Help Please – Download Speed < 8 Mbps on Gen5 for WEEKS
Well I’m back again – for a few days my download speeds had recovered to normal (15-30 Mbps), but now I am back to less than 8 Mbps. My "work day" download speeds are now generally less than 8 Mbps and often around 1 Mbps! Early mornings and very late evenings speeds can be as high as 30, but I don’t work at night or before 8AM. Simple, low resolution, 5 minute, YouTube videos take 10-15 minutes to watch. This has been going on since January 3d. Here is what I have done to chase this problem down:
- Rebooted modem and checked speed = no change
- Powered off modem for 10 minutes = no change
- Repeated above wired directly to my modem (HT2000W) = no change
- I have run 90 download speed tests using testmy.net since January 3d and my average speed is 8.18 Mbps!
- You can see my test results at https://testmy.net/quickstats/stanleytpig
- I contacted Hughesnet support via chat on January 3d (Lulu Carette, case number 108575566), checked everything I was told to check, did everything I was told to do, the chat took over an hour after which time I was told that I would be raised to engineering level support and that I would receive a call within 72 hours. I remaind at home avaliable 24 hours a day for SEVEN DAYS and did not recieve a call duing that time.
- Over two weeks later I received a call back, but I was not home and the caller left a call back number. I called back the next day only to fine that the “call in code” had expired and I could not speak to anyone.
- I have also tried the speed tests on the Hughesnet website which yielded very weird results, like taking 3-4 minutes to download the 12 meg file and speed results given are > 200 Mbps! Not possible! Web speed tests range from around 1 to 4 seconds – mostly greater than 2 seconds
My system is: Gen5 (EcoStar-19-NAD); Gateway ID 15; Beam ID 71; Satellite Receive Signal Strength 99, modem HT2000W, two Windows 10 PCs (wireless and/or ethernet); 30/50 Meg plan that costs $87/per month.
I have been with Hughes since 2001 – that’s 17 years and I have literally done everything that I can think of to make system work as advertised (e.g., highspeed internet and at least 60% of the advertised 25 Mbps, or 15 Mbps and 8 Mbps is not even close).
It would be really nice if someone could fix this problem – perhaps one of those talented techs like Liz or Amanda could be cajoled into looking into my problem – I would greatly appreciate it.
Regards to all - Skip
Hello everyone,
Since January 26th I have run 15 download speed tests using testmy.net (average = 30.4 Mbps) and 14 using Speedtest by Ookla (average = 15.1 Mbps) and it appears that my download speeds have returned to normal. This is way, way, way up from the 91 testmy.net tests I ran between January 3d and 25, which averaged 8.2 Mbps.
I do find it interesting that testmy.net tests were twice as fast as Speedtest (based on the average) - note tests were performed in pairs, using the same computer and run within 2 minutes of each other. This result appears to be the inverse of what others have reported when comparing testmy.net and Speedtest. Possibliy the servers chosen are responsible for the difference, as testmy.net seems to be using a site in Dallas and Speedtest is using a site in Los Angeles (approx 100 miles north of me).
Anyway all that being said, I am happy that I things are back to normal, at least for this Hughesnet user. I don't know how the correction was implemented, but I appericate the help from those on this forum and any of then unknown "engineers" that have worked on this issue. I will mark this discussion string Corrected and begin a new string, if the problem returns.
To those still chasing speed issues, I wish you luck and suggest you continue working within this forum to resolve your specific issues.
ciao for now - Skip
- JeffGFreshman
I would kill for 8 Mbps! I've had the service (Gen 5) since last November, only about 3 days with anything over 1 Mbps. 4 calls and an email into Tech, spoke with two "supervisors" only to be strung along. Last contact was Jan. 11th, I was told they would address my issue in 2-3 weeks. Ya, right. Needless to say I'm very disappointed but in my area there is no other option other than Dish but I already have Direct TV bundled with Wireless and they don't offer internet here.
- newtonfJunior
JeffG, Gabe provided a link to a different speed test link speedtest.net
You might try testing it out at different time during the day. So far this morning I'm getting around 13Mbps, which is pretty good compared to the last few weeks.
If I get my slow download resolved I will post the progress and any solutions.
Good Luck - Skip
- JeffGFreshman
Speed Test Smeed Test, slow is slow, I've tried 6 differnt sites including the Hughes Site. Just did Speedtest.net, result of three tests is download speeds 0.53~0.54~0.58Mbps respectivly. I have yet to be able to stream video from any source at any def setting, even 460. I have read too many others on this forum with the same issue, Hughes MUST step up and fix this!
JeffG
I'll tag the reps so that they will be sure to see your post.
With this said, as of recently there is a problem with testmy.net, so please start using another test. You can use any that you like (speedtest.net is a popular one), but please avoid fast.com, as it not only causes the Video Data Saver to engage, meaning it will never show a speed higher than 2-3Mbps, it uses a LOT of data when running a test with the Video Data Saver off.
- newtonfJunior
GabeU, thank you for tagging the reps and suggesting speedtest.net. I downloaded the desktop version and will begin tracking speed with it. I did one download so far and compared with testmy.net within 3 minutes, speedtest = 13.37 and testmy = ~25 Mbps. Speeds seem faster this morning, but time will tell.
thanks again - Skip
newtonf wrote:GabeU, thank you for tagging the reps and suggesting speedtest.net. I downloaded the desktop version and will begin tracking speed with it. I did one download so far and compared with testmy.net within 3 minutes, speedtest = 13.37 and testmy = ~25 Mbps. Speeds seem faster this morning, but time will tell.
thanks again - Skip
Actually, coincidentally enough, testmy seems to be working properly over the last couple of days, at least for some (maybe all?) on the ES19 satellite, so your result from them may very well be accurate. Accuracy is the reason they've had people using testmy for quite some time now. Hopefully it continues and we'll be able to use testmy on a regular basis again.
I tried the speedtest desktop app, and though it seemed to give accurate download results, my upload results were really skewed. Sometimes it was showing that I had upload speeds of 18Mbps or so, which isn't possible. But, the online version seems to give some people issues, so the desktop app is a decent alternative, at least for download speeds. Speedtest being a little temperamental is another reason why I hope we can soon start using testmy.net again.
