Connectivity problems
The Modem is hardwired to 192.168.0.1
This address can not be shared by any other device or issues will occur.
The LAN IP of the Router is suggested to be at 192.168.1.1
That separation will allow proper operation.
My questions were meant as a sort of checklist.
A IP address conflict between the Modems hardwired address of 192.168.0.1 and the Router's LAN IP being set to the same will cause issues.
Knowing if DHCP is enabled in the Router tells us who, the Modem or the Router, is to hand out IP addresses to clients.
If the Modem is restarting:
Be sure the DIN connector on the back of the modem is fully seated and that coax cables are tight.
Be sure to allow at least 6" of clearance around the modem to allow proper air flow.
What error codes are listed when you open the Modems SCC at 192.168.0.1?
