor18":"#95a5a6","customColor19":"#7e8c8d","customColor20":"#34495e","customColor21":"#000000","customColor22":"#ffffff","defaultMessageHeaderMarginTop":"15px","defaultMessageHeaderMarginBottom":"15px","defaultMessageItemMarginTop":"0","defaultMessageItemMarginBottom":"16px","diffAddedColor":"hsla(170, 53%, 51%, 0.4)","diffChangedColor":"hsla(43, 97%, 63%, 0.4)","diffNoneColor":"hsla(0, 0%, 80%, 0.4)","diffRemovedColor":"hsla(9, 74%, 47%, 0.4)","specialMessageHeaderMarginTop":"15px","specialMessageHeaderMarginBottom":"15px","specialMessageItemMarginTop":"0","specialMessageItemMarginBottom":"16px","__typename":"RteThemeSettings"},"tags":{"bgColor":"var(--lia-bs-gray-200)","bgHoverColor":"var(--lia-bs-gray-400)","borderRadius":"var(--lia-bs-border-radius-sm)","color":"var(--lia-bs-body-color)","hoverColor":"var(--lia-bs-body-color)","fontWeight":"var(--lia-font-weight-md)","fontSize":"var(--lia-font-size-xxs)","textTransform":"UPPERCASE","letterSpacing":"0.5px","__typename":"TagsThemeSettings"},"toasts":{"borderRadius":"var(--lia-bs-border-radius)","paddingX":"12px","__typename":"ToastsThemeSettings"},"typography":{"fontFamilyBase":"Source Sans Pro","fontStyleBase":"NORMAL","fontWeightBase":"400","fontWeightLight":"300","fontWeightNormal":"400","fontWeightMd":"500","fontWeightBold":"700","letterSpacingSm":"normal","letterSpacingXs":"normal","lineHeightBase":"1.5","fontSizeBase":"16px","fontSizeXxs":"11px","fontSizeXs":"14px","fontSizeSm":"15px","fontSizeLg":"20px","fontSizeXl":"24px","smallFontSize":"14px","customFonts":[{"source":"SERVER","name":"Axiforma-Regular","styles":[{"style":"NORMAL","weight":"400","__typename":"FontStyleData"}],"assetNames":["Axiforma-Regular-normal-400.woff2"],"__typename":"CustomFont"},{"source":"SERVER","name":"Source Sans Pro","styles":[{"style":"NORMAL","weight":"400","__typename":"FontStyleData"}],"assetNames":["SourceSansPro-normal-400.woff2"],"__typename":"CustomFont"}],"__typename":"TypographyThemeSettings"},"unstyledListItem":{"marginBottomSm":"5px","marginBottomMd":"10px","marginBottomLg":"15px","marginBottomXl":"20px","marginBottomXxl":"25px","__typename":"UnstyledListItemThemeSettings"},"yiq":{"light":"#ffffff","dark":"#000000","__typename":"YiqThemeSettings"},"colorLightness":{"primaryDark":0.36,"primaryLight":0.74,"primaryLighter":0.89,"primaryLightest":0.95,"infoDark":0.39,"infoLight":0.72,"infoLighter":0.85,"infoLightest":0.93,"successDark":0.24,"successLight":0.62,"successLighter":0.8,"successLightest":0.91,"warningDark":0.39,"warningLight":0.68,"warningLighter":0.84,"warningLightest":0.93,"dangerDark":0.41,"dangerLight":0.72,"dangerLighter":0.89,"dangerLightest":0.95,"__typename":"ColorLightnessThemeSettings"},"localOverride":false,"__typename":"Theme"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/common/Loading/LoadingDot-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/common/Loading/LoadingDot-1739990369000","value":{"title":"Loading..."},"localOverride":false},"CachedAsset:quilt:hughes.prod:pages/forums/ForumMessagePage:board:TechSupport-1744705853218":{"__typename":"CachedAsset","id":"quilt:hughes.prod:pages/forums/ForumMessagePage:board:TechSupport-1744705853218","value":{"id":"ForumMessagePage","container":{"id":"Common","headerProps":{"backgroundImageProps":null,"backgroundColor":null,"addComponents":null,"removeComponents":["community.widget.bannerWidget"],"componentOrder":null,"__typename":"QuiltContainerSectionProps"},"headerComponentProps":{"community.widget.breadcrumbWidget":{"disableLastCrumbForDesktop":false}},"footerProps":null,"footerComponentProps":null,"items":[{"id":"message-list","layout":"MAIN_SIDE","bgColor":null,"showTitle":null,"showDescription":null,"textPosition":null,"textColor":null,"sectionEditLevel":null,"bgImage":null,"disableSpacing":null,"edgeToEdgeDisplay":null,"fullHeight":null,"showBorder":null,"__typename":"MainSideQuiltSection","columnMap":{"main":[{"id":"messages.widget.topicWithThreadedReplyListWidget","className":"lia-topic-with-replies","props":{"editLevel":"CONFIGURE"},"__typename":"QuiltComponent"}],"side":[{"id":"messages.widget.relatedContentWidget","className":null,"props":null,"__typename":"QuiltComponent"},{"id":"messages.widget.messageListForNodeByRecentActivityWidget","className":null,"props":{"hideIfEmpty":true,"useTitle":true,"showTabs":false,"pageSize":5,"pagerVariant":{"type":"loadMore"},"style":"compact","viewVariant":{"type":"inline","props":{"useRepliesCount":false,"useMedia":false,"useAuthorRank":false,"useNode":false,"boardIconSize":"24","truncateBodyLength":-1,"useNodeLink":true,"usePreviewMedia":false,"timeStampType":"conversation.lastPostingActivityTime","avatarSize":"40","useTextBody":true,"useSolvedBadge":true,"subjectAs":"h6","renderPostTimeBeforeAuthor":true,"useAvatar":true,"useTimeToRead":false,"useSpoilerFreeBody":true,"useKudosCount":false,"useViewCount":false,"useBody":false,"useTags":false,"clampSubjectLines":1,"useBoardIcon":false,"useMessageTimeLink":true,"clampBodyLines":3,"useAuthorLogin":true,"useUnreadCount":false,"useNodeHoverCard":true,"useSearchSnippet":false}},"panelType":"divider","sorts":{"conversationLastPostingActivityTime":{"direction":"DESC"}}},"__typename":"QuiltComponent"},{"id":"custom.widget.MixPanelTracker","className":null,"props":{"widgetVisibility":"signedInOrAnonymous","useTitle":true,"useBackground":false,"title":"","lazyLoad":false},"__typename":"QuiltComponent"}],"__typename":"MainSideSectionColumns"}}],"__typename":"QuiltContainer"},"__typename":"Quilt","localOverride":false},"localOverride":false},"CachedAsset:text:en_US-components/common/EmailVerification-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/common/EmailVerification-1739990369000","value":{"email.verification.title":"Email Verification Required","email.verification.message.update.email":"To participate in the community, you must first verify your email address. The verification email was sent to {email}. To change your email, visit My Settings.","email.verification.message.resend.email":"To participate in the community, you must first verify your email address. The verification email was sent to {email}. Resend email."},"localOverride":false},"CachedAsset:text:en_US-pages/forums/ForumMessagePage-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-pages/forums/ForumMessagePage-1739990369000","value":{"title":"{contextMessageSubject} | {communityTitle}","errorMissing":"This message cannot be found","name":"Forum Message Page","section.message-list.title":"Forum Discussion","archivedMessageTitle":"This Content Has Been Archived"},"localOverride":false},"CachedAsset:quiltWrapper:hughes.prod:Common:1744705803448":{"__typename":"CachedAsset","id":"quiltWrapper:hughes.prod:Common:1744705803448","value":{"id":"Common","header":{"backgroundImageProps":{"assetName":null,"backgroundSize":"COVER","backgroundRepeat":"NO_REPEAT","backgroundPosition":"CENTER_CENTER","lastModified":null,"__typename":"BackgroundImageProps"},"backgroundColor":"transparent","items":[{"id":"community.widget.navbarWidget","props":{"showUserName":false,"showRegisterLink":true,"useIconLanguagePicker":true,"useLabelLanguagePicker":true,"links":{"sideLinks":[],"mainLinks":[]},"className":"QuiltComponent_lia-component-edit-mode__0nCcm","style":{"boxShadow":"var(--lia-bs-box-shadow-sm)","linkFontWeight":"400","controllerHighlightColor":"hsla(30, 100%, 50%)","dropdownDividerMarginBottom":"10px","hamburgerBorderHover":"none","linkFontSize":"15px","linkBoxShadowHover":"none","backgroundOpacity":0.8,"controllerBorderRadius":"var(--lia-border-radius-50)","hamburgerBgColor":"transparent","linkTextBorderBottom":"none","hamburgerColor":"var(--lia-nav-controller-icon-color)","brandLogoHeight":"46px","linkLetterSpacing":"normal","linkBgHoverColor":"transparent","collapseMenuDividerOpacity":0.16,"paddingBottom":"10px","dropdownPaddingBottom":"15px","dropdownMenuOffset":"2px","hamburgerBgHoverColor":"transparent","borderBottom":"1px solid var(--lia-bs-border-color)","hamburgerBorder":"none","dropdownPaddingX":"10px","brandMarginRightSm":"10px","linkBoxShadow":"none","linkJustifyContent":"center","linkColor":"var(--lia-bs-primary)","collapseMenuDividerBg":"var(--lia-nav-link-color)","dropdownPaddingTop":"10px","controllerTextColor":"var(--lia-nav-controller-icon-color)","controllerHighlightTextColor":"var(--lia-yiq-dark)","background":{"imageAssetName":"","color":"var(--lia-bs-white)","size":"COVER","repeat":"NO_REPEAT","position":"CENTER_CENTER","imageLastModified":""},"linkBorderRadius":"var(--lia-bs-border-radius-sm)","linkHoverColor":"var(--lia-bs-primary)","position":"FIXED","linkBorder":"none","linkTextBorderBottomHover":"0","brandMarginRight":"30px","hamburgerHoverColor":"var(--lia-nav-controller-icon-color)","linkBorderHover":"none","collapseMenuMarginLeft":"20px","linkFontStyle":"NORMAL","linkPaddingX":"10px","controllerTextHoverColor":"var(--lia-nav-controller-icon-hover-color)","paddingTop":"10px","linkPaddingY":"5px","linkTextTransform":"NONE","dropdownBorderColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.08)","controllerBgHoverColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.1)","linkDropdownPaddingX":"var(--lia-nav-link-px)","linkBgColor":"transparent","linkDropdownPaddingY":"9px","controllerIconColor":"var(--lia-bs-body-color)","dropdownDividerMarginTop":"10px","linkGap":"10px","controllerIconHoverColor":"var(--lia-bs-body-color)"},"showSearchIcon":true,"languagePickerStyle":"iconAndLabel"},"__typename":"QuiltComponent"},{"id":"community.widget.breadcrumbWidget","props":{"backgroundColor":"var(--lia-bs-body-bg)","linkHighlightColor":"var(--lia-bs-primary)","visualEffects":{"showBottomBorder":true},"linkTextColor":"var(--lia-bs-body-color)"},"__typename":"QuiltComponent"},{"id":"community.widget.bannerWidget","props":{"backgroundColor":"var(--lia-bs-primary)","visualEffects":{"showBottomBorder":true},"backgroundOpacity":100,"backgroundImageProps":{"backgroundSize":"COVER","backgroundPosition":"CENTER_CENTER","backgroundRepeat":"NO_REPEAT"},"fontColor":"var(--lia-bs-body-bg)"},"__typename":"QuiltComponent"},{"id":"custom.widget.GoogleTagTracker","props":{"widgetVisibility":"signedInOrAnonymous","useTitle":true,"cProp_gtag":"G-JZZW630G5D","useBackground":false,"title":"","lazyLoad":false,"widgetChooser":"custom.widget.GoogleTagTracker"},"__typename":"QuiltComponent"}],"__typename":"QuiltWrapperSection"},"footer":{"backgroundImageProps":{"assetName":null,"backgroundSize":"COVER","backgroundRepeat":"NO_REPEAT","backgroundPosition":"CENTER_CENTER","lastModified":null,"__typename":"BackgroundImageProps"},"backgroundColor":"#00223A","items":[{"id":"custom.widget.custom_Footer","props":{"widgetVisibility":"signedInOrAnonymous","useTitle":true,"useBackground":false,"title":"","lazyLoad":false},"__typename":"QuiltComponent"}],"__typename":"QuiltWrapperSection"},"__typename":"QuiltWrapper","localOverride":false},"localOverride":false},"CachedAsset:text:en_US-components/common/ActionFeedback-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/common/ActionFeedback-1739990369000","value":{"joinedGroupHub.title":"Welcome","joinedGroupHub.message":"You are now a member of this group and are subscribed to updates.","groupHubInviteNotFound.title":"Invitation Not Found","groupHubInviteNotFound.message":"Sorry, we could not find your invitation to the group. The owner may have canceled the invite.","groupHubNotFound.title":"Group Not Found","groupHubNotFound.message":"The grouphub you tried to join does not exist. It may have been deleted.","existingGroupHubMember.title":"Already Joined","existingGroupHubMember.message":"You are already a member of this group.","accountLocked.title":"Account Locked","accountLocked.message":"Your account has been locked due to multiple failed attempts. Try again in {lockoutTime} minutes.","editedGroupHub.title":"Changes Saved","editedGroupHub.message":"Your group has been updated.","leftGroupHub.title":"Goodbye","leftGroupHub.message":"You are no longer a member of this group and will not receive future updates.","deletedGroupHub.title":"Deleted","deletedGroupHub.message":"The group has been deleted.","groupHubCreated.title":"Group Created","groupHubCreated.message":"{groupHubName} is ready to use","accountClosed.title":"Account Closed","accountClosed.message":"The account has been closed and you will now be redirected to the homepage","resetTokenExpired.title":"Reset Password Link has Expired","resetTokenExpired.message":"Try resetting your password again","invalidUrl.title":"Invalid URL","invalidUrl.message":"The URL you're using is not recognized. Verify your URL and try again.","accountClosedForUser.title":"Account Closed","accountClosedForUser.message":"{userName}'s account is closed","inviteTokenInvalid.title":"Invitation Invalid","inviteTokenInvalid.message":"Your invitation to the community has been canceled or expired.","inviteTokenError.title":"Invitation Verification Failed","inviteTokenError.message":"The url you are utilizing is not recognized. Verify your URL and try again","pageNotFound.title":"Access Denied","pageNotFound.message":"You do not have access to this area of the community or it doesn't exist","eventAttending.title":"Responded as Attending","eventAttending.message":"You'll be notified when there's new activity and reminded as the event approaches","eventInterested.title":"Responded as Interested","eventInterested.message":"You'll be notified when there's new activity and reminded as the event approaches","eventNotFound.title":"Event Not Found","eventNotFound.message":"The event you tried to respond to does not exist.","redirectToRelatedPage.title":"Showing Related Content","redirectToRelatedPageForBaseUsers.title":"Showing Related Content","redirectToRelatedPageForBaseUsers.message":"The content you are trying to access is archived","redirectToRelatedPage.message":"The content you are trying to access is archived","relatedUrl.archivalLink.flyoutMessage":"The content you are trying to access is archived View Archived Content"},"localOverride":false},"CachedAsset:component:custom.widget.GoogleTagTracker-en-us-1744705866656":{"__typename":"CachedAsset","id":"component:custom.widget.GoogleTagTracker-en-us-1744705866656","value":{"component":{"id":"custom.widget.GoogleTagTracker","template":{"id":"GoogleTagTracker","markupLanguage":"HANDLEBARS","style":null,"texts":{},"defaults":{"config":{"applicablePages":[],"description":"Executes Google Tag tracking scripts","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[{"id":"prop_gtag","dataType":"STRING","list":false,"defaultValue":"","label":"Google Tag Manager Id","description":null,"possibleValues":null,"control":"INPUT","__typename":"PropDefinition"}],"__typename":"ComponentProperties"},"components":[{"id":"custom.widget.GoogleTagTracker","form":{"fields":[{"id":"widgetChooser","validation":null,"noValidation":null,"dataType":"STRING","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"title","validation":null,"noValidation":null,"dataType":"STRING","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"useTitle","validation":null,"noValidation":null,"dataType":"BOOLEAN","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"useBackground","validation":null,"noValidation":null,"dataType":"BOOLEAN","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"widgetVisibility","validation":null,"noValidation":null,"dataType":"STRING","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"moreOptions","validation":null,"noValidation":null,"dataType":"STRING","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"cProp_gtag","validation":null,"noValidation":null,"dataType":"STRING","list":false,"control":"INPUT","defaultValue":"","label":"Google Tag Manager Id","description":null,"possibleValues":null,"__typename":"FormField"}],"layout":{"rows":[{"id":"widgetChooserGroup","type":"fieldset","as":null,"items":[{"id":"widgetChooser","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"},{"id":"titleGroup","type":"fieldset","as":null,"items":[{"id":"title","className":null,"__typename":"FormFieldRef"},{"id":"useTitle","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"},{"id":"useBackground","type":"fieldset","as":null,"items":[{"id":"useBackground","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"},{"id":"widgetVisibility","type":"fieldset","as":null,"items":[{"id":"widgetVisibility","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"},{"id":"moreOptionsGroup","type":"fieldset","as":null,"items":[{"id":"moreOptions","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"},{"id":"componentPropsGroup","type":"fieldset","as":null,"items":[{"id":"cProp_gtag","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"}],"actionButtons":null,"className":"custom_widget_GoogleTagTracker_form","formGroupFieldSeparator":"divider","__typename":"FormLayout"},"__typename":"Form"},"config":null,"props":[],"__typename":"Component"}],"grouping":"CUSTOM","__typename":"ComponentTemplate"},"properties":{"config":{"applicablePages":[],"description":"Executes Google Tag tracking scripts","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[{"id":"prop_gtag","dataType":"STRING","list":false,"defaultValue":"","label":"Google Tag Manager Id","description":null,"possibleValues":null,"control":"INPUT","__typename":"PropDefinition"}],"__typename":"ComponentProperties"},"form":{"fields":[{"id":"widgetChooser","validation":null,"noValidation":null,"dataType":"STRING","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"title","validation":null,"noValidation":null,"dataType":"STRING","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"useTitle","validation":null,"noValidation":null,"dataType":"BOOLEAN","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"useBackground","validation":null,"noValidation":null,"dataType":"BOOLEAN","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"widgetVisibility","validation":null,"noValidation":null,"dataType":"STRING","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"moreOptions","validation":null,"noValidation":null,"dataType":"STRING","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"cProp_gtag","validation":null,"noValidation":null,"dataType":"STRING","list":false,"control":"INPUT","defaultValue":"","label":"Google Tag Manager Id","description":null,"possibleValues":null,"__typename":"FormField"}],"layout":{"rows":[{"id":"widgetChooserGroup","type":"fieldset","as":null,"items":[{"id":"widgetChooser","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"},{"id":"titleGroup","type":"fieldset","as":null,"items":[{"id":"title","className":null,"__typename":"FormFieldRef"},{"id":"useTitle","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"},{"id":"useBackground","type":"fieldset","as":null,"items":[{"id":"useBackground","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"},{"id":"widgetVisibility","type":"fieldset","as":null,"items":[{"id":"widgetVisibility","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"},{"id":"moreOptionsGroup","type":"fieldset","as":null,"items":[{"id":"moreOptions","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"},{"id":"componentPropsGroup","type":"fieldset","as":null,"items":[{"id":"cProp_gtag","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"}],"actionButtons":null,"className":"custom_widget_GoogleTagTracker_form","formGroupFieldSeparator":"divider","__typename":"FormLayout"},"__typename":"Form"},"__typename":"Component","localOverride":false},"globalCss":null,"form":{"fields":[{"id":"widgetChooser","validation":null,"noValidation":null,"dataType":"STRING","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"title","validation":null,"noValidation":null,"dataType":"STRING","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"useTitle","validation":null,"noValidation":null,"dataType":"BOOLEAN","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"useBackground","validation":null,"noValidation":null,"dataType":"BOOLEAN","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"widgetVisibility","validation":null,"noValidation":null,"dataType":"STRING","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"moreOptions","validation":null,"noValidation":null,"dataType":"STRING","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"cProp_gtag","validation":null,"noValidation":null,"dataType":"STRING","list":false,"control":"INPUT","defaultValue":"","label":"Google Tag Manager Id","description":null,"possibleValues":null,"__typename":"FormField"}],"layout":{"rows":[{"id":"widgetChooserGroup","type":"fieldset","as":null,"items":[{"id":"widgetChooser","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"},{"id":"titleGroup","type":"fieldset","as":null,"items":[{"id":"title","className":null,"__typename":"FormFieldRef"},{"id":"useTitle","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"},{"id":"useBackground","type":"fieldset","as":null,"items":[{"id":"useBackground","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"},{"id":"widgetVisibility","type":"fieldset","as":null,"items":[{"id":"widgetVisibility","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"},{"id":"moreOptionsGroup","type":"fieldset","as":null,"items":[{"id":"moreOptions","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"},{"id":"componentPropsGroup","type":"fieldset","as":null,"items":[{"id":"cProp_gtag","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"}],"actionButtons":null,"className":"custom_widget_GoogleTagTracker_form","formGroupFieldSeparator":"divider","__typename":"FormLayout"},"__typename":"Form"}},"localOverride":false},"CachedAsset:component:custom.widget.MixPanelTracker-en-us-1744705866656":{"__typename":"CachedAsset","id":"component:custom.widget.MixPanelTracker-en-us-1744705866656","value":{"component":{"id":"custom.widget.MixPanelTracker","template":{"id":"MixPanelTracker","markupLanguage":"HANDLEBARS","style":null,"texts":{},"defaults":{"config":{"applicablePages":[],"description":"Executes MixPanel tracking scripts","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"components":[{"id":"custom.widget.MixPanelTracker","form":null,"config":null,"props":[],"__typename":"Component"}],"grouping":"CUSTOM","__typename":"ComponentTemplate"},"properties":{"config":{"applicablePages":[],"description":"Executes MixPanel tracking scripts","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"form":null,"__typename":"Component","localOverride":false},"globalCss":null,"form":null},"localOverride":false},"CachedAsset:component:custom.widget.custom_Footer-en-us-1744705866656":{"__typename":"CachedAsset","id":"component:custom.widget.custom_Footer-en-us-1744705866656","value":{"component":{"id":"custom.widget.custom_Footer","template":{"id":"custom_Footer","markupLanguage":"HTML","style":null,"texts":{},"defaults":{"config":{"applicablePages":[],"description":"footer links and copy write text","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"components":[{"id":"custom.widget.custom_Footer","form":null,"config":null,"props":[],"__typename":"Component"}],"grouping":"TEXTHTML","__typename":"ComponentTemplate"},"properties":{"config":{"applicablePages":[],"description":"footer links and copy write text","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"form":null,"__typename":"Component","localOverride":false},"globalCss":null,"form":null},"localOverride":false},"CachedAsset:text:en_US-components/community/Navbar-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/community/Navbar-1739990369000","value":{"community":"Community Home","inbox":"Inbox","manageContent":"Manage Content","tos":"Terms of Service","forgotPassword":"Forgot Password","themeEditor":"Theme Editor","edit":"Edit Navigation Bar","skipContent":"Skip to content","external-1":" My Email","external-10":"child 1","mucxz84639":"Home","about-community":"About the Community","external":"Test","external-9":"Bill History","external-8":"Bill Summary","external-7":"Pay Now","mucxz84639-1":"Billing","external-6":"Alerts","external-5":"Service Repair Order","external-4":"My Services & Plan","external-3":"Manage Username / Logins","external-2":"My Information"},"localOverride":false},"CachedAsset:text:en_US-components/community/NavbarHamburgerDropdown-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/community/NavbarHamburgerDropdown-1739990369000","value":{"hamburgerLabel":"Side Menu"},"localOverride":false},"CachedAsset:text:en_US-components/community/BrandLogo-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/community/BrandLogo-1739990369000","value":{"logoAlt":"Khoros","themeLogoAlt":"Brand Logo"},"localOverride":false},"CachedAsset:text:en_US-components/community/NavbarTextLinks-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/community/NavbarTextLinks-1739990369000","value":{"more":"More"},"localOverride":false},"CachedAsset:text:en_US-components/search/SpotlightSearchIcon-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/search/SpotlightSearchIcon-1739990369000","value":{"search":"Search"},"localOverride":false},"CachedAsset:text:en_US-components/authentication/AuthenticationLink-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/authentication/AuthenticationLink-1739990369000","value":{"title.login":"Sign In","title.registration":"Register","title.forgotPassword":"Forgot Password","title.multiAuthLogin":"Sign In"},"localOverride":false},"CachedAsset:text:en_US-components/community/Breadcrumb-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/community/Breadcrumb-1739990369000","value":{"navLabel":"Breadcrumbs","dropdown":"Additional parent page navigation"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageBanner-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageBanner-1739990369000","value":{"messageMarkedAsSpam":"This post has been marked as spam","messageMarkedAsSpam@board:TKB":"This article has been marked as spam","messageMarkedAsSpam@board:BLOG":"This post has been marked as spam","messageMarkedAsSpam@board:FORUM":"This discussion has been marked as spam","messageMarkedAsSpam@board:OCCASION":"This event has been marked as spam","messageMarkedAsSpam@board:IDEA":"This idea has been marked as spam","manageSpam":"Manage Spam","messageMarkedAsAbuse":"This post has been marked as abuse","messageMarkedAsAbuse@board:TKB":"This article has been marked as abuse","messageMarkedAsAbuse@board:BLOG":"This post has been marked as abuse","messageMarkedAsAbuse@board:FORUM":"This discussion has been marked as abuse","messageMarkedAsAbuse@board:OCCASION":"This event has been marked as abuse","messageMarkedAsAbuse@board:IDEA":"This idea has been marked as abuse","preModCommentAuthorText":"This comment will be published as soon as it is approved","preModCommentModeratorText":"This comment is awaiting moderation","messageMarkedAsOther":"This post has been rejected due to other reasons","messageMarkedAsOther@board:TKB":"This article has been rejected due to other reasons","messageMarkedAsOther@board:BLOG":"This post has been rejected due to other reasons","messageMarkedAsOther@board:FORUM":"This discussion has been rejected due to other reasons","messageMarkedAsOther@board:OCCASION":"This event has been rejected due to other reasons","messageMarkedAsOther@board:IDEA":"This idea has been rejected due to other reasons","messageArchived":"This post was archived on {date}","relatedUrl":"View Related Content","relatedContentText":"Showing related content","archivedContentLink":"View Archived Content"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageView/MessageViewStandard-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageView/MessageViewStandard-1739990369000","value":{"anonymous":"Anonymous","author":"{messageAuthorLogin}","authorBy":"{messageAuthorLogin}","board":"{messageBoardTitle}","replyToUser":" to {parentAuthor}","showMoreReplies":"Show More","replyText":"Reply","repliesText":"Replies","markedAsSolved":"Marked as Solution","movedMessagePlaceholder.BLOG":"{count, plural, =0 {This comment has been} other {These comments have been} }","movedMessagePlaceholder.TKB":"{count, plural, =0 {This comment has been} other {These comments have been} }","movedMessagePlaceholder.FORUM":"{count, plural, =0 {This reply has been} other {These replies have been} }","movedMessagePlaceholder.IDEA":"{count, plural, =0 {This comment has been} other {These comments have been} }","movedMessagePlaceholder.OCCASION":"{count, plural, =0 {This comment has been} other {These comments have been} }","movedMessagePlaceholderUrlText":"moved.","messageStatus":"Status: ","statusChanged":"Status changed: {previousStatus} to {currentStatus}","statusAdded":"Status added: {status}","statusRemoved":"Status removed: {status}","labelExpand":"expand replies","labelCollapse":"collapse replies","unhelpfulReason.reason1":"Content is outdated","unhelpfulReason.reason2":"Article is missing information","unhelpfulReason.reason3":"Content is for a different Product","unhelpfulReason.reason4":"Doesn't match what I was searching for"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageDeepLink-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageDeepLink-1739990369000","value":{"viewFullDiscussion@board:FORUM":"View Full Discussion ({repliesCount} Replies)","viewFullDiscussion@board:BLOG":"View Full Discussion ({repliesCount} Comments)","viewFullDiscussion@board:TKB":"View Full Discussion ({repliesCount} Comments)","viewFullDiscussion@board:IDEA":"View Full Discussion ({repliesCount} Comments)","viewFullDiscussion@board:OCCASION":"View Full Discussion ({repliesCount} Comments)","showParents@board:FORUM":"Show Parent Replies","showParents@board:BLOG":"Show Parent Comments","showParents@board:TKB":"Show Parent Comments","showParents@board:IDEA":"Show Parent Comments","showParents@board:OCCASION":"Show Parent Comments"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageReplyCallToAction-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageReplyCallToAction-1739990369000","value":{"leaveReply":"Leave a reply...","leaveReply@board:BLOG@message:root":"Leave a comment...","leaveReply@board:TKB@message:root":"Leave a comment...","leaveReply@board:IDEA@message:root":"Leave a comment...","leaveReply@board:OCCASION@message:root":"Leave a comment...","repliesTurnedOff.FORUM":"Replies are turned off for this topic","repliesTurnedOff.BLOG":"Comments are turned off for this topic","repliesTurnedOff.TKB":"Comments are turned off for this topic","repliesTurnedOff.IDEA":"Comments are turned off for this topic","repliesTurnedOff.OCCASION":"Comments are turned off for this topic","infoText":"Stop poking me!"},"localOverride":false},"CachedAsset:text:en_US-components/messages/RelatedContentWidget-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/RelatedContentWidget-1739990369000","value":{"title":"Related Content","emptyDescription":"No content to show"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageListForNodeByRecentActivityWidget-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageListForNodeByRecentActivityWidget-1739990369000","value":{"title@userScope:other":"Recent Content","title@userScope:self":"Contributions","title@board:FORUM@userScope:other":"Recent Discussions","title@board:BLOG@userScope:other":"Recent Blogs","emptyDescription":"No content to show","MessageListForNodeByRecentActivityWidgetEditor.nodeScope.label":"Scope","title@instance:1722231399124":"Latest Posts","title@instance:1722321652654":"Recent Content","title@instance:1721715590817":"Latest Posts","title@instance:1722251112371":"Latest Posts"},"localOverride":false},"Conversation:conversation:143700":{"__typename":"Conversation","id":"conversation:143700","topic":{"__typename":"ForumTopicMessage","uid":143700},"lastPostingActivityTime":"2025-04-09T16:07:16.099-04:00","solved":false},"ForumTopicMessage:message:143700":{"__typename":"ForumTopicMessage","subject":"Telephone service","conversation":{"__ref":"Conversation:conversation:143700"},"id":"message:143700","revisionNum":1,"uid":143700,"depth":0,"board":{"__ref":"Forum:board:TechSupport"},"author":{"__typename":"User","uid":141779,"login":"flhseabolt","registrationData":{"__typename":"RegistrationData","status":null},"deleted":false,"avatar":{"__typename":"UserAvatar","url":"https://community.hughesnet.com/t5/s/ssqng67387/m_assets/avatars/default/avatar-12.svg?time=0"}},"metrics":{"__typename":"MessageMetrics","views":44},"postTime":"2025-04-09T08:39:22.344-04:00","lastPublishTime":"2025-04-09T08:39:22.344-04:00","readOnly":false},"Conversation:conversation:143672":{"__typename":"Conversation","id":"conversation:143672","topic":{"__typename":"ForumTopicMessage","uid":143672},"lastPostingActivityTime":"2025-04-01T22:47:41.423-04:00","solved":false},"ForumTopicMessage:message:143672":{"__typename":"ForumTopicMessage","subject":"Can't access modem control center","conversation":{"__ref":"Conversation:conversation:143672"},"id":"message:143672","revisionNum":1,"uid":143672,"depth":0,"board":{"__ref":"Forum:board:TechSupport"},"author":{"__typename":"User","uid":146698,"login":"basd","registrationData":{"__typename":"RegistrationData","status":null},"deleted":false,"avatar":{"__typename":"UserAvatar","url":"https://community.hughesnet.com/t5/s/ssqng67387/m_assets/avatars/default/avatar-4.svg?time=0"}},"metrics":{"__typename":"MessageMetrics","views":207},"postTime":"2025-03-18T16:01:46.778-04:00","lastPublishTime":"2025-03-18T16:01:46.778-04:00","readOnly":false},"Conversation:conversation:143642":{"__typename":"Conversation","id":"conversation:143642","topic":{"__typename":"ForumTopicMessage","uid":143642},"lastPostingActivityTime":"2025-03-30T19:14:32.898-04:00","solved":false},"ForumTopicMessage:message:143642":{"__typename":"ForumTopicMessage","subject":"Need to cancel with no ETF","conversation":{"__ref":"Conversation:conversation:143642"},"id":"message:143642","revisionNum":1,"uid":143642,"depth":0,"board":{"__ref":"Forum:board:TechSupport"},"author":{"__typename":"User","uid":148550,"login":"EricN","registrationData":{"__typename":"RegistrationData","status":null},"deleted":false,"avatar":{"__typename":"UserAvatar","url":"https://community.hughesnet.com/t5/s/ssqng67387/m_assets/avatars/default/avatar-8.svg?time=0"}},"metrics":{"__typename":"MessageMetrics","views":173},"postTime":"2025-02-26T14:16:50.813-05:00","lastPublishTime":"2025-02-26T14:16:50.813-05:00","readOnly":false},"Conversation:conversation:143679":{"__typename":"Conversation","id":"conversation:143679","topic":{"__typename":"ForumTopicMessage","uid":143679},"lastPostingActivityTime":"2025-03-25T18:34:59.637-04:00","solved":false},"ForumTopicMessage:message:143679":{"__typename":"ForumTopicMessage","subject":"Caller ID","conversation":{"__ref":"Conversation:conversation:143679"},"id":"message:143679","revisionNum":1,"uid":143679,"depth":0,"board":{"__ref":"Forum:board:TechSupport"},"author":{"__typename":"User","uid":91109,"login":"higgdog","registrationData":{"__typename":"RegistrationData","status":null},"deleted":false,"avatar":{"__typename":"UserAvatar","url":"https://community.hughesnet.com/t5/s/ssqng67387/m_assets/avatars/default/avatar-10.svg?time=0"}},"metrics":{"__typename":"MessageMetrics","views":37},"postTime":"2025-03-25T18:18:12.164-04:00","lastPublishTime":"2025-03-25T18:18:12.164-04:00","readOnly":true},"Conversation:conversation:143675":{"__typename":"Conversation","id":"conversation:143675","topic":{"__typename":"ForumTopicMessage","uid":143675},"lastPostingActivityTime":"2025-03-21T20:10:26.729-04:00","solved":false},"ForumTopicMessage:message:143675":{"__typename":"ForumTopicMessage","subject":"WPS Pin","conversation":{"__ref":"Conversation:conversation:143675"},"id":"message:143675","revisionNum":1,"uid":143675,"depth":0,"board":{"__ref":"Forum:board:TechSupport"},"author":{"__typename":"User","uid":152752,"login":"thomas444","registrationData":{"__typename":"RegistrationData","status":null},"deleted":false,"avatar":{"__typename":"UserAvatar","url":"https://community.hughesnet.com/t5/s/ssqng67387/m_assets/avatars/default/avatar-3.svg?time=0"}},"metrics":{"__typename":"MessageMetrics","views":53},"postTime":"2025-03-21T13:23:44.946-04:00","lastPublishTime":"2025-03-21T13:23:44.946-04:00","readOnly":false},"Rank:rank:20":{"__typename":"Rank","id":"rank:20","position":21,"name":"Sophomore","color":"00CC00","icon":null,"rankStyle":"TEXT"},"User:user:151963":{"__typename":"User","id":"user:151963","uid":151963,"login":"AmandaB1234","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2025-01-30T23:43:44.740-05:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.hughesnet.com/t5/s/ssqng67387/m_assets/avatars/default/avatar-10.svg?time=0"},"rank":{"__ref":"Rank:rank:20"},"messagesCount":29,"kudosGivenCount":10,"kudosReceivedCount":9,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount":1,"entityType":"USER","eventPath":"community:ssqng67387/user:151963"},"AssociatedImage:{\"url\":\"https://community.hughesnet.com/t5/s/ssqng67387/images/bi0xMS1qUHA3ZXA?image-coordinates=0%2C0%2C130%2C130\"}":{"__typename":"AssociatedImage","url":"https://community.hughesnet.com/t5/s/ssqng67387/images/bi0xMS1qUHA3ZXA?image-coordinates=0%2C0%2C130%2C130","mimeType":"image/png"},"ForumTopicMessage:message:143530":{"__typename":"ForumTopicMessage","uid":143530,"subject":"Horrid speed and connection issues","id":"message:143530","revisionNum":1,"repliesCount":15,"author":{"__ref":"User:user:151963"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:TechSupport"},"conversation":{"__ref":"Conversation:conversation:143530"},"moderationData":{"__ref":"ModerationData:moderation_data:143530"},"postTime":"2025-02-02T20:09:59.997-05:00","lastPublishTime":"2025-02-02T20:09:59.997-05:00","readOnly":false,"metrics":{"__typename":"MessageMetrics","views":794},"placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"entityType":"FORUM_TOPIC","eventPath":"category:HNSupport/community:ssqng67387board:TechSupport/message:143530"},"Conversation:conversation:143530":{"__typename":"Conversation","id":"conversation:143530","solved":true,"topic":{"__ref":"ForumTopicMessage:message:143530"},"lastPostingActivityTime":"2025-02-16T20:11:49.909-05:00","lastPostTime":"2025-02-16T20:11:49.909-05:00"},"ModerationData:moderation_data:143530":{"__typename":"ModerationData","id":"moderation_data:143530","status":"APPROVED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:143530":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:143530","relatedMessage":{"__ref":"ForumTopicMessage:message:143530"}},"ForumTopicMessage:message:143475":{"__typename":"ForumTopicMessage","uid":143475,"subject":"Speed issues since Day 1","id":"message:143475","revisionNum":1,"repliesCount":33,"author":{"__ref":"User:user:151963"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:TechSupport"},"conversation":{"__ref":"Conversation:conversation:143475"},"moderationData":{"__ref":"ModerationData:moderation_data:143475"},"postTime":"2025-01-31T09:23:54.971-05:00","lastPublishTime":"2025-01-31T09:23:54.971-05:00","readOnly":false,"metrics":{"__typename":"MessageMetrics","views":696},"placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"entityType":"FORUM_TOPIC","eventPath":"category:HNSupport/community:ssqng67387board:TechSupport/message:143475"},"Conversation:conversation:143475":{"__typename":"Conversation","id":"conversation:143475","solved":true,"topic":{"__ref":"ForumTopicMessage:message:143475"},"lastPostingActivityTime":"2025-02-01T07:50:34.176-05:00","lastPostTime":"2025-02-01T07:50:34.176-05:00"},"ModerationData:moderation_data:143475":{"__typename":"ModerationData","id":"moderation_data:143475","status":"APPROVED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:143475":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:143475","relatedMessage":{"__ref":"ForumTopicMessage:message:143475"}},"User:user:47156":{"__typename":"User","id":"user:47156","uid":47156,"login":"Danny89","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2017-10-01T10:05:39.356-04:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.hughesnet.com/t5/s/ssqng67387/m_assets/avatars/default/avatar-9.svg?time=0"},"rank":{"__ref":"Rank:rank:19"},"messagesCount":50,"kudosGivenCount":22,"kudosReceivedCount":4,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount":0,"entityType":"USER","eventPath":"community:ssqng67387/user:47156"},"ForumTopicMessage:message:134459":{"__typename":"ForumTopicMessage","uid":134459,"subject":"Severe speed issues, is there an issue at Hughes?","id":"message:134459","revisionNum":3,"repliesCount":24,"author":{"__ref":"User:user:47156"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:TechSupport"},"conversation":{"__ref":"Conversation:conversation:134459"},"moderationData":{"__ref":"ModerationData:moderation_data:134459"},"postTime":"2021-08-14T03:41:18.846-04:00","lastPublishTime":"2021-08-16T10:29:27.402-04:00","readOnly":true,"metrics":{"__typename":"MessageMetrics","views":11431},"placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"entityType":"FORUM_TOPIC","eventPath":"category:HNSupport/community:ssqng67387board:TechSupport/message:134459"},"Conversation:conversation:134459":{"__typename":"Conversation","id":"conversation:134459","solved":true,"topic":{"__ref":"ForumTopicMessage:message:134459"},"lastPostingActivityTime":"2021-08-25T09:24:20.670-04:00","lastPostTime":"2021-08-25T09:24:20.670-04:00"},"ModerationData:moderation_data:134459":{"__typename":"ModerationData","id":"moderation_data:134459","status":"APPROVED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:134459":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:134459","relatedMessage":{"__ref":"ForumTopicMessage:message:134459"}},"ForumTopicMessage:message:136142":{"__typename":"ForumTopicMessage","uid":136142,"subject":"Gettin those Severe Speed Issues Again, and Web Acceleration is not supported?","id":"message:136142","revisionNum":1,"repliesCount":22,"author":{"__ref":"User:user:47156"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:TechSupport"},"conversation":{"__ref":"Conversation:conversation:136142"},"moderationData":{"__ref":"ModerationData:moderation_data:136142"},"postTime":"2021-12-16T02:16:14.463-05:00","lastPublishTime":"2021-12-16T02:16:14.463-05:00","readOnly":true,"metrics":{"__typename":"MessageMetrics","views":10084},"placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"entityType":"FORUM_TOPIC","eventPath":"category:HNSupport/community:ssqng67387board:TechSupport/message:136142"},"Conversation:conversation:136142":{"__typename":"Conversation","id":"conversation:136142","solved":true,"topic":{"__ref":"ForumTopicMessage:message:136142"},"lastPostingActivityTime":"2021-12-22T11:43:29.091-05:00","lastPostTime":"2021-12-22T11:43:29.091-05:00"},"ModerationData:moderation_data:136142":{"__typename":"ModerationData","id":"moderation_data:136142","status":"APPROVED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:136142":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:136142","relatedMessage":{"__ref":"ForumTopicMessage:message:136142"}},"Rank:rank:17":{"__typename":"Rank","id":"rank:17","position":18,"name":"Tutor","color":"0096FA","icon":null,"rankStyle":"TEXT"},"User:user:44636":{"__typename":"User","id":"user:44636","uid":44636,"login":"kitnbob","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2017-08-18T11:54:16.794-04:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.hughesnet.com/t5/s/ssqng67387/m_assets/avatars/default/avatar-7.svg?time=0"},"rank":{"__ref":"Rank:rank:17"},"messagesCount":214,"kudosGivenCount":28,"kudosReceivedCount":49,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount":0,"entityType":"USER","eventPath":"community:ssqng67387/user:44636"},"ForumTopicMessage:message:137472":{"__typename":"ForumTopicMessage","uid":137472,"subject":"connection issues","id":"message:137472","revisionNum":1,"repliesCount":4,"author":{"__ref":"User:user:44636"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:TechSupport"},"conversation":{"__ref":"Conversation:conversation:137472"},"moderationData":{"__ref":"ModerationData:moderation_data:137472"},"postTime":"2022-05-01T14:14:07.485-04:00","lastPublishTime":"2022-05-01T14:14:07.485-04:00","readOnly":true,"metrics":{"__typename":"MessageMetrics","views":2880},"placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"entityType":"FORUM_TOPIC","eventPath":"category:HNSupport/community:ssqng67387board:TechSupport/message:137472"},"Conversation:conversation:137472":{"__typename":"Conversation","id":"conversation:137472","solved":true,"topic":{"__ref":"ForumTopicMessage:message:137472"},"lastPostingActivityTime":"2022-05-01T15:48:43.915-04:00","lastPostTime":"2022-05-01T15:48:43.915-04:00"},"ModerationData:moderation_data:137472":{"__typename":"ModerationData","id":"moderation_data:137472","status":"APPROVED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:137472":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:137472","relatedMessage":{"__ref":"ForumTopicMessage:message:137472"}},"QueryVariables:MessageSolutions":{"__typename":"QueryVariables","id":"MessageSolutions","value":{"first":10,"constraints":{"topicId":{"eq":"message:128262"},"solution":{"eq":true}},"sorts":{"postTime":{"direction":"ASC"}},"useAvatar":true,"useAuthorLogin":true,"useAuthorRank":false,"useBody":true,"useKudosCount":false,"useTimeToRead":false,"useMedia":true,"useRepliesCount":false,"useSearchSnippet":false,"useAcceptedSolutionButton":true,"useSolvedBadge":false,"useAttachments":true,"useTags":false,"useUserHoverCard":false,"useNodeHoverCard":false,"usePreviewSubjectModal":false,"useMessageStatus":false}},"ROOT_MUTATION":{"__typename":"Mutation"},"CachedAsset:text:en_US-components/nodes/NodeLink-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/nodes/NodeLink-1739990369000","value":{"place":"Place {name}"},"localOverride":false},"CachedAsset:text:en_US-components/messages/EscalatedMessageBanner-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/EscalatedMessageBanner-1739990369000","value":{"escalationMessage":"Escalated to Salesforce by {username} on {date}","viewDetails":"View Details","modalTitle":"Case Details","escalatedBy":"Escalated by: ","escalatedOn":"Escalated on: ","caseNumber":"Case Number: ","status":"Status: ","lastUpdateDate":"Last Update: ","automaticEscalation":"automatic escalation","anonymous":"Anonymous"},"localOverride":false},"CachedAsset:text:en_US-components/users/UserLink-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/users/UserLink-1739990369000","value":{"authorName":"View Profile: {author}","anonymous":"Anonymous"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/users/UserRank-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/users/UserRank-1739990369000","value":{"rankName":"{rankName}","userRank":"Author rank {rankName}"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageTime-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageTime-1739990369000","value":{"postTime":"Published: {time}","lastPublishTime":"Last Update: {time}","conversation.lastPostingActivityTime":"Last posting activity time: {time}","conversation.lastPostTime":"Last post time: {time}","moderationData.rejectTime":"Rejected time: {time}"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageSolvedBadge-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageSolvedBadge-1739990369000","value":{"solved":"Solved"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageSubject-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageSubject-1739990369000","value":{"noSubject":"(no subject)"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageBody-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageBody-1739990369000","value":{"showMessageBody":"Show More","mentionsErrorTitle":"{mentionsType, select, board {Board} user {User} message {Message} other {}} No Longer Available","mentionsErrorMessage":"The {mentionsType} you are trying to view has been removed from the community.","videoProcessing":"Video is being processed. Please try again in a few minutes.","bannerTitle":"Video provider requires cookies to play the video. Accept to continue or {url} it directly on the provider's site.","buttonTitle":"Accept","urlText":"watch"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageCustomFields-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageCustomFields-1739990369000","value":{"CustomField.default.label":"Value of {name}"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/common/QueryHandler-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/common/QueryHandler-1739990369000","value":{"title":"Query Handler"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageReplyButton-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageReplyButton-1739990369000","value":{"repliesCount":"{count}","title":"Reply","title@board:BLOG@message:root":"Comment","title@board:TKB@message:root":"Comment","title@board:IDEA@message:root":"Comment","title@board:OCCASION@message:root":"Comment"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageSolutionList-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageSolutionList-1739990369000","value":{"emptyDescription":"No has been message solutions yet"},"localOverride":false},"ModerationData:moderation_data:128615":{"__typename":"ModerationData","id":"moderation_data:128615","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ModerationData:moderation_data:128611":{"__typename":"ModerationData","id":"moderation_data:128611","status":"APPROVED","rejectReason":null},"User:user:21490":{"__typename":"User","id":"user:21490","login":"maratsade","uid":21490,"deleted":false,"avatar":{"__typename":"UserAvatar","url":"https://community.hughesnet.com/t5/s/ssqng67387/images/dS0yMTQ5MC04aTNCQUJDNDExNzNEOTlEOUE"},"rank":{"__ref":"Rank:rank:5"},"email":"","messagesCount":8748,"biography":null,"topicsCount":148,"kudosReceivedCount":4121,"kudosGivenCount":3496,"kudosWeight":1,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2015-06-05T03:00:00.000-04:00","confirmEmailStatus":null},"followersCount":null,"solutionsCount":168,"entityType":"USER","eventPath":"community:ssqng67387/user:21490"},"Rank:rank:5":{"__typename":"Rank","id":"rank:5","position":6,"name":"Distinguished Professor IV","color":"0000FF","icon":null,"rankStyle":"TEXT"},"ForumReplyMessage:message:128611":{"__typename":"ForumReplyMessage","id":"message:128611","revisionNum":2,"uid":128611,"depth":34,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:TechSupport"},"conversation":{"__ref":"Conversation:conversation:128262"},"subject":"Re: Speed issues, can't stay on chat for Help","readOnly":true,"editFrozen":false,"moderationData":{"__ref":"ModerationData:moderation_data:128611"},"body":"
They do not respond to unsolicited PMs.
What she is probably waiting for is for you to run the required tests the required way. Right now, the file sizes are incorrect; they need to be 25MB for download tests and 4MB for upload tests.
Don't expect a reply until you have run the tests the right way, as explained here. You may want to focus your efforts on getting the troubleshooting and testing right.
For immediate responses, there's chat and phone customer service, but you've been through that and it hasn't worked for you, so stay here, run the tests the way they're supposed to, and wait for a response, which may be next week if you've done the required testing as required.
bronccat wrote:
I DM Liz as I am not sure how to get her attention?
","body@stringLength":"1431","rawBody":"
","author":{"__ref":"User:user:21490"},"isEscalated":null,"postTime":"2020-10-25T11:53:35.811-04:00","solution":false,"customFields":[],"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}}},"Revision:revision:128615_1":{"__typename":"Revision","id":"revision:128615_1","lastEditTime":"2020-10-25T13:17:31.480-04:00"},"User:user:16464":{"__typename":"User","id":"user:16464","uid":16464,"login":"Liz","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2014-02-18T03:00:00.000-05:00"},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.hughesnet.com/t5/s/ssqng67387/images/dS0xNjQ2NC01NzY0aTFGM0ZBNEE1NTJDMjc1Rjg"},"entityType":"USER","eventPath":"community:ssqng67387/user:16464","rank":{"__ref":"Rank:rank:2"}},"ForumReplyMessage:message:128894":{"__typename":"ForumReplyMessage","uid":128894,"id":"message:128894","revisionNum":1,"author":{"__ref":"User:user:116956"},"readOnly":true},"ModerationData:moderation_data:128915":{"__typename":"ModerationData","id":"moderation_data:128915","status":"APPROVED","rejectReason":null},"AcceptedSolutionMessage:message:128915":{"__typename":"AcceptedSolutionMessage","author":{"__ref":"User:user:16464"},"id":"message:128915","revisionNum":1,"uid":128915,"depth":69,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:TechSupport"},"parent":{"__ref":"ForumReplyMessage:message:128894"},"conversation":{"__ref":"Conversation:conversation:128262"},"subject":"Re: Speed issues, can't stay on chat for Help","moderationData":{"__ref":"ModerationData:moderation_data:128915"},"body":"
Hi bronccat,
\n\n
\n\n
\n\n
\n\n
\n\n
\n\n
","body@stripHtml({\"removeProcessingText\":true,\"removeSpoilerMarkup\":true,\"removeTocMarkup\":true,\"truncateLength\":200})@stringLength":"213","postTime":"2020-11-03T16:35:05.927-05:00","lastPublishTime":"2020-11-03T16:35:05.927-05:00","images":{"__typename":"AssociatedImageConnection","edges":[],"totalCount":0,"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"attachments":{"__typename":"AttachmentConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"solution":true,"metrics":{"__typename":"MessageMetrics","views":39348},"placeholder":false,"originalMessageForPlaceholder":null,"videos":{"__typename":"VideoConnection","edges":[],"totalCount":0,"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"isEscalated":null,"entityType":"FORUM_REPLY","eventPath":"category:HNSupport/community:ssqng67387board:TechSupport/message:128262/message:128915","customFields":[]},"QueryVariables:ReplyList:message:128615:1":{"__typename":"QueryVariables","id":"ReplyList:message:128615:1","value":{"id":"message:128615","sorts":{"postTime":{"direction":"ASC"}},"useAvatar":true,"useAuthorLogin":true,"useAuthorRank":true,"useBody":true,"useKudosCount":true,"useTimeToRead":false,"useMedia":false,"useReadOnlyIcon":false,"useRepliesCount":false,"useSearchSnippet":false,"useAcceptedSolutionButton":true,"useSolvedBadge":false,"useAttachments":false,"attachmentsFirst":5,"useTags":false,"useNodeAncestors":false,"useUserHoverCard":false,"useNodeHoverCard":false,"useModerationStatus":true,"usePreviewSubjectModal":false,"useMessageStatus":true}},"CachedAsset:text:en_US-shared/client/components/users/UserAvatar-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/users/UserAvatar-1739990369000","value":{"altText":"{login}'s avatar","altTextGeneric":"User's avatar"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/ranks/UserRankLabel-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/ranks/UserRankLabel-1739990369000","value":{"altTitle":"Icon for {rankName} rank"},"localOverride":false},"CachedAsset:text:en_US-components/tags/TagView/TagViewChip-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/tags/TagView/TagViewChip-1739990369000","value":{"tagLabelName":"Tag name {tagName}"},"localOverride":false},"CachedAsset:text:en_US-components/messages/AcceptedSolutionButton-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/AcceptedSolutionButton-1739990369000","value":{"accept":"Mark as Solution","accepted":"Marked as Solution","errorHeader":"Error!","errorAdd":"There was an error marking as solution.","errorRemove":"There was an error unmarking as solution.","solved":"Solved","topicAlreadySolvedErrorTitle":"Solution Already Exists","topicAlreadySolvedErrorDesc":"Refresh the browser to view the existing solution"},"localOverride":false},"CachedAsset:text:en_US-components/messages/LinearReplyList-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/LinearReplyList-1739990369000","value":{"title":"{count, plural, one{# Reply} other{# Replies}}","title@board:BLOG":"{count, plural, one{# Comment} other{# Comments}}","title@board:TKB":"{count, plural, one{# Comment} other{# Comments}}","title@board:IDEA":"{count, plural, one{# Comment} other{# Comments}}","title@board:OCCASION":"{count, plural, one{# Comment} other{# Comments}}","noRepliesTitle":"No Replies","noRepliesTitle@board:BLOG":"No Comments","noRepliesTitle@board:TKB":"No Comments","noRepliesTitle@board:IDEA":"No Comments","noRepliesTitle@board:OCCASION":"No Comments","noRepliesDescription":"Be the first to reply","noRepliesDescription@board:BLOG":"Be the first to comment","noRepliesDescription@board:TKB":"Be the first to comment","noRepliesDescription@board:OCCASION":"Be the first to comment","noRepliesDescription@board:IDEA":"Be the first to comment","messageReadOnlyAlert:BLOG":"Comments have been turned off for this post","messageReadOnlyAlert:TKB":"Comments have been turned off for this article","messageReadOnlyAlert:IDEA":"Comments have been turned off for this idea","messageReadOnlyAlert:FORUM":"Replies have been turned off for this discussion","messageReadOnlyAlert:OCCASION":"Comments have been turned off for this event"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageView/MessageViewInline-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageView/MessageViewInline-1739990369000","value":{"bylineAuthor":"{bylineAuthor}","bylineBoard":"{bylineBoard}","anonymous":"Anonymous","place":"Place {bylineBoard}","gotoParent":"Go to parent {name}"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/common/Pager/PagerLoadMore-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/common/Pager/PagerLoadMore-1739990369000","value":{"loadMore":"Show More"},"localOverride":false},"CachedAsset:text:en_US-components/customComponent/CustomComponent-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/customComponent/CustomComponent-1739990369000","value":{"errorMessage":"Error rendering component id: {customComponentId}","bannerTitle":"Video provider requires cookies to play the video. Accept to continue or {url} it directly on the provider's site.","buttonTitle":"Accept","urlText":"watch"},"localOverride":false},"ModerationData:moderation_data:128616":{"__typename":"ModerationData","id":"moderation_data:128616","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:128616":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:116956"},"id":"message:128616","revisionNum":1,"uid":128616,"depth":36,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:TechSupport"},"parent":{"__ref":"ForumReplyMessage:message:128615"},"conversation":{"__ref":"Conversation:conversation:128262"},"subject":"Re: Speed issues, can't stay on chat for Help","moderationData":{"__ref":"ModerationData:moderation_data:128616"},"body":"
MrBuster I'm not using auto - I was running smaller tests before I was hooked to ehternet. Since 1143 (or whenever) I have been running 25 DL and 4 UL.
","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"175","kudosSumWeight":1,"postTime":"2020-10-25T13:20:21.450-04:00","lastPublishTime":"2020-10-25T13:20:21.450-04:00","metrics":{"__typename":"MessageMetrics","views":8166},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"category:HNSupport/community:ssqng67387board:TechSupport/message:128262/message:128616","repliesCount":2,"readOnly":true,"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"customFields":[]},"ModerationData:moderation_data:128617":{"__typename":"ModerationData","id":"moderation_data:128617","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:128617":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:21490"},"id":"message:128617","revisionNum":1,"uid":128617,"depth":36,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:TechSupport"},"parent":{"__ref":"ForumReplyMessage:message:128615"},"conversation":{"__ref":"Conversation:conversation:128262"},"subject":"Re: Speed issues, can't stay on chat for Help","moderationData":{"__ref":"ModerationData:moderation_data:128617"},"body":"
She will know because she will check the URL to your results list. And because she's an all powerful, all seeing entity. Or a magical pixie. HN neither confirms nor denies.
My question is - and not to be a smart**bleep** - but how will she magically know that I have run the tests \"correctly\" and know I am now worthy of a response?
OK, maybe I'm being a little smart**bleep**ed.
","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"233","kudosSumWeight":1,"postTime":"2020-10-25T13:34:04.726-04:00","lastPublishTime":"2020-10-25T13:34:04.726-04:00","metrics":{"__typename":"MessageMetrics","views":8144},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"category:HNSupport/community:ssqng67387board:TechSupport/message:128262/message:128617","repliesCount":64,"readOnly":true,"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"customFields":[]},"Rank:rank:18":{"__typename":"Rank","id":"rank:18","position":19,"name":"Senior","color":"006600","icon":null,"rankStyle":"TEXT"},"User:user:71041":{"__typename":"User","id":"user:71041","uid":71041,"login":"MrBuster","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2018-09-03T09:41:52.634-04:00"},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.hughesnet.com/t5/s/ssqng67387/images/dS03MTA0MS0zODY0aUFERTYxQjRDRjBDNzYzM0E"},"rank":{"__ref":"Rank:rank:18"},"entityType":"USER","eventPath":"community:ssqng67387/user:71041"},"ModerationData:moderation_data:128619":{"__typename":"ModerationData","id":"moderation_data:128619","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:128619":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:71041"},"id":"message:128619","revisionNum":2,"uid":128619,"depth":37,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:TechSupport"},"parent":{"__ref":"ForumReplyMessage:message:128616"},"conversation":{"__ref":"Conversation:conversation:128262"},"subject":"Re: Speed issues, can't stay on chat for Help","moderationData":{"__ref":"ModerationData:moderation_data:128619"},"body":"
You can use that '@' sign like you did for me to notify folks -- also, she will probably check this thread this thread again on Monday.
I think maratsade just responding about the smaller tests that were recent, so I was not sure if maybe testmy was backing your size down. I think she will have what she wants with a good batch of these tests.
edit: I see maratsade responded before I was done typing....
","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"208","kudosSumWeight":0,"postTime":"2020-10-25T13:36:29.541-04:00","lastPublishTime":"2020-10-25T13:38:07.105-04:00","metrics":{"__typename":"MessageMetrics","views":8157},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"category:HNSupport/community:ssqng67387board:TechSupport/message:128262/message:128619","repliesCount":1,"readOnly":true,"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"customFields":[]},"ModerationData:moderation_data:128621":{"__typename":"ModerationData","id":"moderation_data:128621","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:128621":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:21490"},"id":"message:128621","revisionNum":1,"uid":128621,"depth":38,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:TechSupport"},"parent":{"__ref":"ForumReplyMessage:message:128619"},"conversation":{"__ref":"Conversation:conversation:128262"},"subject":"Re: Speed issues, can't stay on chat for Help","moderationData":{"__ref":"ModerationData:moderation_data:128621"},"body":"
the OP needs to get the sizes right or the testing may be rejected by the engineers; Liz is just a conduit. Hopefully the OP will get all the moving pieces right. :)
","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"213","kudosSumWeight":0,"postTime":"2020-10-25T14:14:08.256-04:00","lastPublishTime":"2020-10-25T14:14:08.256-04:00","metrics":{"__typename":"MessageMetrics","views":8127},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"category:HNSupport/community:ssqng67387board:TechSupport/message:128262/message:128621","repliesCount":0,"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"customFields":[]},"ModerationData:moderation_data:128624":{"__typename":"ModerationData","id":"moderation_data:128624","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:128624":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:116956"},"id":"message:128624","revisionNum":1,"uid":128624,"depth":37,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:TechSupport"},"parent":{"__ref":"ForumReplyMessage:message:128617"},"conversation":{"__ref":"Conversation:conversation:128262"},"subject":"Re: Speed issues, can't stay on chat for Help","moderationData":{"__ref":"ModerationData:moderation_data:128624"},"body":"
","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"124","kudosSumWeight":0,"postTime":"2020-10-25T15:34:07.029-04:00","lastPublishTime":"2020-10-25T15:34:07.029-04:00","metrics":{"__typename":"MessageMetrics","views":7203},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"category:HNSupport/community:ssqng67387board:TechSupport/message:128262/message:128624","repliesCount":63,"readOnly":true,"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"customFields":[]},"ModerationData:moderation_data:128625":{"__typename":"ModerationData","id":"moderation_data:128625","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:128625":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:21490"},"id":"message:128625","revisionNum":1,"uid":128625,"depth":38,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:TechSupport"},"parent":{"__ref":"ForumReplyMessage:message:128624"},"conversation":{"__ref":"Conversation:conversation:128262"},"subject":"Re: Speed issues, can't stay on chat for Help","moderationData":{"__ref":"ModerationData:moderation_data:128625"},"body":"
They keep track of the posts and what we talk about -- when the tests have been done, she'll check. :)
bronccat wrote:
maratsade LMAO :heart:
I just meant, what would prompt her to check :smileyvery-happy:
","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"218","kudosSumWeight":1,"postTime":"2020-10-25T15:58:29.076-04:00","lastPublishTime":"2020-10-25T15:58:29.076-04:00","metrics":{"__typename":"MessageMetrics","views":7201},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"category:HNSupport/community:ssqng67387board:TechSupport/message:128262/message:128625","repliesCount":62,"readOnly":true,"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"customFields":[]},"ModerationData:moderation_data:128647":{"__typename":"ModerationData","id":"moderation_data:128647","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:128647":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:116956"},"id":"message:128647","revisionNum":1,"uid":128647,"depth":39,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:TechSupport"},"parent":{"__ref":"ForumReplyMessage:message:128625"},"conversation":{"__ref":"Conversation:conversation:128262"},"subject":"Re: Speed issues, can't stay on chat for Help","moderationData":{"__ref":"ModerationData:moderation_data:128647"},"body":"Well I ran several tests yesterday as per instructions (25 DL / 4 UL) Back home now and will call them to discuss.","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"115","kudosSumWeight":0,"postTime":"2020-10-26T20:37:00.496-04:00","lastPublishTime":"2020-10-26T20:37:00.496-04:00","metrics":{"__typename":"MessageMetrics","views":7161},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"category:HNSupport/community:ssqng67387board:TechSupport/message:128262/message:128647","repliesCount":61,"readOnly":true,"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"customFields":[]},"User:user:29869":{"__typename":"User","id":"user:29869","uid":29869,"login":"GabeU","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2016-01-04T03:00:00.000-05:00"},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.hughesnet.com/t5/s/ssqng67387/images/dS0yOTg2OS0zMzc1aTM2QzZDMjdBOUREQzBFNDg"},"rank":{"__ref":"Rank:rank:5"},"entityType":"USER","eventPath":"community:ssqng67387/user:29869"},"ModerationData:moderation_data:128649":{"__typename":"ModerationData","id":"moderation_data:128649","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:128649":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:29869"},"id":"message:128649","revisionNum":1,"uid":128649,"depth":40,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:TechSupport"},"parent":{"__ref":"ForumReplyMessage:message:128647"},"conversation":{"__ref":"Conversation:conversation:128262"},"subject":"Re: Speed issues, can't stay on chat for Help","moderationData":{"__ref":"ModerationData:moderation_data:128649"},"body":"
bronccat wrote: Well I ran several tests yesterday as per instructions (25 DL / 4 UL) Back home now and will call them to discuss.
Why would you call them?
","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"213","kudosSumWeight":0,"postTime":"2020-10-26T21:00:10.368-04:00","lastPublishTime":"2020-10-26T21:00:10.368-04:00","metrics":{"__typename":"MessageMetrics","views":7150},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"category:HNSupport/community:ssqng67387board:TechSupport/message:128262/message:128649","repliesCount":60,"readOnly":true,"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"customFields":[]},"ModerationData:moderation_data:128651":{"__typename":"ModerationData","id":"moderation_data:128651","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:128651":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:116956"},"id":"message:128651","revisionNum":1,"uid":128651,"depth":41,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:TechSupport"},"parent":{"__ref":"ForumReplyMessage:message:128649"},"conversation":{"__ref":"Conversation:conversation:128262"},"subject":"Re: Speed issues, can't stay on chat for Help","moderationData":{"__ref":"ModerationData:moderation_data:128651"},"body":"Of course, that would be my preference. I didn't know if protocol was to talk to both - or?
I also didn't know how long I should give them to respond here.","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"158","kudosSumWeight":0,"postTime":"2020-10-26T21:02:30.572-04:00","lastPublishTime":"2020-10-26T21:02:30.572-04:00","metrics":{"__typename":"MessageMetrics","views":7156},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"category:HNSupport/community:ssqng67387board:TechSupport/message:128262/message:128651","repliesCount":59,"readOnly":true,"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"customFields":[]},"ModerationData:moderation_data:128652":{"__typename":"ModerationData","id":"moderation_data:128652","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:128652":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:116956"},"id":"message:128652","revisionNum":1,"uid":128652,"depth":42,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:TechSupport"},"parent":{"__ref":"ForumReplyMessage:message:128651"},"conversation":{"__ref":"Conversation:conversation:128262"},"subject":"Re: Speed issues, can't stay on chat for Help","moderationData":{"__ref":"ModerationData:moderation_data:128652"},"body":"If I'm on the mountain, this is all I have. I'll be back there first of next week. I had hoped all of this would get resolved on here before I left but with the ethernet connection issue my timing sucked lol","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"203","kudosSumWeight":0,"postTime":"2020-10-26T21:03:55.353-04:00","lastPublishTime":"2020-10-26T21:03:55.353-04:00","metrics":{"__typename":"MessageMetrics","views":7148},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"category:HNSupport/community:ssqng67387board:TechSupport/message:128262/message:128652","repliesCount":0,"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"customFields":[]},"ModerationData:moderation_data:128653":{"__typename":"ModerationData","id":"moderation_data:128653","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:128653":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:29869"},"id":"message:128653","revisionNum":1,"uid":128653,"depth":42,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:TechSupport"},"parent":{"__ref":"ForumReplyMessage:message:128651"},"conversation":{"__ref":"Conversation:conversation:128262"},"subject":"Re: Speed issues, can't stay on chat for Help","moderationData":{"__ref":"ModerationData:moderation_data:128653"},"body":"
","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"218","kudosSumWeight":0,"postTime":"2020-10-26T21:09:07.335-04:00","lastPublishTime":"2020-10-26T21:09:07.335-04:00","metrics":{"__typename":"MessageMetrics","views":7134},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"category:HNSupport/community:ssqng67387board:TechSupport/message:128262/message:128653","repliesCount":0,"readOnly":true,"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"customFields":[]},"ModerationData:moderation_data:128655":{"__typename":"ModerationData","id":"moderation_data:128655","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:128655":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:116956"},"id":"message:128655","revisionNum":1,"uid":128655,"depth":43,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:TechSupport"},"parent":{"__ref":"ForumReplyMessage:message:128653"},"conversation":{"__ref":"Conversation:conversation:128262"},"subject":"Re: Speed issues, can't stay on chat for Help","moderationData":{"__ref":"ModerationData:moderation_data:128655"},"body":"Yessir! Left it on for this reason.
You rock man, appreciate it!","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"67","kudosSumWeight":1,"postTime":"2020-10-26T21:27:26.602-04:00","lastPublishTime":"2020-10-26T21:27:26.602-04:00","metrics":{"__typename":"MessageMetrics","views":7128},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"category:HNSupport/community:ssqng67387board:TechSupport/message:128262/message:128655","repliesCount":0,"readOnly":true,"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"customFields":[]},"ModerationData:moderation_data:128656":{"__typename":"ModerationData","id":"moderation_data:128656","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:128656":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:116956"},"id":"message:128656","revisionNum":1,"uid":128656,"depth":44,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:TechSupport"},"parent":{"__ref":"ForumReplyMessage:message:128655"},"conversation":{"__ref":"Conversation:conversation:128262"},"subject":"Re: Speed issues, can't stay on chat for Help","moderationData":{"__ref":"ModerationData:moderation_data:128656"},"body":"A little LOL... I almost ran a test here (just bc I'm new to \"test.my\" and realized it would look crazy. I know the location would show but didn't want to muddy the waters ;-)","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"176","kudosSumWeight":1,"postTime":"2020-10-26T21:29:02.847-04:00","lastPublishTime":"2020-10-26T21:29:02.847-04:00","metrics":{"__typename":"MessageMetrics","views":7131},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"category:HNSupport/community:ssqng67387board:TechSupport/message:128262/message:128656","repliesCount":0,"readOnly":true,"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"customFields":[]},"Rank:rank:2":{"__typename":"Rank","id":"rank:2","position":1,"name":"Moderator","color":"0099AA","icon":null,"rankStyle":"TEXT"},"ModerationData:moderation_data:128673":{"__typename":"ModerationData","id":"moderation_data:128673","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:128673":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:16464"},"id":"message:128673","revisionNum":1,"uid":128673,"depth":45,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:TechSupport"},"parent":{"__ref":"ForumReplyMessage:message:128656"},"conversation":{"__ref":"Conversation:conversation:128262"},"subject":"Re: Speed issues, can't stay on chat for Help","moderationData":{"__ref":"ModerationData:moderation_data:128673"},"body":"
Good morning bronccat,
\n\n
\n\n
\n\n
\n\n
\n\n
\n\n
\n\n
\n\n
\n\n
\n\n
\n\n
\n\n
\n\n
\n\n
\n\n
\n\n
\n\n
\n\n
\n\n
\n\n
\n\n
\n\n
\n\n
\n\n
","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"208","kudosSumWeight":0,"postTime":"2020-10-27T10:08:04.599-04:00","lastPublishTime":"2020-10-27T10:08:04.599-04:00","metrics":{"__typename":"MessageMetrics","views":7091},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"category:HNSupport/community:ssqng67387board:TechSupport/message:128262/message:128673","repliesCount":0,"readOnly":true,"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"customFields":[]},"ModerationData:moderation_data:128683":{"__typename":"ModerationData","id":"moderation_data:128683","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:128683":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:116956"},"id":"message:128683","revisionNum":1,"uid":128683,"depth":46,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:TechSupport"},"parent":{"__ref":"ForumReplyMessage:message:128673"},"conversation":{"__ref":"Conversation:conversation:128262"},"subject":"Re: Speed issues, can't stay on chat for Help","moderationData":{"__ref":"ModerationData:moderation_data:128683"},"body":"
","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"213","kudosSumWeight":0,"postTime":"2020-10-27T12:13:22.483-04:00","lastPublishTime":"2020-10-27T12:13:22.483-04:00","metrics":{"__typename":"MessageMetrics","views":7300},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"category:HNSupport/community:ssqng67387board:TechSupport/message:128262/message:128683","repliesCount":0,"readOnly":true,"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"customFields":[]},"ModerationData:moderation_data:128685":{"__typename":"ModerationData","id":"moderation_data:128685","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:128685":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:16464"},"id":"message:128685","revisionNum":1,"uid":128685,"depth":47,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:TechSupport"},"parent":{"__ref":"ForumReplyMessage:message:128683"},"conversation":{"__ref":"Conversation:conversation:128262"},"subject":"Re: Speed issues, can't stay on chat for Help","moderationData":{"__ref":"ModerationData:moderation_data:128685"},"body":"
Hi bronccat,
\n\n
\n\n
\n\n
\n\n
\n\n
\n\n
You can check if an app needs updating if you go to whichever app store you use, visit the streaming app's page, and see if there's an \"Update\" button visible.
\n\n
\n\n
\n\n
\n\n
\n\n
\n\n
\n\n
\n\n
\n\n
\n\n
\n\n
\n\n
\n\n
\n\n
","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"213","kudosSumWeight":0,"postTime":"2020-10-27T12:38:39.229-04:00","lastPublishTime":"2020-10-27T12:38:39.229-04:00","metrics":{"__typename":"MessageMetrics","views":7296},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"category:HNSupport/community:ssqng67387board:TechSupport/message:128262/message:128685","repliesCount":0,"readOnly":true,"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"customFields":[]},"ModerationData:moderation_data:128686":{"__typename":"ModerationData","id":"moderation_data:128686","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:128686":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:116956"},"id":"message:128686","revisionNum":1,"uid":128686,"depth":48,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:TechSupport"},"parent":{"__ref":"ForumReplyMessage:message:128685"},"conversation":{"__ref":"Conversation:conversation:128262"},"subject":"Re: Speed issues, can't stay on chat for Help","moderationData":{"__ref":"ModerationData:moderation_data:128686"},"body":"
","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"208","kudosSumWeight":0,"postTime":"2020-10-27T12:47:10.818-04:00","lastPublishTime":"2020-10-27T12:47:10.818-04:00","metrics":{"__typename":"MessageMetrics","views":7305},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"category:HNSupport/community:ssqng67387board:TechSupport/message:128262/message:128686","repliesCount":0,"readOnly":true,"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"customFields":[]},"ModerationData:moderation_data:128687":{"__typename":"ModerationData","id":"moderation_data:128687","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:128687":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:116956"},"id":"message:128687","revisionNum":1,"uid":128687,"depth":49,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:TechSupport"},"parent":{"__ref":"ForumReplyMessage:message:128686"},"conversation":{"__ref":"Conversation:conversation:128262"},"subject":"Re: Speed issues, can't stay on chat for Help","moderationData":{"__ref":"ModerationData:moderation_data:128687"},"body":"
","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"146","kudosSumWeight":0,"postTime":"2020-10-27T12:51:03.276-04:00","lastPublishTime":"2020-10-27T12:51:03.276-04:00","metrics":{"__typename":"MessageMetrics","views":7305},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"category:HNSupport/community:ssqng67387board:TechSupport/message:128262/message:128687","repliesCount":0,"readOnly":true,"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"customFields":[]},"ModerationData:moderation_data:128727":{"__typename":"ModerationData","id":"moderation_data:128727","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:128727":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:116956"},"id":"message:128727","revisionNum":2,"uid":128727,"depth":50,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:TechSupport"},"parent":{"__ref":"ForumReplyMessage:message:128687"},"conversation":{"__ref":"Conversation:conversation:128262"},"subject":"Re: Speed issues, can't stay on chat for Help","moderationData":{"__ref":"ModerationData:moderation_data:128727"},"body":"
","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"132","kudosSumWeight":0,"postTime":"2020-10-28T14:47:14.265-04:00","lastPublishTime":"2020-10-28T14:47:45.502-04:00","metrics":{"__typename":"MessageMetrics","views":7075},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"category:HNSupport/community:ssqng67387board:TechSupport/message:128262/message:128727","repliesCount":0,"readOnly":true,"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"customFields":[]},"ModerationData:moderation_data:128731":{"__typename":"ModerationData","id":"moderation_data:128731","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:128731":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:16464"},"id":"message:128731","revisionNum":1,"uid":128731,"depth":51,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:TechSupport"},"parent":{"__ref":"ForumReplyMessage:message:128727"},"conversation":{"__ref":"Conversation:conversation:128262"},"subject":"Re: Speed issues, can't stay on chat for Help","moderationData":{"__ref":"ModerationData:moderation_data:128731"},"body":"
Hi broncat,
\n\n
\n\n
\n\n
\n\n
\n\n
\n\n
","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"213","kudosSumWeight":0,"postTime":"2020-10-28T15:17:14.542-04:00","lastPublishTime":"2020-10-28T15:17:14.542-04:00","metrics":{"__typename":"MessageMetrics","views":7063},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"category:HNSupport/community:ssqng67387board:TechSupport/message:128262/message:128731","repliesCount":0,"readOnly":true,"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"customFields":[]},"ModerationData:moderation_data:128733":{"__typename":"ModerationData","id":"moderation_data:128733","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:128733":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:116956"},"id":"message:128733","revisionNum":1,"uid":128733,"depth":52,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:TechSupport"},"parent":{"__ref":"ForumReplyMessage:message:128731"},"conversation":{"__ref":"Conversation:conversation:128262"},"subject":"Re: Speed issues, can't stay on chat for Help","moderationData":{"__ref":"ModerationData:moderation_data:128733"},"body":"Liz
Screenshots?
Thank you.","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"203","kudosSumWeight":0,"postTime":"2020-10-28T15:22:46.422-04:00","lastPublishTime":"2020-10-28T15:22:46.422-04:00","metrics":{"__typename":"MessageMetrics","views":7060},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"category:HNSupport/community:ssqng67387board:TechSupport/message:128262/message:128733","repliesCount":0,"readOnly":true,"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"customFields":[]},"ModerationData:moderation_data:128734":{"__typename":"ModerationData","id":"moderation_data:128734","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:128734":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:21490"},"id":"message:128734","revisionNum":1,"uid":128734,"depth":53,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:TechSupport"},"parent":{"__ref":"ForumReplyMessage:message:128733"},"conversation":{"__ref":"Conversation:conversation:128262"},"subject":"Re: Speed issues, can't stay on chat for Help","moderationData":{"__ref":"ModerationData:moderation_data:128734"},"body":"
","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"203","kudosSumWeight":0,"postTime":"2020-10-28T15:38:05.989-04:00","lastPublishTime":"2020-10-28T15:38:05.989-04:00","metrics":{"__typename":"MessageMetrics","views":7072},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"category:HNSupport/community:ssqng67387board:TechSupport/message:128262/message:128734","repliesCount":0,"readOnly":true,"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"customFields":[]},"ModerationData:moderation_data:128736":{"__typename":"ModerationData","id":"moderation_data:128736","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:128736":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:116956"},"id":"message:128736","revisionNum":1,"uid":128736,"depth":54,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:TechSupport"},"parent":{"__ref":"ForumReplyMessage:message:128734"},"conversation":{"__ref":"Conversation:conversation:128262"},"subject":"Re: Speed issues, can't stay on chat for Help","moderationData":{"__ref":"ModerationData:moderation_data:128736"},"body":"I'm not there and its busy work. No way a video streaming app is going to create slow speed test results.
Now, all of that being said, if I have to jump through hoops before they are \"allowed\" to escalate - then just say it.
BTW, this isn't a CO-OP I'm a paying customer and expect better. I'm not going to apologize for my frustration either.","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"203","kudosSumWeight":0,"postTime":"2020-10-28T15:46:44.413-04:00","lastPublishTime":"2020-10-28T15:46:44.413-04:00","metrics":{"__typename":"MessageMetrics","views":7059},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"category:HNSupport/community:ssqng67387board:TechSupport/message:128262/message:128736","repliesCount":0,"readOnly":true,"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"customFields":[]},"ModerationData:moderation_data:128737":{"__typename":"ModerationData","id":"moderation_data:128737","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:128737":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:21490"},"id":"message:128737","revisionNum":1,"uid":128737,"depth":55,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:TechSupport"},"parent":{"__ref":"ForumReplyMessage:message:128736"},"conversation":{"__ref":"Conversation:conversation:128262"},"subject":"Re: Speed issues, can't stay on chat for Help","moderationData":{"__ref":"ModerationData:moderation_data:128737"},"body":"
","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"203","kudosSumWeight":0,"postTime":"2020-10-28T16:05:22.703-04:00","lastPublishTime":"2020-10-28T16:05:22.703-04:00","metrics":{"__typename":"MessageMetrics","views":7046},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"category:HNSupport/community:ssqng67387board:TechSupport/message:128262/message:128737","repliesCount":0,"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"customFields":[]},"ModerationData:moderation_data:128738":{"__typename":"ModerationData","id":"moderation_data:128738","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:128738":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:16464"},"id":"message:128738","revisionNum":1,"uid":128738,"depth":55,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:TechSupport"},"parent":{"__ref":"ForumReplyMessage:message:128736"},"conversation":{"__ref":"Conversation:conversation:128262"},"subject":"Re: Speed issues, can't stay on chat for Help","moderationData":{"__ref":"ModerationData:moderation_data:128738"},"body":"
Hi bronccat,
\n\n
\n\n
\n\n
\n\n
\n\n
\n\n
","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"213","kudosSumWeight":0,"postTime":"2020-10-28T16:08:10.117-04:00","lastPublishTime":"2020-10-28T16:08:10.117-04:00","metrics":{"__typename":"MessageMetrics","views":7272},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"category:HNSupport/community:ssqng67387board:TechSupport/message:128262/message:128738","repliesCount":0,"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"customFields":[]},"CachedAsset:text:en_US-shared/client/components/nodes/NodeIcon-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/nodes/NodeIcon-1739990369000","value":{"contentType":"Content Type {style, select, FORUM {Forum} BLOG {Blog} TKB {Knowledge Base} IDEA {Ideas} OCCASION {Events} other {}} icon"},"localOverride":false}}}},"page":"/forums/ForumMessagePage/ForumMessagePage","query":{"boardId":"TechSupport","messageSubject":"speed-issues-cant-stay-on-chat-for-help","messageId":"128262","replyId":"128615"},"buildId":"FP3zsFp6DJl70wDujOvtu","runtimeConfig":{"buildInformationVisible":false,"logLevelApp":"info","logLevelMetrics":"info","openTelemetryClientEnabled":false,"openTelemetryConfigName":"hughes","openTelemetryServiceVersion":"25.3.0","openTelemetryUniverse":"prod","openTelemetryCollector":"http://localhost:4318","openTelemetryRouteChangeAllowedTime":"5000","apolloDevToolsEnabled":false,"inboxMuteWipFeatureEnabled":false},"isFallback":false,"isExperimentalCompile":false,"dynamicIds":["./components/seo/QAPageSchema/QAPageSchema.tsx","./components/community/Navbar/NavbarWidget.tsx","./components/community/Breadcrumb/BreadcrumbWidget.tsx","./components/customComponent/CustomComponent/CustomComponent.tsx","./components/messages/TopicWithThreadedReplyListWidget/TopicWithThreadedReplyListWidget.tsx","./components/messages/MessageView/MessageViewStandard/MessageViewStandard.tsx","./components/messages/RelatedContentWidget/RelatedContentWidget.tsx","./components/messages/MessageListForNodeByRecentActivityWidget/MessageListForNodeByRecentActivityWidget.tsx","./components/customComponent/CustomComponentContent/TemplateContent.tsx","../shared/client/components/common/List/UnwrappedList/UnwrappedList.tsx","./components/tags/TagView/TagView.tsx","./components/tags/TagView/TagViewChip/TagViewChip.tsx","../shared/client/components/common/List/UnstyledList/UnstyledList.tsx","./components/messages/MessageView/MessageView.tsx","./components/messages/MessageView/MessageViewInline/MessageViewInline.tsx","../shared/client/components/common/List/ListGroup/ListGroup.tsx","../shared/client/components/common/Pager/PagerLoadMore/PagerLoadMore.tsx","./components/customComponent/CustomComponentContent/HtmlContent.tsx","./components/customComponent/CustomComponentContent/CustomComponentScripts.tsx"],"appGip":true,"scriptLoader":[{"id":"mixPanel","src":"https://community.hughesnet.com/t5/s/ssqng67387/pagescripts/1733832053000/mixPanel.js?page.id=ForumReplyPage&entity.id=board%3ATechSupport&entity.id=message%3A128615","strategy":"afterInteractive"}]}
