MODEM
MODEM
MODEM
MODEM
I do this multiple times every day! Often, when it drops a call, I start getting a ringback, as though the system were trying to reestablish the connection. When I pick up, the line is dead. As soon as I hang up, it rings again. The only way to stop this is to cycle the ATA. Sometimes, I cycle both, but getting everyone out of what they're doing and off the internet is a bit more hassle.
In any case, that has not helped yet. Once it has started dropping calls, the chances of making another call of more than 2 minutes or so diminish dramatically. Cycling the sysytem fully or partially does not seem to change that.
I hope I can get some response soon. For obvious reasons, I can't *call* customer service on the VOIP. We are in a rural area with no cell phone service.
(To be fair, the only wired phone provider in this region is Frontier, and their products, pricing, and service are terrible!)
HELP! Please!
