bos2420's avatar
bos2420
Junior
6 years ago
The problem started a week to 10 days ago.  I can not connect to AOL via my hughes Gen5 connection.  We both use aol mail (yes, I know there are better options, and I may look into that, but when you...
    6 years ago
    bos2420
    One other thing is that, if you'd like to schedule the file downloads, but you don't like the idea of leaving your PC on (I don't), or messing with trying to schedule the downloads to your PC, you can schedule the file download(s) to your Android or IOS device using the PlayOn Cloud app, then copy the files to your PC.
    BTW, don't forget to change the resolution on the app if you want it to be better than standard.  I'm fine with standard, which is DVD quality, but some people want it to be better, regardless of the increased file size for the program/movie.  I believe 720p is the maximum resolution, but that's still very good.
    If you try it and you like it, please let us know.  I'm still deciding whether to get it, though I probably will.  It's cheap, and lets you easily take advantage of the Bonus Zone data, and even those twenty days of data resets with your upgrade (make sure first, though, of course).  :)
"}},"component({\"componentId\":\"custom.widget.custom_Footer\"})":{"__typename":"Component","render({\"context\":{\"component\":{\"entities\":[],\"props\":{}},\"page\":{\"entities\":[\"board:TechSupport\",\"message:111048\"],\"name\":\"ForumReplyPage\",\"props\":{},\"url\":\"https://community.hughesnet.com\"}}})":{"__typename":"ComponentRenderResult","html":""}},"component({\"componentId\":\"custom.widget.MixPanelTracker\"})":{"__typename":"Component","render({\"context\":{\"component\":{\"entities\":[],\"props\":{}},\"page\":{\"entities\":[\"board:TechSupport\",\"message:111048\"],\"name\":\"ForumReplyPage\",\"props\":{},\"url\":\"https://community.hughesnet.com\"}}})":{"__typename":"ComponentRenderResult","html":" "}},"cachedText({\"lastModified\":\"1728282321000\",\"locale\":\"en-US\",\"namespaces\":[\"components/messages/EscalatedMessageBanner\"]})":[{"__ref":"CachedAsset:text:en_US-components/messages/EscalatedMessageBanner-1728282321000"}],"cachedText({\"lastModified\":\"1728282321000\",\"locale\":\"en-US\",\"namespaces\":[\"components/users/UserLink\"]})":[{"__ref":"CachedAsset:text:en_US-components/users/UserLink-1728282321000"}],"cachedText({\"lastModified\":\"1728282321000\",\"locale\":\"en-US\",\"namespaces\":[\"shared/client/components/users/UserRank\"]})":[{"__ref":"CachedAsset:text:en_US-shared/client/components/users/UserRank-1728282321000"}],"cachedText({\"lastModified\":\"1728282321000\",\"locale\":\"en-US\",\"namespaces\":[\"components/messages/MessageTime\"]})":[{"__ref":"CachedAsset:text:en_US-components/messages/MessageTime-1728282321000"}],"cachedText({\"lastModified\":\"1728282321000\",\"locale\":\"en-US\",\"namespaces\":[\"components/messages/MessageSubject\"]})":[{"__ref":"CachedAsset:text:en_US-components/messages/MessageSubject-1728282321000"}],"cachedText({\"lastModified\":\"1728282321000\",\"locale\":\"en-US\",\"namespaces\":[\"components/messages/MessageBody\"]})":[{"__ref":"CachedAsset:text:en_US-components/messages/MessageBody-1728282321000"}],"cachedText({\"lastModified\":\"1728282321000\",\"locale\":\"en-US\",\"namespaces\":[\"components/messages/MessageCustomFields\"]})":[{"__ref":"CachedAsset:text:en_US-components/messages/MessageCustomFields-1728282321000"}],"cachedText({\"lastModified\":\"1728282321000\",\"locale\":\"en-US\",\"namespaces\":[\"components/messages/MessageReplyButton\"]})":[{"__ref":"CachedAsset:text:en_US-components/messages/MessageReplyButton-1728282321000"}],"cachedText({\"lastModified\":\"1728282321000\",\"locale\":\"en-US\",\"namespaces\":[\"components/messages/MessageSolutionList\"]})":[{"__ref":"CachedAsset:text:en_US-components/messages/MessageSolutionList-1728282321000"}],"cachedText({\"lastModified\":\"1728282321000\",\"locale\":\"en-US\",\"namespaces\":[\"components/messages/MessageView/MessageViewInline\"]})":[{"__ref":"CachedAsset:text:en_US-components/messages/MessageView/MessageViewInline-1728282321000"}],"cachedText({\"lastModified\":\"1728282321000\",\"locale\":\"en-US\",\"namespaces\":[\"shared/client/components/common/Pager/PagerLoadMore\"]})":[{"__ref":"CachedAsset:text:en_US-shared/client/components/common/Pager/PagerLoadMore-1728282321000"}],"message({\"id\":\"message:111048\"})":{"__ref":"ForumTopicMessage:message:111048"},"messages({\"constraints\":{\"solution\":{\"eq\":true},\"topicId\":{\"eq\":\"message:111048\"}},\"first\":10,\"sorts\":{\"postTime\":{\"direction\":\"ASC\"}}})":{"__typename":"MessageConnection","edges":[{"__typename":"MessageEdge","cursor":"MjQuMTF8Mi4xfGl8MTB8Mzk6MXxpbnQsMTExMTMzLDExMTEzMw","node":{"__ref":"AcceptedSolutionMessage:message:111133"}}],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null},"totalCount":1},"cachedText({\"lastModified\":\"1728282321000\",\"locale\":\"en-US\",\"namespaces\":[\"shared/client/components/users/UserAvatar\"]})":[{"__ref":"CachedAsset:text:en_US-shared/client/components/users/UserAvatar-1728282321000"}],"cachedText({\"lastModified\":\"1728282321000\",\"locale\":\"en-US\",\"namespaces\":[\"shared/client/components/ranks/UserRankLabel\"]})":[{"__ref":"CachedAsset:text:en_US-shared/client/components/ranks/UserRankLabel-1728282321000"}],"cachedText({\"lastModified\":\"1728282321000\",\"locale\":\"en-US\",\"namespaces\":[\"components/messages/AcceptedSolutionButton\"]})":[{"__ref":"CachedAsset:text:en_US-components/messages/AcceptedSolutionButton-1728282321000"}],"cachedText({\"lastModified\":\"1728282321000\",\"locale\":\"en-US\",\"namespaces\":[\"components/messages/LinearReplyList\"]})":[{"__ref":"CachedAsset:text:en_US-components/messages/LinearReplyList-1728282321000"}],"cachedText({\"lastModified\":\"1728282321000\",\"locale\":\"en-US\",\"namespaces\":[\"shared/client/components/nodes/NodeIcon\"]})":[{"__ref":"CachedAsset:text:en_US-shared/client/components/nodes/NodeIcon-1728282321000"}],"cachedText({\"lastModified\":\"1728282321000\",\"locale\":\"en-US\",\"namespaces\":[\"components/messages/MessageSolvedBadge\"]})":[{"__ref":"CachedAsset:text:en_US-components/messages/MessageSolvedBadge-1728282321000"}],"message({\"id\":\"message:111133\"})":{"__ref":"AcceptedSolutionMessage:message:111133"},"message({\"id\":\"message:111122\"})":{"__ref":"ForumReplyMessage:message:111122"},"cachedText({\"lastModified\":\"1728282321000\",\"locale\":\"en-US\",\"namespaces\":[\"components/tags/TagView/TagViewChip\"]})":[{"__ref":"CachedAsset:text:en_US-components/tags/TagView/TagViewChip-1728282321000"}],"message({\"id\":\"message:111124\"})":{"__ref":"ForumReplyMessage:message:111124"},"message({\"id\":\"message:111125\"})":{"__ref":"ForumReplyMessage:message:111125"},"message({\"id\":\"message:111126\"})":{"__ref":"ForumReplyMessage:message:111126"},"message({\"id\":\"message:111128\"})":{"__ref":"ForumReplyMessage:message:111128"},"message({\"id\":\"message:111235\"})":{"__ref":"ForumReplyMessage:message:111235"},"message({\"id\":\"message:111238\"})":{"__ref":"ForumReplyMessage:message:111238"},"message({\"id\":\"message:111411\"})":{"__ref":"ForumReplyMessage:message:111411"},"message({\"id\":\"message:111412\"})":{"__ref":"ForumReplyMessage:message:111412"},"message({\"id\":\"message:111413\"})":{"__ref":"ForumReplyMessage:message:111413"},"message({\"id\":\"message:111416\"})":{"__ref":"ForumReplyMessage:message:111416"}},"CachedAsset:pages-1736251114741":{"__typename":"CachedAsset","id":"pages-1736251114741","value":[{"lastUpdatedTime":1736251114741,"localOverride":null,"page":{"id":"BlogViewAllPostsPage","type":"BLOG","urlPath":"/category/:categoryId/blog/:boardId/all-posts/(/:after|/:before)?","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1736251114741,"localOverride":null,"page":{"id":"CasePortalPage","type":"CASE_PORTAL","urlPath":"/caseportal","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1736251114741,"localOverride":null,"page":{"id":"CreateGroupHubPage","type":"GROUP_HUB","urlPath":"/groups/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1736251114741,"localOverride":null,"page":{"id":"CaseViewPage","type":"CASE_DETAILS","urlPath":"/case/:caseId/:caseNumber","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1736251114741,"localOverride":null,"page":{"id":"InboxPage","type":"COMMUNITY","urlPath":"/inbox","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1736251114741,"localOverride":null,"page":{"id":"HelpFAQPage","type":"COMMUNITY","urlPath":"/help","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1736251114741,"localOverride":null,"page":{"id":"IdeaMessagePage","type":"IDEA_POST","urlPath":"/idea/:boardId/:messageSubject/:messageId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1736251114741,"localOverride":null,"page":{"id":"IdeaViewAllIdeasPage","type":"IDEA","urlPath":"/category/:categoryId/ideas/:boardId/all-ideas/(/:after|/:before)?","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1736251114741,"localOverride":null,"page":{"id":"LoginPage","type":"USER","urlPath":"/signin","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1736251114741,"localOverride":null,"page":{"id":"BlogPostPage","type":"BLOG","urlPath":"/category/:categoryId/blogs/:boardId/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1736251114741,"localOverride":null,"page":{"id":"ThemeEditorPage","type":"COMMUNITY","urlPath":"/designer/themes","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1736251114741,"localOverride":null,"page":{"id":"TkbViewAllArticlesPage","type":"TKB","urlPath":"/category/:categoryId/kb/:boardId/all-articles/(/:after|/:before)?","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1736251114741,"localOverride":null,"page":{"id":"OccasionEditPage","type":"EVENT","urlPath":"/event/:boardId/:messageSubject/:messageId/edit","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1736251114741,"localOverride":null,"page":{"id":"OAuthAuthorizationAllowPage","type":"USER","urlPath":"/auth/authorize/allow","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1736251114741,"localOverride":null,"page":{"id":"PageEditorPage","type":"COMMUNITY","urlPath":"/designer/pages","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1736251114741,"localOverride":null,"page":{"id":"PostPage","type":"COMMUNITY","urlPath":"/category/:categoryId/:boardId/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1736251114741,"localOverride":null,"page":{"id":"ForumBoardPage","type":"FORUM","urlPath":"/category/:categoryId/discussions/:boardId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1736251114741,"localOverride":null,"page":{"id":"TkbBoardPage","type":"TKB","urlPath":"/category/:categoryId/kb/:boardId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1736251114741,"localOverride":null,"page":{"id":"EventPostPage","type":"EVENT","urlPath":"/category/:categoryId/events/:boardId/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1736251114741,"localOverride":null,"page":{"id":"UserBadgesPage","type":"COMMUNITY","urlPath":"/users/:login/:userId/badges","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1736251114741,"localOverride":null,"page":{"id":"GroupHubMembershipAction","type":"GROUP_HUB","urlPath":"/membership/join/:nodeId/:membershipType","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1736251114741,"localOverride":null,"page":{"id":"IdeaReplyPage","type":"IDEA_REPLY","urlPath":"/idea/:boardId/:messageSubject/:messageId/comments/:replyId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1736251114741,"localOverride":null,"page":{"id":"UserSettingsPage","type":"USER","urlPath":"/mysettings/:userSettingsTab","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1736251114741,"localOverride":null,"page":{"id":"GroupHubsPage","type":"GROUP_HUB","urlPath":"/groups","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1736251114741,"localOverride":null,"page":{"id":"ForumPostPage","type":"FORUM","urlPath":"/category/:categoryId/discussions/:boardId/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1736251114741,"localOverride":null,"page":{"id":"OccasionRsvpActionPage","type":"OCCASION","urlPath":"/event/:boardId/:messageSubject/:messageId/rsvp/:responseType","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1736251114741,"localOverride":null,"page":{"id":"VerifyUserEmailPage","type":"USER","urlPath":"/verifyemail/:userId/:verifyEmailToken","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1736251114741,"localOverride":null,"page":{"id":"AllOccasionsPage","type":"OCCASION","urlPath":"/category/:categoryId/events/:boardId/all-events/(/:after|/:before)?","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1736251114741,"localOverride":null,"page":{"id":"EventBoardPage","type":"EVENT","urlPath":"/category/:categoryId/events/:boardId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1736251114741,"localOverride":null,"page":{"id":"TkbReplyPage","type":"TKB_REPLY","urlPath":"/kb/:boardId/:messageSubject/:messageId/comments/:replyId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1736251114741,"localOverride":null,"page":{"id":"IdeaBoardPage","type":"IDEA","urlPath":"/category/:categoryId/ideas/:boardId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1736251114741,"localOverride":null,"page":{"id":"CommunityGuideLinesPage","type":"COMMUNITY","urlPath":"/communityguidelines","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1736251114741,"localOverride":null,"page":{"id":"CaseCreatePage","type":"SALESFORCE_CASE_CREATION","urlPath":"/caseportal/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1736251114741,"localOverride":null,"page":{"id":"TkbEditPage","type":"TKB","urlPath":"/kb/:boardId/:messageSubject/:messageId/edit","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1736251114741,"localOverride":null,"page":{"id":"ForgotPasswordPage","type":"USER","urlPath":"/forgotpassword","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1736251114741,"localOverride":null,"page":{"id":"IdeaEditPage","type":"IDEA","urlPath":"/idea/:boardId/:messageSubject/:messageId/edit","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1736251114741,"localOverride":null,"page":{"id":"TagPage","type":"COMMUNITY","urlPath":"/tag/:tagName","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1736251114741,"localOverride":null,"page":{"id":"BlogBoardPage","type":"BLOG","urlPath":"/category/:categoryId/blog/:boardId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1736251114741,"localOverride":null,"page":{"id":"OccasionMessagePage","type":"OCCASION_TOPIC","urlPath":"/event/:boardId/:messageSubject/:messageId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1736251114741,"localOverride":null,"page":{"id":"ManageContentPage","type":"COMMUNITY","urlPath":"/managecontent","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1736251114741,"localOverride":null,"page":{"id":"ClosedMembershipNodeNonMembersPage","type":"GROUP_HUB","urlPath":"/closedgroup/:groupHubId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1736251114741,"localOverride":null,"page":{"id":"CommunityPage","type":"COMMUNITY","urlPath":"/","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1736251114741,"localOverride":null,"page":{"id":"ForumMessagePage","type":"FORUM_TOPIC","urlPath":"/discussions/:boardId/:messageSubject/:messageId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1736251114741,"localOverride":null,"page":{"id":"IdeaPostPage","type":"IDEA","urlPath":"/category/:categoryId/ideas/:boardId/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1736251114741,"localOverride":null,"page":{"id":"BlogMessagePage","type":"BLOG_ARTICLE","urlPath":"/blog/:boardId/:messageSubject/:messageId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1736251114741,"localOverride":null,"page":{"id":"RegistrationPage","type":"USER","urlPath":"/register","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1736251114741,"localOverride":null,"page":{"id":"EditGroupHubPage","type":"GROUP_HUB","urlPath":"/group/:groupHubId/edit","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1736251114741,"localOverride":null,"page":{"id":"ForumEditPage","type":"FORUM","urlPath":"/discussions/:boardId/:messageSubject/:messageId/edit","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1736251114741,"localOverride":null,"page":{"id":"ResetPasswordPage","type":"USER","urlPath":"/resetpassword/:userId/:resetPasswordToken","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1736251114741,"localOverride":null,"page":{"id":"TkbMessagePage","type":"TKB_ARTICLE","urlPath":"/kb/:boardId/:messageSubject/:messageId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1736251114741,"localOverride":null,"page":{"id":"BlogEditPage","type":"BLOG","urlPath":"/blog/:boardId/:messageSubject/:messageId/edit","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1736251114741,"localOverride":null,"page":{"id":"ManageUsersPage","type":"USER","urlPath":"/users/manage/:tab?/:manageUsersTab?","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1736251114741,"localOverride":null,"page":{"id":"ForumReplyPage","type":"FORUM_REPLY","urlPath":"/discussions/:boardId/:messageSubject/:messageId/replies/:replyId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1736251114741,"localOverride":null,"page":{"id":"PrivacyPolicyPage","type":"COMMUNITY","urlPath":"/privacypolicy","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1736251114741,"localOverride":null,"page":{"id":"NotificationPage","type":"COMMUNITY","urlPath":"/notifications","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1736251114741,"localOverride":null,"page":{"id":"UserPage","type":"USER","urlPath":"/users/:login/:userId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1736251114741,"localOverride":null,"page":{"id":"OccasionReplyPage","type":"OCCASION_REPLY","urlPath":"/event/:boardId/:messageSubject/:messageId/comments/:replyId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1736251114741,"localOverride":null,"page":{"id":"ManageMembersPage","type":"GROUP_HUB","urlPath":"/group/:groupHubId/manage/:tab?","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1736251114741,"localOverride":null,"page":{"id":"SearchResultsPage","type":"COMMUNITY","urlPath":"/search","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1736251114741,"localOverride":null,"page":{"id":"BlogReplyPage","type":"BLOG_REPLY","urlPath":"/blog/:boardId/:messageSubject/:messageId/replies/:replyId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1736251114741,"localOverride":null,"page":{"id":"GroupHubPage","type":"GROUP_HUB","urlPath":"/group/:groupHubId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1736251114741,"localOverride":null,"page":{"id":"TermsOfServicePage","type":"COMMUNITY","urlPath":"/termsofservice","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1736251114741,"localOverride":null,"page":{"id":"CategoryPage","type":"CATEGORY","urlPath":"/category/:categoryId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1736251114741,"localOverride":null,"page":{"id":"ForumViewAllTopicsPage","type":"FORUM","urlPath":"/category/:categoryId/discussions/:boardId/all-topics/(/:after|/:before)?","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1736251114741,"localOverride":null,"page":{"id":"TkbPostPage","type":"TKB","urlPath":"/category/:categoryId/kbs/:boardId/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1736251114741,"localOverride":null,"page":{"id":"GroupHubPostPage","type":"GROUP_HUB","urlPath":"/group/:groupHubId/:boardId/create","__typename":"PageDescriptor"},"__typename":"PageResource"}],"localOverride":false},"CachedAsset:text:en_US-components/context/AppContext/AppContextProvider-0":{"__typename":"CachedAsset","id":"text:en_US-components/context/AppContext/AppContextProvider-0","value":{"noCommunity":"Cannot find community","noUser":"Cannot find current user","noNode":"Cannot find node with id {nodeId}","noMessage":"Cannot find message with id {messageId}"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/common/Loading/LoadingDot-0":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/common/Loading/LoadingDot-0","value":{"title":"Loading..."},"localOverride":false},"User:user:-1":{"__typename":"User","id":"user:-1","uid":-1,"login":"Anonymous","email":"","avatar":null,"rank":null,"kudosWeight":1,"registrationData":{"__typename":"RegistrationData","status":"ANONYMOUS","registrationTime":null,"confirmEmailStatus":false,"registrationAccessLevel":"VIEW","ssoRegistrationFields":[]},"ssoId":null,"profileSettings":{"__typename":"ProfileSettings","dateDisplayStyle":{"__typename":"InheritableStringSettingWithPossibleValues","key":"layout.friendly_dates_enabled","value":"true","localValue":"true","possibleValues":["true","false"]},"dateDisplayFormat":{"__typename":"InheritableStringSetting","key":"layout.format_pattern_date","value":"MM-dd-yyyy","localValue":"MM-dd-yyyy"},"language":{"__typename":"InheritableStringSettingWithPossibleValues","key":"profile.language","value":"en-US","localValue":"en","possibleValues":["en-US"]}},"deleted":false},"Theme:customTheme1":{"__typename":"Theme","id":"customTheme1"},"AssociatedImage:{\"url\":\"https://community.hughesnet.com/t5/s/ssqng67387/images/bi0xMS1qUHA3ZXA?image-coordinates=0%2C0%2C130%2C130\"}":{"__typename":"AssociatedImage","url":"https://community.hughesnet.com/t5/s/ssqng67387/images/bi0xMS1qUHA3ZXA?image-coordinates=0%2C0%2C130%2C130","mimeType":"image/png"},"Category:category:HNSupport":{"__typename":"Category","id":"category:HNSupport","entityType":"CATEGORY","displayId":"HNSupport","nodeType":"category","depth":1,"title":"Hughesnet Support Community","shortTitle":"Hughesnet Support Community","parent":{"__ref":"Category:category:top"}},"Category:category:top":{"__typename":"Category","id":"category:top","displayId":"top","nodeType":"category","depth":0,"title":"Top","entityType":"CATEGORY","shortTitle":"Top"},"Forum:board:TechSupport":{"__typename":"Forum","id":"board:TechSupport","entityType":"FORUM","displayId":"TechSupport","nodeType":"board","depth":2,"conversationStyle":"FORUM","title":"Tech Support","description":"Tips and tricks to getting the most out of your Hughesnet internet and Hughesnet Voice services.","avatar":{"__ref":"AssociatedImage:{\"url\":\"https://community.hughesnet.com/t5/s/ssqng67387/images/bi0xMS1qUHA3ZXA?image-coordinates=0%2C0%2C130%2C130\"}"},"profileSettings":{"__typename":"ProfileSettings","language":null},"parent":{"__ref":"Category:category:HNSupport"},"ancestors":{"__typename":"CoreNodeConnection","edges":[{"__typename":"CoreNodeEdge","node":{"__ref":"Community:community:ssqng67387"}},{"__typename":"CoreNodeEdge","node":{"__ref":"Category:category:HNSupport"}}]},"userContext":{"__typename":"NodeUserContext","canAddAttachments":false,"canUpdateNode":false,"canPostMessages":false,"isSubscribed":false},"boardPolicies":{"__typename":"BoardPolicies","canPublishArticleOnCreate":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.forums.policy_can_publish_on_create_workflow_action.accessDenied","key":"error.lithium.policies.forums.policy_can_publish_on_create_workflow_action.accessDenied","args":[]}}},"shortTitle":"Tech Support","repliesProperties":{"__typename":"RepliesProperties","sortOrder":"PUBLISH_TIME","repliesFormat":"threaded"},"eventPath":"category:HNSupport/community:ssqng67387board:TechSupport/","tagProperties":{"__typename":"TagNodeProperties","tagsEnabled":{"__typename":"PolicyResult","failureReason":null}},"requireTags":true,"tagType":"PRESET_ONLY","description@stripHtml":"Tips and tricks to getting the most out of your Hughesnet internet and Hughesnet Voice services."},"Rank:rank:19":{"__typename":"Rank","id":"rank:19","position":20,"name":"Junior","color":"009900","icon":null,"rankStyle":"TEXT"},"User:user:24839":{"__typename":"User","id":"user:24839","uid":24839,"login":"bos2420","deleted":false,"avatar":{"__typename":"UserAvatar","url":"https://community.hughesnet.com/t5/s/ssqng67387/m_assets/avatars/default/avatar-8.svg"},"rank":{"__ref":"Rank:rank:19"},"email":"","messagesCount":51,"biography":null,"topicsCount":4,"kudosReceivedCount":10,"kudosGivenCount":0,"kudosWeight":1,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2015-08-19T03:00:00.000-04:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"followersCount":null,"solutionsCount":1,"ssoId":null,"entityType":"USER","eventPath":"community:ssqng67387/user:24839"},"ForumTopicMessage:message:111048":{"__typename":"ForumTopicMessage","uid":111048,"subject":"Connection Problems- Only with AOL","id":"message:111048","revisionNum":1,"repliesCount":52,"author":{"__ref":"User:user:24839"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:TechSupport"},"conversation":{"__ref":"Conversation:conversation:111048"},"readOnly":true,"editFrozen":false,"moderationData":{"__ref":"ModerationData:moderation_data:111048"},"body@stripHtml({\"truncateLength\":200})":" The problem started a week to 10 days ago.  I can not connect to AOL via my hughes Gen5 connection.  We both use aol mail (yes, I know there are better options, and I may look into that, but when you...","body@stringLength":"2429","rawBody":"
The problem started a week to 10 days ago.  I can not connect to AOL via my hughes Gen5 connection.  We both use aol mail (yes, I know there are better options, and I may look into that, but when you have had the same address forever, switching is hard to do)
Now, not only can I/we not connect to our mail, we also can not connect to aol.com (main website)  I thought this might be a router problem, as a couple of other websites were pretty slow.  Just put in a new TP-Link AC1200.  It is working fine.  All other websites come up quickly.  Running Win10.  This is happening on ALL of our computers, 3 laptops and this decktop.  When trying to connect, I get the \"This site can't be reached.  Mail.aol.com took too long to respond\".  This desktop is running wired through the router, the other computers are running wireless.
When I break the phones out, and go to the 'mobil hotspot route', we can connect.  Again, on all 4 computers.
We have exceeded our download allowance, but we are working on 7 gigs of purchased allowance.  Regardless of that, this started when we were still in our allowance, and it happens during 'Bonus Time', so I do not think it is an 'allowance' problem.
I am pretty computer literate, so this isn't a basic knowledge issue (I hope).  I have also torn up Google looking for answers.  There was something about disabling the IPv6 settings.  No joy.  Then there was something about changing the IPv4 settings and going to a directed DNS Server address.  Tried that also.  No good.
Wife, who is NOT computer literate, suggested a System Restore.  I do not think that will work, but I was halfway through this post when she brought it up.  I will try that, and come back if it works.  Otherwise, assume it didn't.  Can't think it would anyway, unless there is some virus that infected all 4 computers, through Malware Byes, and is specific to Hughes not connecting to AOL.
So, short story, in review.  Can not connect via Hughes to any form of AOL (including the help articles listed in Google searches)  If it says AOL in the address, it will not load.  It WILL load via a phones' mobil hotspot.
","kudosSumWeight":0,"postTime":"2019-03-26T00:42:47.475-04:00","images":{"__typename":"AssociatedImageConnection","edges":[],"totalCount":0,"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"attachments":{"__typename":"AttachmentConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"tags":{"__typename":"TagConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[{"__typename":"TagEdge","cursor":"MjQuMTF8Mi4xfG98MTB8X05WX3wx","node":{"__typename":"Tag","id":"tag:Performance","text":"Performance","time":"2017-03-09T08:01:18.409-05:00","lastActivityTime":null,"messagesCount":null,"followersCount":null}}]},"timeToRead":2,"currentRevision":{"__ref":"Revision:revision:111048_1"},"latestVersion":null,"metrics":{"__typename":"MessageMetrics","views":24520},"visibilityScope":"PUBLIC","canonicalUrl":null,"seoTitle":null,"seoDescription":null,"isEscalated":null,"placeholder":false,"originalMessageForPlaceholder":null,"messagePolicies":{"__typename":"MessagePolicies","canModerateSpamMessage":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","key":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","args":[]}}},"archivalData":null,"customFields":[]},"Conversation:conversation:111048":{"__typename":"Conversation","id":"conversation:111048","solved":true,"topic":{"__ref":"ForumTopicMessage:message:111048"},"lastPostingActivityTime":"2020-02-29T20:46:03.721-05:00","lastPostTime":"2020-02-29T20:46:03.721-05:00","unreadReplyCount":52,"isSubscribed":false},"ModerationData:moderation_data:111048":{"__typename":"ModerationData","id":"moderation_data:111048","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"Revision:revision:111048_1":{"__typename":"Revision","id":"revision:111048_1","lastEditTime":"2019-03-26T00:42:47.475-04:00"},"ForumReplyMessage:message:111123":{"__typename":"ForumReplyMessage","id":"message:111123","conversation":{"__ref":"Conversation:conversation:111048"},"author":{"__ref":"User:user:24839"},"revisionNum":1,"uid":111123,"depth":14,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:TechSupport"},"subject":"Re: Connection Problems- Only with AOL","readOnly":true,"editFrozen":false,"moderationData":{"__ref":"ModerationData:moderation_data:111123"},"parent":{"__ref":"ForumReplyMessage:message:111122"},"body":"
Is there a trick to getting the app on a Win10 laptop?  I can see how to get it for my phones.  I must be doing something wrong.  Can't find how to authorize my laptop with Google Play.
(I don't use many (if any) apps on Win10)  Use em all the time on the phone.
","body@stringLength":"307","rawBody":"
","kudosSumWeight":0,"repliesCount":11,"postTime":"2019-03-28T15:41:06.058-04:00","images":{"__typename":"AssociatedImageConnection","edges":[],"totalCount":0,"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"attachments":{"__typename":"AttachmentConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"timeToRead":1,"currentRevision":{"__ref":"Revision:revision:111123_1"},"latestVersion":null,"metrics":{"__typename":"MessageMetrics","views":10474},"visibilityScope":"PUBLIC","isEscalated":null,"placeholder":false,"originalMessageForPlaceholder":null,"messagePolicies":{"__typename":"MessagePolicies","canModerateSpamMessage":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","key":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","args":[]}}},"customFields":[],"descendants":{"__typename":"MessageConnection","edges":[{"__typename":"MessageEdge","cursor":"MjQuMTF8Mi4xfGl8MjV8Mzk6MXxpbnQsMTExMTI0LDExMTEyNA","node":{"__ref":"ForumReplyMessage:message:111124"}},{"__typename":"MessageEdge","cursor":"MjQuMTF8Mi4xfGl8MjV8Mzk6MXxpbnQsMTExMTI0LDExMTEyNQ","node":{"__ref":"ForumReplyMessage:message:111125"}},{"__typename":"MessageEdge","cursor":"MjQuMTF8Mi4xfGl8MjV8Mzk6MXxpbnQsMTExMTI0LDExMTEyNg","node":{"__ref":"ForumReplyMessage:message:111126"}},{"__typename":"MessageEdge","cursor":"MjQuMTF8Mi4xfGl8MjV8Mzk6MXxpbnQsMTExMTI0LDExMTEyOA","node":{"__ref":"ForumReplyMessage:message:111128"}},{"__typename":"MessageEdge","cursor":"MjQuMTF8Mi4xfGl8MjV8Mzk6MXxpbnQsMTExMTI0LDExMTEzMw","node":{"__ref":"AcceptedSolutionMessage:message:111133"}},{"__typename":"MessageEdge","cursor":"MjQuMTF8Mi4xfGl8MjV8Mzk6MXxpbnQsMTExMTI0LDExMTIzNQ","node":{"__ref":"ForumReplyMessage:message:111235"}},{"__typename":"MessageEdge","cursor":"MjQuMTF8Mi4xfGl8MjV8Mzk6MXxpbnQsMTExMTI0LDExMTIzOA","node":{"__ref":"ForumReplyMessage:message:111238"}},{"__typename":"MessageEdge","cursor":"MjQuMTF8Mi4xfGl8MjV8Mzk6MXxpbnQsMTExMTI0LDExMTQxMQ","node":{"__ref":"ForumReplyMessage:message:111411"}},{"__typename":"MessageEdge","cursor":"MjQuMTF8Mi4xfGl8MjV8Mzk6MXxpbnQsMTExMTI0LDExMTQxMg","node":{"__ref":"ForumReplyMessage:message:111412"}},{"__typename":"MessageEdge","cursor":"MjQuMTF8Mi4xfGl8MjV8Mzk6MXxpbnQsMTExMTI0LDExMTQxMw","node":{"__ref":"ForumReplyMessage:message:111413"}},{"__typename":"MessageEdge","cursor":"MjQuMTF8Mi4xfGl8MjV8Mzk6MXxpbnQsMTExMTI0LDExMTQxNg","node":{"__ref":"ForumReplyMessage:message:111416"}}],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}}},"CachedAsset:theme:customTheme1-1736251114261":{"__typename":"CachedAsset","id":"theme:customTheme1-1736251114261","value":{"id":"customTheme1","animation":{"fast":"150ms","normal":"250ms","slow":"500ms","slowest":"750ms","function":"cubic-bezier(0.07, 0.91, 0.51, 1)","__typename":"AnimationThemeSettings"},"avatar":{"borderRadius":"50%","collections":["default"],"__typename":"AvatarThemeSettings"},"basics":{"browserIcon":{"imageAssetName":"rebrand-favicon-1721032736485.png","imageLastModified":"1721032741408","__typename":"ThemeAsset"},"customerLogo":{"imageAssetName":"HughesnetLogo-1721027846492.png","imageLastModified":"1721027849927","__typename":"ThemeAsset"},"maximumWidthOfPageContent":"1200px","oneColumnNarrowWidth":"800px","gridGutterWidthMd":"30px","gridGutterWidthXs":"10px","pageWidthStyle":"WIDTH_OF_BROWSER","__typename":"BasicsThemeSettings"},"buttons":{"borderRadiusSm":"100vw","borderRadius":"100vw","borderRadiusLg":"100vw","paddingY":"5px","paddingYLg":"7px","paddingYHero":"var(--lia-bs-btn-padding-y-lg)","paddingX":"22px","paddingXLg":"24px","paddingXHero":"56px","fontStyle":"NORMAL","fontWeight":"400","textTransform":"NONE","disabledOpacity":0.5,"primaryTextColor":"var(--lia-bs-white)","primaryTextHoverColor":"var(--lia-bs-white)","primaryTextActiveColor":"var(--lia-bs-white)","primaryBgColor":"var(--lia-bs-primary)","primaryBgHoverColor":"hsl(var(--lia-bs-primary-h), var(--lia-bs-primary-s), calc(var(--lia-bs-primary-l) * 0.85))","primaryBgActiveColor":"hsl(var(--lia-bs-primary-h), var(--lia-bs-primary-s), calc(var(--lia-bs-primary-l) * 0.7))","primaryBorder":"1px solid transparent","primaryBorderHover":"1px solid transparent","primaryBorderActive":"1px solid transparent","primaryBorderFocus":"1px solid var(--lia-bs-white)","primaryBoxShadowFocus":"0 0 0 1px var(--lia-bs-primary), 0 0 0 4px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","secondaryTextColor":"var(--lia-bs-gray-900)","secondaryTextHoverColor":"hsl(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), calc(var(--lia-bs-gray-900-l) * 0.95))","secondaryTextActiveColor":"hsl(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), calc(var(--lia-bs-gray-900-l) * 0.9))","secondaryBgColor":"var(--lia-bs-gray-200)","secondaryBgHoverColor":"hsl(var(--lia-bs-gray-200-h), var(--lia-bs-gray-200-s), calc(var(--lia-bs-gray-200-l) * 0.96))","secondaryBgActiveColor":"hsl(var(--lia-bs-gray-200-h), var(--lia-bs-gray-200-s), calc(var(--lia-bs-gray-200-l) * 0.92))","secondaryBorder":"1px solid transparent","secondaryBorderHover":"1px solid transparent","secondaryBorderActive":"1px solid transparent","secondaryBorderFocus":"1px solid transparent","secondaryBoxShadowFocus":"0 0 0 1px var(--lia-bs-primary), 0 0 0 4px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","tertiaryTextColor":"var(--lia-bs-gray-900)","tertiaryTextHoverColor":"hsl(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), calc(var(--lia-bs-gray-900-l) * 0.95))","tertiaryTextActiveColor":"hsl(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), calc(var(--lia-bs-gray-900-l) * 0.9))","tertiaryBgColor":"transparent","tertiaryBgHoverColor":"transparent","tertiaryBgActiveColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.04)","tertiaryBorder":"1px solid transparent","tertiaryBorderHover":"1px solid hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.08)","tertiaryBorderActive":"1px solid transparent","tertiaryBorderFocus":"1px solid transparent","tertiaryBoxShadowFocus":"0 0 0 1px var(--lia-bs-primary), 0 0 0 4px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","destructiveTextColor":"var(--lia-bs-danger)","destructiveTextHoverColor":"hsl(var(--lia-bs-danger-h), var(--lia-bs-danger-s), calc(var(--lia-bs-danger-l) * 0.95))","destructiveTextActiveColor":"hsl(var(--lia-bs-danger-h), var(--lia-bs-danger-s), calc(var(--lia-bs-danger-l) * 0.9))","destructiveBgColor":"var(--lia-bs-gray-200)","destructiveBgHoverColor":"hsl(var(--lia-bs-gray-200-h), var(--lia-bs-gray-200-s), calc(var(--lia-bs-gray-200-l) * 0.96))","destructiveBgActiveColor":"hsl(var(--lia-bs-gray-200-h), var(--lia-bs-gray-200-s), calc(var(--lia-bs-gray-200-l) * 0.92))","destructiveBorder":"1px solid transparent","destructiveBorderHover":"1px solid transparent","destructiveBorderActive":"1px solid transparent","destructiveBorderFocus":"1px solid transparent","destructiveBoxShadowFocus":"0 0 0 1px var(--lia-bs-primary), 0 0 0 4px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","__typename":"ButtonsThemeSettings"},"border":{"color":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.08)","mainContent":"DARK","sideContent":"DARK","radiusSm":"3px","radius":"5px","radiusLg":"9px","radius50":"100vw","__typename":"BorderThemeSettings"},"boxShadow":{"xs":"0 0 0 1px hsla(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), var(--lia-bs-gray-900-l), 0.08), 0 3px 0 -1px hsla(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), var(--lia-bs-gray-900-l), 0.16)","sm":"0 2px 4px hsla(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), var(--lia-bs-gray-900-l), 0.12)","md":"0 5px 15px hsla(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), var(--lia-bs-gray-900-l), 0.3)","lg":"0 10px 30px hsla(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), var(--lia-bs-gray-900-l), 0.3)","__typename":"BoxShadowThemeSettings"},"cards":{"bgColor":"var(--lia-panel-bg-color)","borderRadius":"var(--lia-panel-border-radius)","boxShadow":"var(--lia-box-shadow-xs)","__typename":"CardsThemeSettings"},"chip":{"maxWidth":"300px","height":"30px","__typename":"ChipThemeSettings"},"coreTypes":{"defaultMessageLinkColor":"#005DAC","defaultMessageLinkDecoration":"none","defaultMessageLinkFontStyle":"NORMAL","defaultMessageLinkFontWeight":"400","defaultMessageFontStyle":"NORMAL","defaultMessageFontWeight":"400","forumColor":"#4099E2","forumFontFamily":"var(--lia-bs-font-family-base)","forumFontWeight":"var(--lia-default-message-font-weight)","forumLineHeight":"var(--lia-bs-line-height-base)","forumFontStyle":"var(--lia-default-message-font-style)","forumMessageLinkColor":"var(--lia-default-message-link-color)","forumMessageLinkDecoration":"var(--lia-default-message-link-decoration)","forumMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","forumMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","forumSolvedColor":"#148563","blogColor":"#1CBAA0","blogFontFamily":"var(--lia-bs-font-family-base)","blogFontWeight":"var(--lia-default-message-font-weight)","blogLineHeight":"1.75","blogFontStyle":"var(--lia-default-message-font-style)","blogMessageLinkColor":"var(--lia-default-message-link-color)","blogMessageLinkDecoration":"var(--lia-default-message-link-decoration)","blogMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","blogMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","tkbColor":"#4C6B90","tkbFontFamily":"var(--lia-bs-font-family-base)","tkbFontWeight":"var(--lia-default-message-font-weight)","tkbLineHeight":"1.75","tkbFontStyle":"var(--lia-default-message-font-style)","tkbMessageLinkColor":"var(--lia-default-message-link-color)","tkbMessageLinkDecoration":"var(--lia-default-message-link-decoration)","tkbMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","tkbMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","qandaColor":"#4099E2","qandaFontFamily":"var(--lia-bs-font-family-base)","qandaFontWeight":"var(--lia-default-message-font-weight)","qandaLineHeight":"var(--lia-bs-line-height-base)","qandaFontStyle":"var(--lia-default-message-link-font-style)","qandaMessageLinkColor":"var(--lia-default-message-link-color)","qandaMessageLinkDecoration":"var(--lia-default-message-link-decoration)","qandaMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","qandaMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","qandaSolvedColor":"#3FA023","ideaColor":"#FF8000","ideaFontFamily":"var(--lia-bs-font-family-base)","ideaFontWeight":"var(--lia-default-message-font-weight)","ideaLineHeight":"var(--lia-bs-line-height-base)","ideaFontStyle":"var(--lia-default-message-font-style)","ideaMessageLinkColor":"var(--lia-default-message-link-color)","ideaMessageLinkDecoration":"var(--lia-default-message-link-decoration)","ideaMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","ideaMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","contestColor":"#FCC845","contestFontFamily":"var(--lia-bs-font-family-base)","contestFontWeight":"var(--lia-default-message-font-weight)","contestLineHeight":"var(--lia-bs-line-height-base)","contestFontStyle":"var(--lia-default-message-link-font-style)","contestMessageLinkColor":"var(--lia-default-message-link-color)","contestMessageLinkDecoration":"var(--lia-default-message-link-decoration)","contestMessageLinkFontStyle":"ITALIC","contestMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","occasionColor":"#D13A1F","occasionFontFamily":"var(--lia-bs-font-family-base)","occasionFontWeight":"var(--lia-default-message-font-weight)","occasionLineHeight":"var(--lia-bs-line-height-base)","occasionFontStyle":"var(--lia-default-message-font-style)","occasionMessageLinkColor":"var(--lia-default-message-link-color)","occasionMessageLinkDecoration":"var(--lia-default-message-link-decoration)","occasionMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","occasionMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","grouphubColor":"#333333","categoryColor":"#949494","communityColor":"#FFFFFF","productColor":"#949494","__typename":"CoreTypesThemeSettings"},"colors":{"black":"#000000","white":"#FFFFFF","gray100":"#F7F7F7","gray200":"#F7F7F7","gray300":"#E8E8E8","gray400":"#D9D9D9","gray500":"#CCCCCC","gray600":"#949494","gray700":"#707070","gray800":"#545454","gray900":"#333333","dark":"#545454","light":"#F7F7F7","primary":"#005DAC","secondary":"#333333","bodyText":"#000000","bodyBg":"#F7F7F8","info":"#409AE2","success":"#41C5AE","warning":"#FCB116","danger":"#DE3700","alertSystem":"#FF6600","textMuted":"#707070","highlight":"#FFFCAD","outline":"var(--lia-bs-primary)","custom":["#00223A","#0096FA","#0E4275","#005DAC","#1C475A","#00223A","#0E4275","#FF0000","#0099AA","#582596","#660099","#0000FF","#0066FF","#006600","#009900","#00CC00","#33CC00"],"__typename":"ColorsThemeSettings"},"divider":{"size":"3px","marginLeft":"4px","marginRight":"4px","borderRadius":"50%","bgColor":"var(--lia-bs-gray-600)","bgColorActive":"var(--lia-bs-gray-600)","__typename":"DividerThemeSettings"},"dropdown":{"fontSize":"var(--lia-bs-font-size-sm)","borderColor":"var(--lia-bs-border-color)","borderRadius":"var(--lia-bs-border-radius-sm)","dividerBg":"var(--lia-bs-gray-300)","itemPaddingY":"5px","itemPaddingX":"20px","headerColor":"var(--lia-bs-gray-700)","__typename":"DropdownThemeSettings"},"email":null,"emoji":{"skinToneDefault":"#ffcd43","skinToneLight":"#fae3c5","skinToneMediumLight":"#e2cfa5","skinToneMedium":"#daa478","skinToneMediumDark":"#a78058","skinToneDark":"#5e4d43","__typename":"EmojiThemeSettings"},"heading":{"color":"var(--lia-bs-body-color)","fontFamily":"Montserrat","fontStyle":"NORMAL","fontWeight":"700","h1FontSize":"34px","h2FontSize":"28px","h3FontSize":"18px","h4FontSize":"18px","h5FontSize":"18px","h6FontSize":"18px","lineHeight":"1.3","subHeaderFontSize":"11px","subHeaderFontWeight":"500","h1LetterSpacing":"normal","h2LetterSpacing":"normal","h3LetterSpacing":"normal","h4LetterSpacing":"normal","h5LetterSpacing":"normal","h6LetterSpacing":"normal","subHeaderLetterSpacing":"2px","h1FontWeight":"var(--lia-bs-headings-font-weight)","h2FontWeight":"var(--lia-bs-headings-font-weight)","h3FontWeight":"var(--lia-bs-headings-font-weight)","h4FontWeight":"var(--lia-bs-headings-font-weight)","h5FontWeight":"var(--lia-bs-headings-font-weight)","h6FontWeight":"var(--lia-bs-headings-font-weight)","__typename":"HeadingThemeSettings"},"icons":{"size10":null,"size12":"12px","size14":"14px","size16":"16px","size20":"20px","size24":"24px","size30":"30px","size40":"40px","size50":"50px","size60":"60px","size80":"80px","size120":"120px","size160":"160px","__typename":"IconsThemeSettings"},"imagePreview":{"bgColor":"var(--lia-bs-gray-900)","titleColor":"var(--lia-bs-white)","controlColor":"var(--lia-bs-white)","controlBgColor":"var(--lia-bs-gray-800)","__typename":"ImagePreviewThemeSettings"},"input":{"borderColor":"var(--lia-bs-gray-600)","disabledColor":"var(--lia-bs-gray-600)","focusBorderColor":"var(--lia-bs-primary)","labelMarginBottom":"10px","btnFontSize":"var(--lia-bs-font-size-sm)","focusBoxShadow":"0 0 0 3px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","checkLabelMarginBottom":"2px","checkboxBorderRadius":"3px","borderRadiusSm":"100vw","borderRadius":"100vw","borderRadiusLg":"100vw","formTextMarginTop":"4px","textAreaBorderRadius":"20px","activeFillColor":"var(--lia-bs-primary)","__typename":"InputThemeSettings"},"loading":{"dotDarkColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.2)","dotLightColor":"hsla(var(--lia-bs-white-h), var(--lia-bs-white-s), var(--lia-bs-white-l), 0.5)","barDarkColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.06)","barLightColor":"hsla(var(--lia-bs-white-h), var(--lia-bs-white-s), var(--lia-bs-white-l), 0.4)","__typename":"LoadingThemeSettings"},"link":{"color":"var(--lia-bs-primary)","hoverColor":"hsl(var(--lia-bs-primary-h), var(--lia-bs-primary-s), calc(var(--lia-bs-primary-l) - 10%))","decoration":"none","hoverDecoration":"underline","__typename":"LinkThemeSettings"},"listGroup":{"itemPaddingY":"15px","itemPaddingX":"15px","borderColor":"var(--lia-bs-gray-300)","__typename":"ListGroupThemeSettings"},"modal":{"contentTextColor":"var(--lia-bs-body-color)","contentBg":"var(--lia-bs-white)","backgroundBg":"var(--lia-bs-black)","smSize":"440px","mdSize":"760px","lgSize":"1080px","backdropOpacity":0.3,"contentBoxShadowXs":"var(--lia-bs-box-shadow-sm)","contentBoxShadow":"var(--lia-bs-box-shadow)","headerFontWeight":"700","__typename":"ModalThemeSettings"},"navbar":{"position":"FIXED","background":{"attachment":null,"clip":null,"color":"var(--lia-bs-white)","imageAssetName":"","imageLastModified":"0","origin":null,"position":"CENTER_CENTER","repeat":"NO_REPEAT","size":"COVER","__typename":"BackgroundProps"},"backgroundOpacity":0.8,"paddingTop":"15px","paddingBottom":"15px","borderBottom":"1px solid var(--lia-bs-border-color)","boxShadow":"var(--lia-bs-box-shadow-sm)","brandMarginRight":"30px","brandMarginRightSm":"10px","brandLogoHeight":"30px","linkGap":"10px","linkJustifyContent":"flex-start","linkPaddingY":"5px","linkPaddingX":"10px","linkDropdownPaddingY":"9px","linkDropdownPaddingX":"var(--lia-nav-link-px)","linkColor":"var(--lia-bs-body-color)","linkHoverColor":"var(--lia-bs-primary)","linkFontSize":"var(--lia-bs-font-size-sm)","linkFontStyle":"NORMAL","linkFontWeight":"400","linkTextTransform":"NONE","linkLetterSpacing":"normal","linkBorderRadius":"var(--lia-bs-border-radius-sm)","linkBgColor":"transparent","linkBgHoverColor":"transparent","linkBorder":"none","linkBorderHover":"none","linkBoxShadow":"none","linkBoxShadowHover":"none","linkTextBorderBottom":"none","linkTextBorderBottomHover":"none","dropdownPaddingTop":"10px","dropdownPaddingBottom":"15px","dropdownPaddingX":"10px","dropdownMenuOffset":"2px","dropdownDividerMarginTop":"10px","dropdownDividerMarginBottom":"10px","dropdownBorderColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.08)","controllerBgHoverColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.1)","controllerIconColor":"var(--lia-bs-body-color)","controllerIconHoverColor":"var(--lia-bs-body-color)","controllerTextColor":"var(--lia-nav-controller-icon-color)","controllerTextHoverColor":"var(--lia-nav-controller-icon-hover-color)","controllerHighlightColor":"hsla(30, 100%, 50%)","controllerHighlightTextColor":"var(--lia-yiq-light)","controllerBorderRadius":"var(--lia-border-radius-50)","hamburgerColor":"var(--lia-nav-controller-icon-color)","hamburgerHoverColor":"var(--lia-nav-controller-icon-color)","hamburgerBgColor":"transparent","hamburgerBgHoverColor":"transparent","hamburgerBorder":"none","hamburgerBorderHover":"none","collapseMenuMarginLeft":"20px","collapseMenuDividerBg":"var(--lia-nav-link-color)","collapseMenuDividerOpacity":0.16,"__typename":"NavbarThemeSettings"},"pager":{"textColor":"var(--lia-bs-link-color)","textFontWeight":"var(--lia-font-weight-md)","textFontSize":"var(--lia-bs-font-size-sm)","__typename":"PagerThemeSettings"},"panel":{"bgColor":"var(--lia-bs-white)","borderRadius":"var(--lia-bs-border-radius)","borderColor":"var(--lia-bs-border-color)","boxShadow":"none","__typename":"PanelThemeSettings"},"popover":{"arrowHeight":"8px","arrowWidth":"16px","maxWidth":"300px","minWidth":"100px","headerBg":"var(--lia-bs-white)","borderColor":"var(--lia-bs-border-color)","borderRadius":"var(--lia-bs-border-radius)","boxShadow":"0 0.5rem 1rem hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.15)","__typename":"PopoverThemeSettings"},"prism":{"color":"#000000","bgColor":"#f5f2f0","fontFamily":"var(--font-family-monospace)","fontSize":"var(--lia-bs-font-size-base)","fontWeightBold":"var(--lia-bs-font-weight-bold)","fontStyleItalic":"italic","tabSize":2,"highlightColor":"#b3d4fc","commentColor":"#62707e","punctuationColor":"#6f6f6f","namespaceOpacity":"0.7","propColor":"#990055","selectorColor":"#517a00","operatorColor":"#906736","operatorBgColor":"hsla(0, 0%, 100%, 0.5)","keywordColor":"#0076a9","functionColor":"#d3284b","variableColor":"#c14700","__typename":"PrismThemeSettings"},"rte":{"bgColor":"var(--lia-bs-white)","borderRadius":"var(--lia-panel-border-radius)","boxShadow":" var(--lia-panel-box-shadow)","customColor1":"#bfedd2","customColor2":"#fbeeb8","customColor3":"#f8cac6","customColor4":"#eccafa","customColor5":"#c2e0f4","customColor6":"#2dc26b","customColor7":"#f1c40f","customColor8":"#e03e2d","customColor9":"#b96ad9","customColor10":"#3598db","customColor11":"#169179","customColor12":"#e67e23","customColor13":"#ba372a","customColor14":"#843fa1","customColor15":"#236fa1","customColor16":"#ecf0f1","customColor17":"#ced4d9","customColor18":"#95a5a6","customColor19":"#7e8c8d","customColor20":"#34495e","customColor21":"#000000","customColor22":"#ffffff","defaultMessageHeaderMarginTop":"15px","defaultMessageHeaderMarginBottom":"15px","defaultMessageItemMarginTop":"0","defaultMessageItemMarginBottom":"16px","diffAddedColor":"hsla(170, 53%, 51%, 0.4)","diffChangedColor":"hsla(43, 97%, 63%, 0.4)","diffNoneColor":"hsla(0, 0%, 80%, 0.4)","diffRemovedColor":"hsla(9, 74%, 47%, 0.4)","specialMessageHeaderMarginTop":"15px","specialMessageHeaderMarginBottom":"15px","specialMessageItemMarginTop":"0","specialMessageItemMarginBottom":"16px","__typename":"RteThemeSettings"},"tags":{"bgColor":"var(--lia-bs-gray-200)","bgHoverColor":"var(--lia-bs-gray-400)","borderRadius":"var(--lia-bs-border-radius-sm)","color":"var(--lia-bs-body-color)","hoverColor":"var(--lia-bs-body-color)","fontWeight":"var(--lia-font-weight-md)","fontSize":"var(--lia-font-size-xxs)","textTransform":"UPPERCASE","letterSpacing":"0.5px","__typename":"TagsThemeSettings"},"toasts":{"borderRadius":"var(--lia-bs-border-radius)","paddingX":"12px","__typename":"ToastsThemeSettings"},"typography":{"fontFamilyBase":"Source Sans Pro","fontStyleBase":"NORMAL","fontWeightBase":"400","fontWeightLight":"300","fontWeightNormal":"400","fontWeightMd":"500","fontWeightBold":"700","letterSpacingSm":"normal","letterSpacingXs":"normal","lineHeightBase":"1.5","fontSizeBase":"16px","fontSizeXxs":"11px","fontSizeXs":"14px","fontSizeSm":"15px","fontSizeLg":"20px","fontSizeXl":"24px","smallFontSize":"14px","customFonts":[{"source":"SERVER","name":"Axiforma-Regular","styles":[{"style":"NORMAL","weight":"400","__typename":"FontStyleData"}],"assetNames":["Axiforma-Regular-normal-400.woff2"],"__typename":"CustomFont"},{"source":"SERVER","name":"Source Sans Pro","styles":[{"style":"NORMAL","weight":"400","__typename":"FontStyleData"}],"assetNames":["SourceSansPro-normal-400.woff2"],"__typename":"CustomFont"}],"__typename":"TypographyThemeSettings"},"unstyledListItem":{"marginBottomSm":"5px","marginBottomMd":"10px","marginBottomLg":"15px","marginBottomXl":"20px","marginBottomXxl":"25px","__typename":"UnstyledListItemThemeSettings"},"yiq":{"light":"#ffffff","dark":"#000000","__typename":"YiqThemeSettings"},"colorLightness":{"primaryDark":0.36,"primaryLight":0.74,"primaryLighter":0.89,"primaryLightest":0.95,"infoDark":0.39,"infoLight":0.72,"infoLighter":0.85,"infoLightest":0.93,"successDark":0.24,"successLight":0.62,"successLighter":0.8,"successLightest":0.91,"warningDark":0.39,"warningLight":0.68,"warningLighter":0.84,"warningLightest":0.93,"dangerDark":0.41,"dangerLight":0.72,"dangerLighter":0.89,"dangerLightest":0.95,"__typename":"ColorLightnessThemeSettings"},"localOverride":false,"__typename":"Theme"},"localOverride":false},"CachedAsset:text:en_US-components/common/EmailVerification-1728282321000":{"__typename":"CachedAsset","id":"text:en_US-components/common/EmailVerification-1728282321000","value":{"email.verification.title":"Email Verification Required","email.verification.message.update.email":"To participate in the community, you must first verify your email address. The verification email was sent to {email}. To change your email, visit My Settings.","email.verification.message.resend.email":"To participate in the community, you must first verify your email address. The verification email was sent to {email}. Resend email."},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/common/Loading/LoadingDot-1728282321000":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/common/Loading/LoadingDot-1728282321000","value":{"title":"Loading..."},"localOverride":false},"CachedAsset:quilt:hughes.prod:pages/forums/ForumMessagePage:board:TechSupport-1736251112425":{"__typename":"CachedAsset","id":"quilt:hughes.prod:pages/forums/ForumMessagePage:board:TechSupport-1736251112425","value":{"id":"ForumMessagePage","container":{"id":"Common","headerProps":{"backgroundImageProps":null,"backgroundColor":null,"addComponents":null,"removeComponents":["community.widget.bannerWidget"],"componentOrder":null,"__typename":"QuiltContainerSectionProps"},"headerComponentProps":{"community.widget.breadcrumbWidget":{"disableLastCrumbForDesktop":false}},"footerProps":null,"footerComponentProps":null,"items":[{"id":"message-list","layout":"MAIN_SIDE","bgColor":null,"showTitle":null,"showDescription":null,"textPosition":null,"textColor":null,"sectionEditLevel":null,"bgImage":null,"disableSpacing":null,"edgeToEdgeDisplay":null,"fullHeight":null,"showBorder":null,"__typename":"MainSideQuiltSection","columnMap":{"main":[{"id":"messages.widget.topicWithThreadedReplyListWidget","className":"lia-topic-with-replies","props":{"editLevel":"CONFIGURE"},"__typename":"QuiltComponent"}],"side":[{"id":"messages.widget.relatedContentWidget","className":null,"props":null,"__typename":"QuiltComponent"},{"id":"messages.widget.messageListForNodeByRecentActivityWidget","className":null,"props":{"hideIfEmpty":true,"useTitle":true,"showTabs":false,"pageSize":5,"pagerVariant":{"type":"loadMore"},"style":"compact","viewVariant":{"type":"inline","props":{"useRepliesCount":false,"useMedia":false,"useAuthorRank":false,"useNode":false,"boardIconSize":"24","truncateBodyLength":-1,"useNodeLink":true,"usePreviewMedia":false,"timeStampType":"conversation.lastPostingActivityTime","avatarSize":"40","useTextBody":true,"useSolvedBadge":true,"subjectAs":"h6","renderPostTimeBeforeAuthor":true,"useAvatar":true,"useTimeToRead":false,"useSpoilerFreeBody":true,"useKudosCount":false,"useViewCount":false,"useBody":false,"useTags":false,"clampSubjectLines":1,"useBoardIcon":false,"useMessageTimeLink":true,"clampBodyLines":3,"useAuthorLogin":true,"useUnreadCount":false,"useNodeHoverCard":true,"useSearchSnippet":false}},"panelType":"divider","sorts":{"conversationLastPostingActivityTime":{"direction":"DESC"}}},"__typename":"QuiltComponent"},{"id":"custom.widget.MixPanelTracker","className":null,"props":{"widgetVisibility":"signedInOrAnonymous","useTitle":true,"useBackground":false,"title":"","lazyLoad":false},"__typename":"QuiltComponent"}],"__typename":"MainSideSectionColumns"}}],"__typename":"QuiltContainer"},"__typename":"Quilt","localOverride":false},"localOverride":false},"CachedAsset:text:en_US-pages/forums/ForumMessagePage-1728282321000":{"__typename":"CachedAsset","id":"text:en_US-pages/forums/ForumMessagePage-1728282321000","value":{"title":"{contextMessageSubject} | {communityTitle}","errorMissing":"This message cannot be found","name":"Forum Message Page","section.message-list.title":"Forum Discussion","archivedMessageTitle":"This Content Has Been Archived"},"localOverride":false},"CachedAsset:quiltWrapper:hughes.prod:Common:1736251050646":{"__typename":"CachedAsset","id":"quiltWrapper:hughes.prod:Common:1736251050646","value":{"id":"Common","header":{"backgroundImageProps":{"assetName":null,"backgroundSize":"COVER","backgroundRepeat":"NO_REPEAT","backgroundPosition":"CENTER_CENTER","lastModified":null,"__typename":"BackgroundImageProps"},"backgroundColor":"transparent","items":[{"id":"community.widget.navbarWidget","props":{"showUserName":false,"showRegisterLink":true,"useIconLanguagePicker":true,"useLabelLanguagePicker":true,"links":{"sideLinks":[],"mainLinks":[]},"className":"QuiltComponent_lia-component-edit-mode__0nCcm","style":{"boxShadow":"var(--lia-bs-box-shadow-sm)","linkFontWeight":"400","controllerHighlightColor":"hsla(30, 100%, 50%)","dropdownDividerMarginBottom":"10px","hamburgerBorderHover":"none","linkFontSize":"15px","linkBoxShadowHover":"none","backgroundOpacity":0.8,"controllerBorderRadius":"var(--lia-border-radius-50)","hamburgerBgColor":"transparent","linkTextBorderBottom":"none","hamburgerColor":"var(--lia-nav-controller-icon-color)","brandLogoHeight":"46px","linkLetterSpacing":"normal","linkBgHoverColor":"transparent","collapseMenuDividerOpacity":0.16,"paddingBottom":"10px","dropdownPaddingBottom":"15px","dropdownMenuOffset":"2px","hamburgerBgHoverColor":"transparent","borderBottom":"1px solid var(--lia-bs-border-color)","hamburgerBorder":"none","dropdownPaddingX":"10px","brandMarginRightSm":"10px","linkBoxShadow":"none","linkJustifyContent":"center","linkColor":"var(--lia-bs-primary)","collapseMenuDividerBg":"var(--lia-nav-link-color)","dropdownPaddingTop":"10px","controllerTextColor":"var(--lia-nav-controller-icon-color)","controllerHighlightTextColor":"var(--lia-yiq-dark)","background":{"imageAssetName":"","color":"var(--lia-bs-white)","size":"COVER","repeat":"NO_REPEAT","position":"CENTER_CENTER","imageLastModified":""},"linkBorderRadius":"var(--lia-bs-border-radius-sm)","linkHoverColor":"var(--lia-bs-primary)","position":"FIXED","linkBorder":"none","linkTextBorderBottomHover":"0","brandMarginRight":"30px","hamburgerHoverColor":"var(--lia-nav-controller-icon-color)","linkBorderHover":"none","collapseMenuMarginLeft":"20px","linkFontStyle":"NORMAL","linkPaddingX":"10px","controllerTextHoverColor":"var(--lia-nav-controller-icon-hover-color)","paddingTop":"10px","linkPaddingY":"5px","linkTextTransform":"NONE","dropdownBorderColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.08)","controllerBgHoverColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.1)","linkDropdownPaddingX":"var(--lia-nav-link-px)","linkBgColor":"transparent","linkDropdownPaddingY":"9px","controllerIconColor":"var(--lia-bs-body-color)","dropdownDividerMarginTop":"10px","linkGap":"10px","controllerIconHoverColor":"var(--lia-bs-body-color)"},"showSearchIcon":true,"languagePickerStyle":"iconAndLabel"},"__typename":"QuiltComponent"},{"id":"community.widget.breadcrumbWidget","props":{"backgroundColor":"var(--lia-bs-body-bg)","linkHighlightColor":"var(--lia-bs-primary)","visualEffects":{"showBottomBorder":true},"linkTextColor":"var(--lia-bs-body-color)"},"__typename":"QuiltComponent"},{"id":"community.widget.bannerWidget","props":{"backgroundColor":"var(--lia-bs-primary)","visualEffects":{"showBottomBorder":true},"backgroundOpacity":100,"backgroundImageProps":{"backgroundSize":"COVER","backgroundPosition":"CENTER_CENTER","backgroundRepeat":"NO_REPEAT"},"fontColor":"var(--lia-bs-body-bg)"},"__typename":"QuiltComponent"},{"id":"custom.widget.GoogleTagTracker","props":{"widgetVisibility":"signedInOrAnonymous","useTitle":true,"cProp_gtag":"G-JZZW630G5D","useBackground":false,"title":"","lazyLoad":false,"widgetChooser":"custom.widget.GoogleTagTracker"},"__typename":"QuiltComponent"}],"__typename":"QuiltWrapperSection"},"footer":{"backgroundImageProps":{"assetName":null,"backgroundSize":"COVER","backgroundRepeat":"NO_REPEAT","backgroundPosition":"CENTER_CENTER","lastModified":null,"__typename":"BackgroundImageProps"},"backgroundColor":"#00223A","items":[{"id":"custom.widget.custom_Footer","props":{"widgetVisibility":"signedInOrAnonymous","useTitle":true,"useBackground":false,"title":"","lazyLoad":false},"__typename":"QuiltComponent"}],"__typename":"QuiltWrapperSection"},"__typename":"QuiltWrapper","localOverride":false},"localOverride":false},"CachedAsset:text:en_US-components/common/ActionFeedback-1728282321000":{"__typename":"CachedAsset","id":"text:en_US-components/common/ActionFeedback-1728282321000","value":{"joinedGroupHub.title":"Welcome","joinedGroupHub.message":"You are now a member of this group and are subscribed to updates.","groupHubInviteNotFound.title":"Invitation Not Found","groupHubInviteNotFound.message":"Sorry, we could not find your invitation to the group. The owner may have canceled the invite.","groupHubNotFound.title":"Group Not Found","groupHubNotFound.message":"The grouphub you tried to join does not exist. It may have been deleted.","existingGroupHubMember.title":"Already Joined","existingGroupHubMember.message":"You are already a member of this group.","accountLocked.title":"Account Locked","accountLocked.message":"Your account has been locked due to multiple failed attempts. Try again in {lockoutTime} minutes.","editedGroupHub.title":"Changes Saved","editedGroupHub.message":"Your group has been updated.","leftGroupHub.title":"Goodbye","leftGroupHub.message":"You are no longer a member of this group and will not receive future updates.","deletedGroupHub.title":"Deleted","deletedGroupHub.message":"The group has been deleted.","groupHubCreated.title":"Group Created","groupHubCreated.message":"{groupHubName} is ready to use","accountClosed.title":"Account Closed","accountClosed.message":"The account has been closed and you will now be redirected to the homepage","resetTokenExpired.title":"Reset Password Link has Expired","resetTokenExpired.message":"Try resetting your password again","invalidUrl.title":"Invalid URL","invalidUrl.message":"The URL you're using is not recognized. Verify your URL and try again.","accountClosedForUser.title":"Account Closed","accountClosedForUser.message":"{userName}'s account is closed","inviteTokenInvalid.title":"Invitation Invalid","inviteTokenInvalid.message":"Your invitation to the community has been canceled or expired.","inviteTokenError.title":"Invitation Verification Failed","inviteTokenError.message":"The url you are utilizing is not recognized. Verify your URL and try again","pageNotFound.title":"Access Denied","pageNotFound.message":"You do not have access to this area of the community or it doesn't exist","eventAttending.title":"Responded as Attending","eventAttending.message":"You'll be notified when there's new activity and reminded as the event approaches","eventInterested.title":"Responded as Interested","eventInterested.message":"You'll be notified when there's new activity and reminded as the event approaches","eventNotFound.title":"Event Not Found","eventNotFound.message":"The event you tried to respond to does not exist.","redirectToRelatedPage.title":"Showing Related Content","redirectToRelatedPageForBaseUsers.title":"Showing Related Content","redirectToRelatedPageForBaseUsers.message":"The content you are trying to access is archived","redirectToRelatedPage.message":"The content you are trying to access is archived","relatedUrl.archivalLink.flyoutMessage":"The content you are trying to access is archived View Archived Content"},"localOverride":false},"CachedAsset:component:custom.widget.GoogleTagTracker-en-1736251130602":{"__typename":"CachedAsset","id":"component:custom.widget.GoogleTagTracker-en-1736251130602","value":{"component":{"id":"custom.widget.GoogleTagTracker","template":{"id":"GoogleTagTracker","markupLanguage":"HANDLEBARS","style":null,"texts":null,"defaults":{"config":{"applicablePages":[],"dynamicByCoreNode":false,"description":"Executes Google Tag tracking scripts","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[{"id":"prop_gtag","dataType":"STRING","list":false,"defaultValue":"","label":"Google Tag Manager Id","description":null,"possibleValues":null,"control":"INPUT","__typename":"PropDefinition"}],"__typename":"ComponentProperties"},"components":[{"id":"custom.widget.GoogleTagTracker","form":{"fields":[{"id":"widgetChooser","validation":null,"noValidation":null,"dataType":"STRING","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"title","validation":null,"noValidation":null,"dataType":"STRING","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"useTitle","validation":null,"noValidation":null,"dataType":"BOOLEAN","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"useBackground","validation":null,"noValidation":null,"dataType":"BOOLEAN","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"widgetVisibility","validation":null,"noValidation":null,"dataType":"STRING","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"moreOptions","validation":null,"noValidation":null,"dataType":"STRING","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"cProp_gtag","validation":null,"noValidation":null,"dataType":"STRING","list":false,"control":"INPUT","defaultValue":"","label":"Google Tag Manager Id","description":null,"possibleValues":null,"__typename":"FormField"}],"layout":{"rows":[{"id":"widgetChooserGroup","type":"fieldset","as":null,"items":[{"id":"widgetChooser","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"},{"id":"titleGroup","type":"fieldset","as":null,"items":[{"id":"title","className":null,"__typename":"FormFieldRef"},{"id":"useTitle","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"},{"id":"useBackground","type":"fieldset","as":null,"items":[{"id":"useBackground","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"},{"id":"widgetVisibility","type":"fieldset","as":null,"items":[{"id":"widgetVisibility","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"},{"id":"moreOptionsGroup","type":"fieldset","as":null,"items":[{"id":"moreOptions","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"},{"id":"componentPropsGroup","type":"fieldset","as":null,"items":[{"id":"cProp_gtag","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"}],"actionButtons":null,"className":"custom_widget_GoogleTagTracker_form","formGroupFieldSeparator":"divider","__typename":"FormLayout"},"__typename":"Form"},"config":null,"props":[],"__typename":"Component"}],"grouping":"CUSTOM","__typename":"ComponentTemplate"},"properties":{"config":{"applicablePages":[],"dynamicByCoreNode":false,"description":"Executes Google Tag tracking scripts","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[{"id":"prop_gtag","dataType":"STRING","list":false,"defaultValue":"","label":"Google Tag Manager Id","description":null,"possibleValues":null,"control":"INPUT","__typename":"PropDefinition"}],"__typename":"ComponentProperties"},"form":{"fields":[{"id":"widgetChooser","validation":null,"noValidation":null,"dataType":"STRING","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"title","validation":null,"noValidation":null,"dataType":"STRING","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"useTitle","validation":null,"noValidation":null,"dataType":"BOOLEAN","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"useBackground","validation":null,"noValidation":null,"dataType":"BOOLEAN","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"widgetVisibility","validation":null,"noValidation":null,"dataType":"STRING","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"moreOptions","validation":null,"noValidation":null,"dataType":"STRING","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"cProp_gtag","validation":null,"noValidation":null,"dataType":"STRING","list":false,"control":"INPUT","defaultValue":"","label":"Google Tag Manager Id","description":null,"possibleValues":null,"__typename":"FormField"}],"layout":{"rows":[{"id":"widgetChooserGroup","type":"fieldset","as":null,"items":[{"id":"widgetChooser","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"},{"id":"titleGroup","type":"fieldset","as":null,"items":[{"id":"title","className":null,"__typename":"FormFieldRef"},{"id":"useTitle","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"},{"id":"useBackground","type":"fieldset","as":null,"items":[{"id":"useBackground","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"},{"id":"widgetVisibility","type":"fieldset","as":null,"items":[{"id":"widgetVisibility","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"},{"id":"moreOptionsGroup","type":"fieldset","as":null,"items":[{"id":"moreOptions","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"},{"id":"componentPropsGroup","type":"fieldset","as":null,"items":[{"id":"cProp_gtag","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"}],"actionButtons":null,"className":"custom_widget_GoogleTagTracker_form","formGroupFieldSeparator":"divider","__typename":"FormLayout"},"__typename":"Form"},"__typename":"Component","localOverride":false},"globalCss":null,"form":{"fields":[{"id":"widgetChooser","validation":null,"noValidation":null,"dataType":"STRING","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"title","validation":null,"noValidation":null,"dataType":"STRING","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"useTitle","validation":null,"noValidation":null,"dataType":"BOOLEAN","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"useBackground","validation":null,"noValidation":null,"dataType":"BOOLEAN","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"widgetVisibility","validation":null,"noValidation":null,"dataType":"STRING","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"moreOptions","validation":null,"noValidation":null,"dataType":"STRING","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"cProp_gtag","validation":null,"noValidation":null,"dataType":"STRING","list":false,"control":"INPUT","defaultValue":"","label":"Google Tag Manager Id","description":null,"possibleValues":null,"__typename":"FormField"}],"layout":{"rows":[{"id":"widgetChooserGroup","type":"fieldset","as":null,"items":[{"id":"widgetChooser","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"},{"id":"titleGroup","type":"fieldset","as":null,"items":[{"id":"title","className":null,"__typename":"FormFieldRef"},{"id":"useTitle","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"},{"id":"useBackground","type":"fieldset","as":null,"items":[{"id":"useBackground","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"},{"id":"widgetVisibility","type":"fieldset","as":null,"items":[{"id":"widgetVisibility","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"},{"id":"moreOptionsGroup","type":"fieldset","as":null,"items":[{"id":"moreOptions","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"},{"id":"componentPropsGroup","type":"fieldset","as":null,"items":[{"id":"cProp_gtag","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"}],"actionButtons":null,"className":"custom_widget_GoogleTagTracker_form","formGroupFieldSeparator":"divider","__typename":"FormLayout"},"__typename":"Form"}},"localOverride":false},"CachedAsset:component:custom.widget.MixPanelTracker-en-1736251130602":{"__typename":"CachedAsset","id":"component:custom.widget.MixPanelTracker-en-1736251130602","value":{"component":{"id":"custom.widget.MixPanelTracker","template":{"id":"MixPanelTracker","markupLanguage":"HANDLEBARS","style":null,"texts":null,"defaults":{"config":{"applicablePages":[],"dynamicByCoreNode":false,"description":"Executes MixPanel tracking scripts","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"components":[{"id":"custom.widget.MixPanelTracker","form":null,"config":null,"props":[],"__typename":"Component"}],"grouping":"CUSTOM","__typename":"ComponentTemplate"},"properties":{"config":{"applicablePages":[],"dynamicByCoreNode":false,"description":"Executes MixPanel tracking scripts","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"form":null,"__typename":"Component","localOverride":false},"globalCss":null,"form":null},"localOverride":false},"CachedAsset:component:custom.widget.custom_Footer-en-1736251130602":{"__typename":"CachedAsset","id":"component:custom.widget.custom_Footer-en-1736251130602","value":{"component":{"id":"custom.widget.custom_Footer","template":{"id":"custom_Footer","markupLanguage":"HTML","style":null,"texts":null,"defaults":{"config":{"applicablePages":[],"dynamicByCoreNode":false,"description":"footer links and copy write text","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"components":[{"id":"custom.widget.custom_Footer","form":null,"config":null,"props":[],"__typename":"Component"}],"grouping":"TEXTHTML","__typename":"ComponentTemplate"},"properties":{"config":{"applicablePages":[],"dynamicByCoreNode":false,"description":"footer links and copy write text","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"form":null,"__typename":"Component","localOverride":false},"globalCss":null,"form":null},"localOverride":false},"CachedAsset:text:en_US-components/community/Navbar-1728282321000":{"__typename":"CachedAsset","id":"text:en_US-components/community/Navbar-1728282321000","value":{"community":"Community Home","inbox":"Inbox","manageContent":"Manage Content","tos":"Terms of Service","forgotPassword":"Forgot Password","themeEditor":"Theme Editor","edit":"Edit Navigation Bar","skipContent":"Skip to content","external-1":" My Email","external-10":"child 1","mucxz84639":"Home","about-community":"About the Community","external":"Test","external-9":"Bill History","external-8":"Bill Summary","external-7":"Pay Now","mucxz84639-1":"Billing","external-6":"Alerts","external-5":"Service Repair Order","external-4":"My Services & Plan","external-3":"Manage Username / Logins","external-2":"My Information"},"localOverride":false},"CachedAsset:text:en_US-components/community/NavbarHamburgerDropdown-1728282321000":{"__typename":"CachedAsset","id":"text:en_US-components/community/NavbarHamburgerDropdown-1728282321000","value":{"hamburgerLabel":"Side Menu"},"localOverride":false},"CachedAsset:text:en_US-components/community/BrandLogo-1728282321000":{"__typename":"CachedAsset","id":"text:en_US-components/community/BrandLogo-1728282321000","value":{"logoAlt":"Khoros","themeLogoAlt":"Brand Logo"},"localOverride":false},"CachedAsset:text:en_US-components/community/NavbarTextLinks-1728282321000":{"__typename":"CachedAsset","id":"text:en_US-components/community/NavbarTextLinks-1728282321000","value":{"more":"More"},"localOverride":false},"CachedAsset:text:en_US-components/search/SpotlightSearchIcon-1728282321000":{"__typename":"CachedAsset","id":"text:en_US-components/search/SpotlightSearchIcon-1728282321000","value":{"search":"Search"},"localOverride":false},"CachedAsset:text:en_US-components/authentication/AuthenticationLink-1728282321000":{"__typename":"CachedAsset","id":"text:en_US-components/authentication/AuthenticationLink-1728282321000","value":{"title.login":"Sign In","title.registration":"Register","title.forgotPassword":"Forgot Password","title.multiAuthLogin":"Sign In"},"localOverride":false},"CachedAsset:text:en_US-components/community/Breadcrumb-1728282321000":{"__typename":"CachedAsset","id":"text:en_US-components/community/Breadcrumb-1728282321000","value":{"navLabel":"Breadcrumbs","dropdown":"Additional parent page navigation"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageBanner-1728282321000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageBanner-1728282321000","value":{"messageMarkedAsSpam":"This post has been marked as spam","messageMarkedAsSpam@board:TKB":"This article has been marked as spam","messageMarkedAsSpam@board:BLOG":"This post has been marked as spam","messageMarkedAsSpam@board:FORUM":"This discussion has been marked as spam","messageMarkedAsSpam@board:OCCASION":"This event has been marked as spam","messageMarkedAsSpam@board:IDEA":"This idea has been marked as spam","manageSpam":"Manage Spam","messageMarkedAsAbuse":"This post has been marked as abuse","messageMarkedAsAbuse@board:TKB":"This article has been marked as abuse","messageMarkedAsAbuse@board:BLOG":"This post has been marked as abuse","messageMarkedAsAbuse@board:FORUM":"This discussion has been marked as abuse","messageMarkedAsAbuse@board:OCCASION":"This event has been marked as abuse","messageMarkedAsAbuse@board:IDEA":"This idea has been marked as abuse","preModCommentAuthorText":"This comment will be published as soon as it is approved","preModCommentModeratorText":"This comment is awaiting moderation","messageMarkedAsOther":"This post has been rejected due to other reasons","messageMarkedAsOther@board:TKB":"This article has been rejected due to other reasons","messageMarkedAsOther@board:BLOG":"This post has been rejected due to other reasons","messageMarkedAsOther@board:FORUM":"This discussion has been rejected due to other reasons","messageMarkedAsOther@board:OCCASION":"This event has been rejected due to other reasons","messageMarkedAsOther@board:IDEA":"This idea has been rejected due to other reasons","messageArchived":"This post was archived on {date}","relatedUrl":"View Related Content","relatedContentText":"Showing related content","archivedContentLink":"View Archived Content"},"localOverride":false},"CachedAsset:text:en_US-components/messages/RelatedContentWidget-1728282321000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/RelatedContentWidget-1728282321000","value":{"title":"Related Content","emptyDescription":"No content to show"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageListForNodeByRecentActivityWidget-1728282321000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageListForNodeByRecentActivityWidget-1728282321000","value":{"title@userScope:other":"Recent Content","title@userScope:self":"Contributions","title@board:FORUM@userScope:other":"Recent Discussions","title@board:BLOG@userScope:other":"Recent Blogs","emptyDescription":"No content to show","MessageListForNodeByRecentActivityWidgetEditor.nodeScope.label":"Scope","title@instance:1722231399124":"Latest Posts","title@instance:1722321652654":"Recent Content","title@instance:1721715590817":"Latest Posts","title@instance:1722251112371":"Latest Posts"},"localOverride":false},"Conversation:conversation:143373":{"__typename":"Conversation","id":"conversation:143373","topic":{"__typename":"ForumTopicMessage","uid":143373},"lastPostingActivityTime":"2024-12-31T07:41:03.787-05:00","solved":false},"ForumTopicMessage:message:143373":{"__typename":"ForumTopicMessage","subject":"Additional Data prices...","conversation":{"__ref":"Conversation:conversation:143373"},"id":"message:143373","revisionNum":2,"uid":143373,"depth":0,"board":{"__ref":"Forum:board:TechSupport"},"author":{"__typename":"User","uid":151456,"login":"Arj72715","registrationData":{"__typename":"RegistrationData","status":null},"deleted":false,"avatar":{"__typename":"UserAvatar","url":"https://community.hughesnet.com/t5/s/ssqng67387/m_assets/avatars/default/avatar-6.svg"}},"metrics":{"__typename":"MessageMetrics","views":76},"postTime":"2024-12-30T18:45:44.316-05:00","lastPublishTime":"2024-12-30T19:32:27.359-05:00","readOnly":false},"Conversation:conversation:143368":{"__typename":"Conversation","id":"conversation:143368","topic":{"__typename":"ForumTopicMessage","uid":143368},"lastPostingActivityTime":"2024-12-30T17:00:07.874-05:00","solved":false},"ForumTopicMessage:message:143368":{"__typename":"ForumTopicMessage","subject":"Data management","conversation":{"__ref":"Conversation:conversation:143368"},"id":"message:143368","revisionNum":1,"uid":143368,"depth":0,"board":{"__ref":"Forum:board:TechSupport"},"author":{"__typename":"User","uid":151443,"login":"Melissa1966","registrationData":{"__typename":"RegistrationData","status":null},"deleted":false,"avatar":{"__typename":"UserAvatar","url":"https://community.hughesnet.com/t5/s/ssqng67387/m_assets/avatars/default/avatar-1.svg"}},"metrics":{"__typename":"MessageMetrics","views":29},"postTime":"2024-12-30T08:12:48.019-05:00","lastPublishTime":"2024-12-30T08:12:48.019-05:00","readOnly":false},"Conversation:conversation:143287":{"__typename":"Conversation","id":"conversation:143287","topic":{"__typename":"ForumTopicMessage","uid":143287},"lastPostingActivityTime":"2024-12-26T13:10:55.658-05:00","solved":false},"ForumTopicMessage:message:143287":{"__typename":"ForumTopicMessage","subject":"Problem with uploading image for PM...","conversation":{"__ref":"Conversation:conversation:143287"},"id":"message:143287","revisionNum":1,"uid":143287,"depth":0,"board":{"__ref":"Forum:board:TechSupport"},"author":{"__typename":"User","uid":29869,"login":"GabeU","registrationData":{"__typename":"RegistrationData","status":null},"deleted":false,"avatar":{"__typename":"UserAvatar","url":"https://community.hughesnet.com/t5/s/ssqng67387/images/dS0yOTg2OS0zMzc1aTM2QzZDMjdBOUREQzBFNDg"}},"metrics":{"__typename":"MessageMetrics","views":133},"postTime":"2024-12-11T20:11:30.243-05:00","lastPublishTime":"2024-12-11T20:11:30.243-05:00","readOnly":false},"Conversation:conversation:143310":{"__typename":"Conversation","id":"conversation:143310","topic":{"__typename":"ForumTopicMessage","uid":143310},"lastPostingActivityTime":"2024-12-24T21:56:47.486-05:00","solved":false},"ForumTopicMessage:message:143310":{"__typename":"ForumTopicMessage","subject":"Cannot access phone service or E-mail.","conversation":{"__ref":"Conversation:conversation:143310"},"id":"message:143310","revisionNum":1,"uid":143310,"depth":0,"board":{"__ref":"Forum:board:TechSupport"},"author":{"__typename":"User","uid":151228,"login":"Suel4","registrationData":{"__typename":"RegistrationData","status":null},"deleted":false,"avatar":{"__typename":"UserAvatar","url":"https://community.hughesnet.com/t5/s/ssqng67387/m_assets/avatars/default/avatar-12.svg"}},"metrics":{"__typename":"MessageMetrics","views":122},"postTime":"2024-12-15T19:10:27.833-05:00","lastPublishTime":"2024-12-15T19:10:27.833-05:00","readOnly":false},"Conversation:conversation:143312":{"__typename":"Conversation","id":"conversation:143312","topic":{"__ref":"ForumTopicMessage:message:143312"},"lastPostingActivityTime":"2024-12-16T20:37:01.295-05:00","solved":true,"lastPostTime":"2024-12-16T20:37:01.295-05:00"},"ForumTopicMessage:message:143312":{"__typename":"ForumTopicMessage","subject":"Speed Problem Returns","conversation":{"__ref":"Conversation:conversation:143312"},"id":"message:143312","revisionNum":1,"uid":143312,"depth":0,"board":{"__ref":"Forum:board:TechSupport"},"author":{"__ref":"User:user:147943"},"metrics":{"__typename":"MessageMetrics","views":121},"postTime":"2024-12-16T08:10:30.588-05:00","lastPublishTime":"2024-12-16T08:10:30.588-05:00","readOnly":true,"repliesCount":1,"hasGivenKudo":false,"moderationData":{"__ref":"ModerationData:moderation_data:143312"},"placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"entityType":"FORUM_TOPIC","eventPath":"category:HNSupport/community:ssqng67387board:TechSupport/message:143312"},"Rank:rank:22":{"__typename":"Rank","id":"rank:22","position":23,"name":"New Poster","color":"333333","icon":null,"rankStyle":"TEXT"},"User:user:5470":{"__typename":"User","id":"user:5470","uid":5470,"login":"ihinesm","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2016-12-13T03:00:00.000-05:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.hughesnet.com/t5/s/ssqng67387/m_assets/avatars/default/avatar-9.svg"},"rank":{"__ref":"Rank:rank:22"},"messagesCount":8,"kudosGivenCount":0,"kudosReceivedCount":0,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount":0,"entityType":"USER","eventPath":"community:ssqng67387/user:5470"},"ForumTopicMessage:message:76549":{"__typename":"ForumTopicMessage","uid":76549,"subject":"Connectivity problems","id":"message:76549","revisionNum":1,"repliesCount":8,"author":{"__ref":"User:user:5470"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:TechSupport"},"conversation":{"__ref":"Conversation:conversation:76549"},"moderationData":{"__ref":"ModerationData:moderation_data:76549"},"postTime":"2017-04-20T10:00:10.314-04:00","lastPublishTime":"2017-04-20T10:00:10.314-04:00","readOnly":true,"metrics":{"__typename":"MessageMetrics","views":6257},"placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"entityType":"FORUM_TOPIC","eventPath":"category:HNSupport/community:ssqng67387board:TechSupport/message:76549"},"Conversation:conversation:76549":{"__typename":"Conversation","id":"conversation:76549","solved":true,"topic":{"__ref":"ForumTopicMessage:message:76549"},"lastPostingActivityTime":"2017-04-20T20:30:37.011-04:00","lastPostTime":"2017-04-20T20:30:37.011-04:00"},"ModerationData:moderation_data:76549":{"__typename":"ModerationData","id":"moderation_data:76549","status":"APPROVED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:76549":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:76549","relatedMessage":{"__ref":"ForumTopicMessage:message:76549"}},"Rank:rank:21":{"__typename":"Rank","id":"rank:21","position":22,"name":"Freshman","color":"33CC00","icon":null,"rankStyle":"TEXT"},"User:user:18118":{"__typename":"User","id":"user:18118","uid":18118,"login":"Satellite Hermi","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2014-09-26T03:00:00.000-04:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.hughesnet.com/t5/s/ssqng67387/m_assets/avatars/default/avatar-7.svg"},"rank":{"__ref":"Rank:rank:21"},"messagesCount":6,"kudosGivenCount":2,"kudosReceivedCount":1,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount":0,"entityType":"USER","eventPath":"community:ssqng67387/user:18118"},"ForumTopicMessage:message:83964":{"__typename":"ForumTopicMessage","uid":83964,"subject":"HN9000 Connection Problems","id":"message:83964","revisionNum":1,"repliesCount":9,"author":{"__ref":"User:user:18118"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:TechSupport"},"conversation":{"__ref":"Conversation:conversation:83964"},"moderationData":{"__ref":"ModerationData:moderation_data:83964"},"postTime":"2017-09-25T15:13:42.722-04:00","lastPublishTime":"2017-09-25T15:13:42.722-04:00","readOnly":true,"metrics":{"__typename":"MessageMetrics","views":5754},"placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"entityType":"FORUM_TOPIC","eventPath":"category:HNSupport/community:ssqng67387board:TechSupport/message:83964"},"Conversation:conversation:83964":{"__typename":"Conversation","id":"conversation:83964","solved":true,"topic":{"__ref":"ForumTopicMessage:message:83964"},"lastPostingActivityTime":"2017-10-05T10:10:43.946-04:00","lastPostTime":"2017-10-05T10:10:43.946-04:00"},"ModerationData:moderation_data:83964":{"__typename":"ModerationData","id":"moderation_data:83964","status":"APPROVED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:83964":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:83964","relatedMessage":{"__ref":"ForumTopicMessage:message:83964"}},"User:user:147943":{"__typename":"User","uid":147943,"login":"eco","registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2024-01-22T13:22:13.304-05:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"avatar":{"__typename":"UserAvatar","url":"https://community.hughesnet.com/t5/s/ssqng67387/images/dS0xNDc5NDMtNzg1NWk0RTc4RDQxODg5REQ5QkM0"},"id":"user:147943","biography":null,"email":"","rank":{"__ref":"Rank:rank:19"},"messagesCount":75,"kudosGivenCount":0,"kudosReceivedCount":6,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount":4,"entityType":"USER","eventPath":"community:ssqng67387/user:147943"},"ForumTopicMessage:message:142253":{"__typename":"ForumTopicMessage","uid":142253,"subject":"Modem Problem Solar No Communication","id":"message:142253","revisionNum":2,"repliesCount":8,"author":{"__ref":"User:user:147943"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:TechSupport"},"conversation":{"__ref":"Conversation:conversation:142253"},"moderationData":{"__ref":"ModerationData:moderation_data:142253"},"postTime":"2024-05-10T13:42:38.663-04:00","lastPublishTime":"2024-05-10T16:21:28.580-04:00","readOnly":false,"metrics":{"__typename":"MessageMetrics","views":4516},"placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"entityType":"FORUM_TOPIC","eventPath":"category:HNSupport/community:ssqng67387board:TechSupport/message:142253"},"Conversation:conversation:142253":{"__typename":"Conversation","id":"conversation:142253","solved":true,"topic":{"__ref":"ForumTopicMessage:message:142253"},"lastPostingActivityTime":"2024-05-13T17:11:49.419-04:00","lastPostTime":"2024-05-13T17:11:49.419-04:00"},"ModerationData:moderation_data:142253":{"__typename":"ModerationData","id":"moderation_data:142253","status":"APPROVED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:142253":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:142253","relatedMessage":{"__ref":"ForumTopicMessage:message:142253"}},"User:user:150243":{"__typename":"User","id":"user:150243","uid":150243,"login":"jeffreygrant717","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2024-09-10T13:05:13.752-04:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.hughesnet.com/t5/s/ssqng67387/m_assets/avatars/default/avatar-6.svg"},"rank":{"__ref":"Rank:rank:22"},"messagesCount":2,"kudosGivenCount":0,"kudosReceivedCount":1,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount":0,"entityType":"USER","eventPath":"community:ssqng67387/user:150243"},"ForumTopicMessage:message:142912":{"__typename":"ForumTopicMessage","uid":142912,"subject":"Unable to connect to System Control Center","id":"message:142912","revisionNum":1,"repliesCount":3,"author":{"__ref":"User:user:150243"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:TechSupport"},"conversation":{"__ref":"Conversation:conversation:142912"},"moderationData":{"__ref":"ModerationData:moderation_data:142912"},"postTime":"2024-09-13T11:05:15.546-04:00","lastPublishTime":"2024-09-13T11:05:15.546-04:00","readOnly":false,"metrics":{"__typename":"MessageMetrics","views":2505},"placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"entityType":"FORUM_TOPIC","eventPath":"category:HNSupport/community:ssqng67387board:TechSupport/message:142912"},"Conversation:conversation:142912":{"__typename":"Conversation","id":"conversation:142912","solved":true,"topic":{"__ref":"ForumTopicMessage:message:142912"},"lastPostingActivityTime":"2024-09-17T13:59:45.986-04:00","lastPostTime":"2024-09-17T13:59:45.986-04:00"},"ModerationData:moderation_data:142912":{"__typename":"ModerationData","id":"moderation_data:142912","status":"APPROVED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:142912":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:142912","relatedMessage":{"__ref":"ForumTopicMessage:message:142912"}},"ModerationData:moderation_data:143312":{"__typename":"ModerationData","id":"moderation_data:143312","status":"APPROVED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:143312":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:143312","relatedMessage":{"__ref":"ForumTopicMessage:message:143312"}},"CachedAsset:text:en_US-components/nodes/NodeLink-1728282321000":{"__typename":"CachedAsset","id":"text:en_US-components/nodes/NodeLink-1728282321000","value":{"place":"Place {name}"},"localOverride":false},"CachedAsset:text:en_US-components/customComponent/CustomComponent-1728282321000":{"__typename":"CachedAsset","id":"text:en_US-components/customComponent/CustomComponent-1728282321000","value":{"errorMessage":"Error rendering component id: {customComponentId}","bannerTitle":"Video provider requires cookies to play the video. Accept to continue or {url} it directly on the provider's site.","buttonTitle":"Accept","urlText":"watch"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageView/MessageViewStandard-1728282321000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageView/MessageViewStandard-1728282321000","value":{"anonymous":"Anonymous","author":"{messageAuthorLogin}","authorBy":"{messageAuthorLogin}","board":"{messageBoardTitle}","replyToUser":" to {parentAuthor}","showMoreReplies":"Show More","replyText":"Reply","repliesText":"Replies","markedAsSolved":"Marked as Solved","movedMessagePlaceholder.BLOG":"{count, plural, =0 {This comment has been} other {These comments have been} }","movedMessagePlaceholder.TKB":"{count, plural, =0 {This comment has been} other {These comments have been} }","movedMessagePlaceholder.FORUM":"{count, plural, =0 {This reply has been} other {These replies have been} }","movedMessagePlaceholder.IDEA":"{count, plural, =0 {This comment has been} other {These comments have been} }","movedMessagePlaceholder.OCCASION":"{count, plural, =0 {This comment has been} other {These comments have been} }","movedMessagePlaceholderUrlText":"moved.","messageStatus":"Status: ","statusChanged":"Status changed: {previousStatus} to {currentStatus}","statusAdded":"Status added: {status}","statusRemoved":"Status removed: {status}","labelExpand":"expand replies","labelCollapse":"collapse replies","unhelpfulReason.reason1":"Content is outdated","unhelpfulReason.reason2":"Article is missing information","unhelpfulReason.reason3":"Content is for a different Product","unhelpfulReason.reason4":"Doesn't match what I was searching for"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageDeepLink-1728282321000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageDeepLink-1728282321000","value":{"viewFullDiscussion@board:FORUM":"View Full Discussion ({repliesCount} Replies)","viewFullDiscussion@board:BLOG":"View Full Discussion ({repliesCount} Comments)","viewFullDiscussion@board:TKB":"View Full Discussion ({repliesCount} Comments)","viewFullDiscussion@board:IDEA":"View Full Discussion ({repliesCount} Comments)","viewFullDiscussion@board:OCCASION":"View Full Discussion ({repliesCount} Comments)","showParents@board:FORUM":"Show Parent Replies","showParents@board:BLOG":"Show Parent Comments","showParents@board:TKB":"Show Parent Comments","showParents@board:IDEA":"Show Parent Comments","showParents@board:OCCASION":"Show Parent Comments"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageReplyCallToAction-1728282321000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageReplyCallToAction-1728282321000","value":{"leaveReply":"Leave a reply...","leaveReply@board:BLOG@message:root":"Leave a comment...","leaveReply@board:TKB@message:root":"Leave a comment...","leaveReply@board:IDEA@message:root":"Leave a comment...","leaveReply@board:OCCASION@message:root":"Leave a comment...","repliesTurnedOff.FORUM":"Replies are turned off for this topic","repliesTurnedOff.BLOG":"Comments are turned off for this topic","repliesTurnedOff.TKB":"Comments are turned off for this topic","repliesTurnedOff.IDEA":"Comments are turned off for this topic","repliesTurnedOff.OCCASION":"Comments are turned off for this topic","infoText":"Stop poking me!"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/common/QueryHandler-1728282321000":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/common/QueryHandler-1728282321000","value":{"title":"Query Handler"},"localOverride":false},"QueryVariables:MessageSolutions":{"__typename":"QueryVariables","id":"MessageSolutions","value":{"first":10,"constraints":{"topicId":{"eq":"message:111048"},"solution":{"eq":true}},"sorts":{"postTime":{"direction":"ASC"}},"useAvatar":true,"useAuthorLogin":true,"useAuthorRank":false,"useBody":true,"useKudosCount":false,"useTimeToRead":false,"useMedia":true,"useRepliesCount":false,"useSearchSnippet":false,"useAcceptedSolutionButton":true,"useSolvedBadge":false,"useAttachments":true,"useTags":false,"useUserHoverCard":true,"useNodeHoverCard":true,"usePreviewSubjectModal":false,"useMessageStatus":false}},"ROOT_MUTATION":{"__typename":"Mutation"},"CachedAsset:text:en_US-components/messages/EscalatedMessageBanner-1728282321000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/EscalatedMessageBanner-1728282321000","value":{"escalationMessage":"Escalated to Salesforce by {username} on {date}","viewDetails":"View Details","modalTitle":"Case Details","escalatedBy":"Escalated by: ","escalatedOn":"Escalated on: ","caseNumber":"Case Number: ","status":"Status: ","lastUpdateDate":"Last Update: ","automaticEscalation":"automatic escalation","anonymous":"Anonymous"},"localOverride":false},"CachedAsset:text:en_US-components/users/UserLink-1728282321000":{"__typename":"CachedAsset","id":"text:en_US-components/users/UserLink-1728282321000","value":{"authorName":"View Profile: {author}","anonymous":"Anonymous"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/users/UserRank-1728282321000":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/users/UserRank-1728282321000","value":{"rankName":"{rankName}","userRank":"Author rank {rankName}"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageTime-1728282321000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageTime-1728282321000","value":{"postTime":"Published: {time}","lastPublishTime":"Last Update: {time}","conversation.lastPostingActivityTime":"Last posting activity time: {time}","conversation.lastPostTime":"Last post time: {time}","moderationData.rejectTime":"Rejected time: {time}"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageSubject-1728282321000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageSubject-1728282321000","value":{"noSubject":"(no subject)"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageBody-1728282321000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageBody-1728282321000","value":{"showMessageBody":"Show More","mentionsErrorTitle":"{mentionsType, select, board {Board} user {User} message {Message} other {}} No Longer Available","mentionsErrorMessage":"The {mentionsType} you are trying to view has been removed from the community.","videoProcessing":"Video is being processed. Please try again in a few minutes.","bannerTitle":"Video provider requires cookies to play the video. Accept to continue or {url} it directly on the provider's site.","buttonTitle":"Accept","urlText":"watch"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageCustomFields-1728282321000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageCustomFields-1728282321000","value":{"CustomField.default.label":"Value of {name}"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageReplyButton-1728282321000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageReplyButton-1728282321000","value":{"repliesCount":"{count}","title":"Reply","title@board:BLOG@message:root":"Comment","title@board:TKB@message:root":"Comment","title@board:IDEA@message:root":"Comment","title@board:OCCASION@message:root":"Comment"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageSolutionList-1728282321000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageSolutionList-1728282321000","value":{"emptyDescription":"No has been message solutions yet"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageView/MessageViewInline-1728282321000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageView/MessageViewInline-1728282321000","value":{"bylineAuthor":"{bylineAuthor}","bylineBoard":"{bylineBoard}","anonymous":"Anonymous","place":"Place {bylineBoard}","gotoParent":"Go to parent {name}"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/common/Pager/PagerLoadMore-1728282321000":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/common/Pager/PagerLoadMore-1728282321000","value":{"loadMore":"Show More"},"localOverride":false},"Rank:rank:5":{"__typename":"Rank","id":"rank:5","position":6,"name":"Distinguished Professor IV","color":"0000FF","icon":null,"rankStyle":"TEXT"},"User:user:29869":{"__typename":"User","id":"user:29869","uid":29869,"login":"GabeU","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2016-01-04T03:00:00.000-05:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.hughesnet.com/t5/s/ssqng67387/images/dS0yOTg2OS0zMzc1aTM2QzZDMjdBOUREQzBFNDg"},"rank":{"__ref":"Rank:rank:5"},"messagesCount:{\"solution\":{\"eq\":true},\"topicId\":{\"eq\":\"message:111048\"}}":12224,"kudosGivenCount:{\"solution\":{\"eq\":true},\"topicId\":{\"eq\":\"message:111048\"}}":6384,"kudosReceivedCount:{\"solution\":{\"eq\":true},\"topicId\":{\"eq\":\"message:111048\"}}":3688,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount:{\"solution\":{\"eq\":true},\"topicId\":{\"eq\":\"message:111048\"}}":270,"entityType":"USER","eventPath":"community:ssqng67387/user:29869","messagesCount":12224,"topicsCount":304,"kudosReceivedCount":3688,"kudosGivenCount":6384,"solutionsCount":270},"User:user:9074":{"__typename":"User","id":"user:9074","deleted":false,"uid":9074,"login":"BirdDog","biography":"Air Force Vet, Air Traffic Control radio repair tech, Satellite Comm Superintendent, member Inspector General team for Strategic Air Command, ground crew member for USAF Thunderbirds. \r\n\r\nAfter leaving AIr Force worked in several different installation/repair of electronics positions. Including POS systems, ATMs, printers, computers, LAN systems, factory automated control systems, parking control systems, security control systems, and HVAC control systems.","registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2011-12-03T03:00:00.000-05:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.hughesnet.com/t5/s/ssqng67387/images/dS05MDc0LTU4Mmk0M0FBQzgxRjcyQzJCMTdD"},"rank":{"__ref":"Rank:rank:11"},"messagesCount":7606,"kudosGivenCount":584,"kudosReceivedCount":1127,"kudosWeight":1,"ssoId":null,"followersCount":3,"solutionsCount":56,"entityType":"USER","eventPath":"community:ssqng67387/user:9074"},"ForumReplyMessage:message:111128":{"__typename":"ForumReplyMessage","uid":111128,"id":"message:111128","revisionNum":1,"author":{"__ref":"User:user:9074"},"readOnly":true,"depth":16,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:TechSupport"},"parent":{"__ref":"ForumReplyMessage:message:111126"},"conversation":{"__ref":"Conversation:conversation:111048"},"subject":"Re: Connection Problems- Only with AOL","moderationData":{"__ref":"ModerationData:moderation_data:111128"},"body":"
","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"203","kudosSumWeight":0,"postTime":"2019-03-28T18:27:31.052-04:00","lastPublishTime":"2019-03-28T18:27:31.052-04:00","metrics":{"__typename":"MessageMetrics","views":11334},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"category:HNSupport/community:ssqng67387board:TechSupport/message:111048/message:111128","repliesCount":7,"customFields":[],"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}}},"ModerationData:moderation_data:111133":{"__typename":"ModerationData","id":"moderation_data:111133","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"AcceptedSolutionMessage:message:111133":{"__typename":"AcceptedSolutionMessage","author":{"__ref":"User:user:29869"},"id":"message:111133","revisionNum":1,"uid":111133,"depth":17,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:TechSupport"},"parent":{"__ref":"ForumReplyMessage:message:111128"},"conversation":{"__ref":"Conversation:conversation:111048"},"subject":"Re: Connection Problems- Only with AOL","moderationData":{"__ref":"ModerationData:moderation_data:111133"},"body":"
bos2420
One other thing is that, if you'd like to schedule the file downloads, but you don't like the idea of leaving your PC on (I don't), or messing with trying to schedule the downloads to your PC, you can schedule the file download(s) to your Android or IOS device using the PlayOn Cloud app, then copy the files to your PC.
BTW, don't forget to change the resolution on the app if you want it to be better than standard.  I'm fine with standard, which is DVD quality, but some people want it to be better, regardless of the increased file size for the program/movie.  I believe 720p is the maximum resolution, but that's still very good.
If you try it and you like it, please let us know.  I'm still deciding whether to get it, though I probably will.  It's cheap, and lets you easily take advantage of the Bonus Zone data, and even those twenty days of data resets with your upgrade (make sure first, though, of course).  :)
","body@stripHtml({\"removeProcessingText\":true,\"removeSpoilerMarkup\":true,\"removeTocMarkup\":true,\"truncateLength\":200})@stringLength":"213","postTime":"2019-03-29T00:43:30.232-04:00","lastPublishTime":"2019-03-29T00:43:30.232-04:00","images":{"__typename":"AssociatedImageConnection","edges":[],"totalCount":0,"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"attachments":{"__typename":"AttachmentConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"solution":true,"metrics":{"__typename":"MessageMetrics","views":27014},"placeholder":false,"originalMessageForPlaceholder":null,"videos":{"__typename":"VideoConnection","edges":[],"totalCount":0,"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"isEscalated":null,"entityType":"FORUM_REPLY","eventPath":"category:HNSupport/community:ssqng67387board:TechSupport/message:111048/message:111133","customFields":[],"body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"213","kudosSumWeight":0,"visibilityScope":"PUBLIC","repliesCount":6,"readOnly":true},"ModerationData:moderation_data:111123":{"__typename":"ModerationData","id":"moderation_data:111123","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ModerationData:moderation_data:111122":{"__typename":"ModerationData","id":"moderation_data:111122","status":"APPROVED","rejectReason":null},"User:user:21490":{"__typename":"User","id":"user:21490","login":"maratsade","uid":21490,"deleted":false,"avatar":{"__typename":"UserAvatar","url":"https://community.hughesnet.com/t5/s/ssqng67387/images/dS0yMTQ5MC04aTNCQUJDNDExNzNEOTlEOUE"},"rank":{"__ref":"Rank:rank:5"},"email":"","messagesCount":8656,"biography":null,"topicsCount":142,"kudosReceivedCount":4074,"kudosGivenCount":3471,"kudosWeight":1,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2015-06-05T03:00:00.000-04:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"followersCount":null,"solutionsCount":168,"ssoId":null,"entityType":"USER","eventPath":"community:ssqng67387/user:21490"},"ModerationData:moderation_data:111119":{"__typename":"ModerationData","id":"moderation_data:111119","status":"APPROVED","rejectReason":null},"ModerationData:moderation_data:111105":{"__typename":"ModerationData","id":"moderation_data:111105","status":"APPROVED","rejectReason":null},"ModerationData:moderation_data:111104":{"__typename":"ModerationData","id":"moderation_data:111104","status":"APPROVED","rejectReason":null},"ForumReplyMessage:message:111104":{"__typename":"ForumReplyMessage","id":"message:111104","revisionNum":1,"uid":111104,"depth":10,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:TechSupport"},"conversation":{"__ref":"Conversation:conversation:111048"},"subject":"Re: Connection Problems- Only with AOL","readOnly":true,"editFrozen":false,"moderationData":{"__ref":"ModerationData:moderation_data:111104"},"body":"
Well, we got off track, but that's ok.
When I last upgraded, they gave me 20 days of basically unlimited data, so I am not worried.  The warning is well taken, and something I can watch for.
Meanwhile, I gave up on a solution, and ordered the upgrade.  They come next Wed.
On a side note, living in the mountains, I am also on Dish, which cancelled HBO.  Sorta ticked about that, as I am looking forward to the last season of Game of Thrones.  So we will be looking into streaming HBO Now on a limited basis.  Upgraded from the old 14gb to the 20gb plan, so it should work out.  Yea, I know streaming eats data.  I will watch it.
Thanks for all the help, even if we didn't solve it.
","body@stringLength":"824","rawBody":"
","author":{"__ref":"User:user:24839"},"isEscalated":null},"ForumReplyMessage:message:111105":{"__typename":"ForumReplyMessage","id":"message:111105","revisionNum":1,"uid":111105,"depth":11,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:TechSupport"},"conversation":{"__ref":"Conversation:conversation:111048"},"subject":"Re: Connection Problems- Only with AOL","readOnly":true,"editFrozen":false,"moderationData":{"__ref":"ModerationData:moderation_data:111105"},"body":"
bos2420
You should like the Gen5.  It works pretty well for me.  And the HT2000W has built in WiFi, so if anything were to ever go wrong with your own router you'll still it.
That whole Dish and HBO thing is angering a lot of people, especially because of GOT.  I'm looking forward to the Deadwood film, as well.
You may even want to take a look at PlayOn Cloud.  With it you can download GOT and other things as a file (.mp4) instead of actually having to stream it.  It's a great way to be able to take advantage of the Bonus Zone.  It streams what you choose to the cloud, then converts it to an .mp4 file for downloading.  And what you download you keep, as well.  There's no expiration.  You then use your media player, like VLC or Windows' built in player, to view the file.  And best of all is that there's no buffering, as you're watching the programs/movies from already downloaded files.  It's a pretty inexpensive service, as well.  You can even schedule the file downloads.  You should check it out.  It might be worth it for you.  I don't have it, myself, but a couple of people on here do, including maratsade.  He seems to like it.  :)
","body@stringLength":"1717","rawBody":"
You may even want to take a look at PlayOn Cloud.  With it you can download GOT and other things as a file (.mp4) instead of actually having to stream it.  It's a great way to be able to take advantage of the Bonus Zone.  It streams what you choose to the cloud, then converts it to an .mp4 file for downloading.  And what you download you keep, as well.  There's no expiration.  You then use your media player, like VLC or Windows' built in player, to view the file.  And best of all is that there's no buffering, as you're watching the programs/movies from already downloaded files.  It's a pretty inexpensive service, as well.  You can even schedule the file downloads.  You should check it out.  It might be worth it for you.  I don't have it, myself, but a couple of people on here do, including .  He seems to like it.  :)
","author":{"__ref":"User:user:29869"},"isEscalated":null,"parent":{"__ref":"ForumReplyMessage:message:111104"}},"ForumReplyMessage:message:111119":{"__typename":"ForumReplyMessage","id":"message:111119","revisionNum":1,"uid":111119,"depth":12,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:TechSupport"},"conversation":{"__ref":"Conversation:conversation:111048"},"subject":"Re: Connection Problems- Only with AOL","readOnly":true,"editFrozen":false,"moderationData":{"__ref":"ModerationData:moderation_data:111119"},"body":"
Good news.  Install date was moved up from next Fri to next Wed.  Yeaaaaaaaaaaaaaaaaaaaa.
Interested in the Playon.tv thing.  So I went to take a look.
Wouldn'tcha know....
This site can’t be reached
www.playon.tv took too long to respond.
I tried a couple of different links, several times.  No joy.
(No need to try to fix this, just amusing)
","body@stringLength":"579","rawBody":"
","author":{"__ref":"User:user:24839"},"isEscalated":null,"parent":{"__ref":"ForumReplyMessage:message:111105"}},"ForumReplyMessage:message:111122":{"__typename":"ForumReplyMessage","id":"message:111122","revisionNum":1,"uid":111122,"depth":13,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:TechSupport"},"conversation":{"__ref":"Conversation:conversation:111048"},"subject":"Re: Connection Problems- Only with AOL","readOnly":true,"editFrozen":false,"moderationData":{"__ref":"ModerationData:moderation_data:111122"},"body":"
Working fine for me:
","body@stringLength":"444","rawBody":"
","author":{"__ref":"User:user:21490"},"isEscalated":null,"parent":{"__ref":"ForumReplyMessage:message:111119"},"customFields":[],"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}}},"Revision:revision:111123_1":{"__typename":"Revision","id":"revision:111123_1","lastEditTime":"2019-03-28T15:41:06.058-04:00"},"QueryVariables:ReplyList:message:111123:1":{"__typename":"QueryVariables","id":"ReplyList:message:111123:1","value":{"id":"message:111123","sorts":{"postTime":{"direction":"ASC"}},"useAvatar":true,"useAuthorLogin":true,"useAuthorRank":true,"useBody":true,"useKudosCount":true,"useTimeToRead":false,"useMedia":false,"useReadOnlyIcon":false,"useRepliesCount":false,"useSearchSnippet":false,"useAcceptedSolutionButton":true,"useSolvedBadge":false,"useAttachments":false,"attachmentsFirst":5,"useTags":false,"useNodeAncestors":false,"useUserHoverCard":true,"useNodeHoverCard":false,"useModerationStatus":true,"usePreviewSubjectModal":false,"useMessageStatus":true}},"CachedAsset:text:en_US-shared/client/components/users/UserAvatar-1728282321000":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/users/UserAvatar-1728282321000","value":{"altText":"{login}'s avatar","altTextGeneric":"User's avatar"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/ranks/UserRankLabel-1728282321000":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/ranks/UserRankLabel-1728282321000","value":{"altTitle":"Icon for {rankName} rank"},"localOverride":false},"CachedAsset:text:en_US-components/messages/AcceptedSolutionButton-1728282321000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/AcceptedSolutionButton-1728282321000","value":{"accept":"Mark as Solution","accepted":"Marked as Solution","errorHeader":"Error!","errorAdd":"There was an error marking as solution.","errorRemove":"There was an error unmarking as solution.","solved":"Solved"},"localOverride":false},"CachedAsset:text:en_US-components/messages/LinearReplyList-1728282321000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/LinearReplyList-1728282321000","value":{"title":"{count, plural, one{# Reply} other{# Replies}}","title@board:BLOG":"{count, plural, one{# Comment} other{# Comments}}","title@board:TKB":"{count, plural, one{# Comment} other{# Comments}}","title@board:IDEA":"{count, plural, one{# Comment} other{# Comments}}","title@board:OCCASION":"{count, plural, one{# Comment} other{# Comments}}","noRepliesTitle":"No Replies","noRepliesTitle@board:BLOG":"No Comments","noRepliesTitle@board:TKB":"No Comments","noRepliesTitle@board:IDEA":"No Comments","noRepliesTitle@board:OCCASION":"No Comments","noRepliesDescription":"Be the first to reply","noRepliesDescription@board:BLOG":"Be the first to comment","noRepliesDescription@board:TKB":"Be the first to comment","noRepliesDescription@board:OCCASION":"Be the first to comment","noRepliesDescription@board:IDEA":"Be the first to comment","messageReadOnlyAlert:BLOG":"Comments have been turned off for this post","messageReadOnlyAlert:TKB":"Comments have been turned off for this article","messageReadOnlyAlert:IDEA":"Comments have been turned off for this idea","messageReadOnlyAlert:FORUM":"Replies have been turned off for this discussion","messageReadOnlyAlert:OCCASION":"Comments have been turned off for this event"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/nodes/NodeIcon-1728282321000":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/nodes/NodeIcon-1728282321000","value":{"contentType":"Content Type {style, select, FORUM {Forum} BLOG {Blog} TKB {Knowledge Base} IDEA {Ideas} OCCASION {Events} other {}} icon"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageSolvedBadge-1728282321000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageSolvedBadge-1728282321000","value":{"solved":"Solved"},"localOverride":false},"ModerationData:moderation_data:111124":{"__typename":"ModerationData","id":"moderation_data:111124","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:111124":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:24839"},"id":"message:111124","revisionNum":1,"uid":111124,"depth":15,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:TechSupport"},"parent":{"__ref":"ForumReplyMessage:message:111123"},"conversation":{"__ref":"Conversation:conversation:111048"},"subject":"Re: Connection Problems- Only with AOL","moderationData":{"__ref":"ModerationData:moderation_data:111124"},"body":"
OK, I just got in to the Play On Cloud website.  I guess what I need to do is this.....
Once that recording is complete, an .mp4 file will be ready for you to enjoy. You can download the recorded.mp4 video file from the PlayOn Cloud app onto your mobile device. We also email you a download link to the video so you can download it from anywhere onto any device or computer.
","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"213","kudosSumWeight":1,"postTime":"2019-03-28T15:44:50.742-04:00","lastPublishTime":"2019-03-28T15:44:50.742-04:00","metrics":{"__typename":"MessageMetrics","views":10475},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"category:HNSupport/community:ssqng67387board:TechSupport/message:111048/message:111124","repliesCount":1,"readOnly":true,"customFields":[],"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}}},"ModerationData:moderation_data:111125":{"__typename":"ModerationData","id":"moderation_data:111125","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:111125":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:21490"},"id":"message:111125","revisionNum":1,"uid":111125,"depth":16,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:TechSupport"},"parent":{"__ref":"ForumReplyMessage:message:111124"},"conversation":{"__ref":"Conversation:conversation:111048"},"subject":"Re: Connection Problems- Only with AOL","moderationData":{"__ref":"ModerationData:moderation_data:111125"},"body":"
That's right.  You set up the download (this is where they deduct the recording tokens from your account), and it works behind the scenes, in the cloud. You can just shut down the app and forget about it.  It records in real time (it's a DVR-like thing), so a 1 hour show will take 1 hour to record.  When the recording is done, you will get an email with a download link.  Unless you pay for storage, the recording will only be stored for 7 days.  If you lose the link or the email, you can use the app to get the email resent.  If the recording is no longer in storage, you have to re-record it.
With the link, you can download to any device. I think to download to devices like iPhone or iPad you don't need the email, you do that from the app -- BirdDog will know more about this.  I download from the link in the email to a flash drive.
","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"208","kudosSumWeight":0,"postTime":"2019-03-28T17:02:59.765-04:00","lastPublishTime":"2019-03-28T17:02:59.765-04:00","metrics":{"__typename":"MessageMetrics","views":10465},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"category:HNSupport/community:ssqng67387board:TechSupport/message:111048/message:111125","repliesCount":0,"customFields":[],"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}}},"ModerationData:moderation_data:111126":{"__typename":"ModerationData","id":"moderation_data:111126","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:111126":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:21490"},"id":"message:111126","revisionNum":1,"uid":111126,"depth":15,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:TechSupport"},"parent":{"__ref":"ForumReplyMessage:message:111123"},"conversation":{"__ref":"Conversation:conversation:111048"},"subject":"Re: Connection Problems- Only with AOL","moderationData":{"__ref":"ModerationData:moderation_data:111126"},"body":"
the app for the computer is a software package. You need to buy a license for it.  But be warned that the desktop version USES YOUR DATA.  Only the app version doesn't.  The desktop version is also very glitchy.
bos2420 wrote:
Is there a trick to getting the app on a Win10 laptop?  I can see how to get it for my phones.  I must be doing something wrong.  Can't find how to authorize my laptop with Google Play.
(I don't use many (if any) apps on Win10)  Use em all the time on the phone.
","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"218","kudosSumWeight":0,"postTime":"2019-03-28T17:06:37.456-04:00","lastPublishTime":"2019-03-28T17:06:37.456-04:00","metrics":{"__typename":"MessageMetrics","views":11316},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"category:HNSupport/community:ssqng67387board:TechSupport/message:111048/message:111126","repliesCount":8,"readOnly":true,"customFields":[],"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}}},"Rank:rank:11":{"__typename":"Rank","id":"rank:11","position":12,"name":"Assistant Professor","color":"0066FF","icon":null,"rankStyle":"TEXT"},"ModerationData:moderation_data:111128":{"__typename":"ModerationData","id":"moderation_data:111128","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ModerationData:moderation_data:111235":{"__typename":"ModerationData","id":"moderation_data:111235","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:111235":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:24839"},"id":"message:111235","revisionNum":1,"uid":111235,"depth":18,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:TechSupport"},"parent":{"__ref":"AcceptedSolutionMessage:message:111133"},"conversation":{"__ref":"Conversation:conversation:111048"},"subject":"Re: Connection Problems- Only with AOL","moderationData":{"__ref":"ModerationData:moderation_data:111235"},"body":"
Well, the installer just left.  All is well in the world again.  The wife has her e-mail back.  Painless process, as has always been the case with us and Hughes.
Thanks again for everyone that tried to help.  I mentioned it to my installer, and he said he has heard of the same types of problems, and it has to go all the way up to the 'code writers' as he put it.
","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"233","kudosSumWeight":1,"postTime":"2019-04-03T20:01:03.523-04:00","lastPublishTime":"2019-04-03T20:01:03.523-04:00","metrics":{"__typename":"MessageMetrics","views":6061},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"category:HNSupport/community:ssqng67387board:TechSupport/message:111048/message:111235","repliesCount":1,"readOnly":true,"customFields":[],"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}}},"ModerationData:moderation_data:111238":{"__typename":"ModerationData","id":"moderation_data:111238","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:111238":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:21490"},"id":"message:111238","revisionNum":1,"uid":111238,"depth":19,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:TechSupport"},"parent":{"__ref":"ForumReplyMessage:message:111235"},"conversation":{"__ref":"Conversation:conversation:111048"},"subject":"Re: Connection Problems- Only with AOL","moderationData":{"__ref":"ModerationData:moderation_data:111238"},"body":"
","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"56","kudosSumWeight":1,"postTime":"2019-04-03T20:20:59.187-04:00","lastPublishTime":"2019-04-03T20:20:59.187-04:00","metrics":{"__typename":"MessageMetrics","views":6056},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"category:HNSupport/community:ssqng67387board:TechSupport/message:111048/message:111238","repliesCount":0,"customFields":[],"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}}},"ModerationData:moderation_data:111411":{"__typename":"ModerationData","id":"moderation_data:111411","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:111411":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:24839"},"id":"message:111411","revisionNum":1,"uid":111411,"depth":18,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:TechSupport"},"parent":{"__ref":"AcceptedSolutionMessage:message:111133"},"conversation":{"__ref":"Conversation:conversation:111048"},"subject":"Re: Connection Problems- Only with AOL","moderationData":{"__ref":"ModerationData:moderation_data:111411"},"body":"
So I got to use the PlayOn system.  I have both the Desktop and phone app.  I used the app.  Just to test, I selected 'The Tick' on Amazon.  30 minute video.  Had it play on the cloud, and then got the link to download the file.  About 250mb.  Put that on a USB stick, and plugged that into the back of the smart TV.  Worked like a charm.
Not simple, but allows Bonus Time to be used, or even if you are out and about on a public WiFi.  I get WiFi from the bank when I work weekends at our coffee hut, so that is how I will use it, most of the time.
","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"228","kudosSumWeight":1,"postTime":"2019-04-11T23:03:29.527-04:00","lastPublishTime":"2019-04-11T23:03:29.527-04:00","metrics":{"__typename":"MessageMetrics","views":6005},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"category:HNSupport/community:ssqng67387board:TechSupport/message:111048/message:111411","repliesCount":3,"readOnly":true,"customFields":[],"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}}},"ModerationData:moderation_data:111412":{"__typename":"ModerationData","id":"moderation_data:111412","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:111412":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:29869"},"id":"message:111412","revisionNum":1,"uid":111412,"depth":19,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:TechSupport"},"parent":{"__ref":"ForumReplyMessage:message:111411"},"conversation":{"__ref":"Conversation:conversation:111048"},"subject":"Re: Connection Problems- Only with AOL","moderationData":{"__ref":"ModerationData:moderation_data:111412"},"body":"
Does your TV have a special program built in that reads and plays what you have on the flash drive?  I have a smart TV, and it has a USB port, as well.  I wonder if that would work for me.  It would eliminate me having to play the items on my HDMI connected laptop.
I should try to find a .mp4 clip or something somewhere, put it on one of my flash drives, and just give it a try.  Now, to find something.  :p
","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"223","kudosSumWeight":0,"postTime":"2019-04-11T23:40:06.704-04:00","lastPublishTime":"2019-04-11T23:40:06.704-04:00","metrics":{"__typename":"MessageMetrics","views":6000},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"category:HNSupport/community:ssqng67387board:TechSupport/message:111048/message:111412","repliesCount":0,"customFields":[],"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}}},"ModerationData:moderation_data:111413":{"__typename":"ModerationData","id":"moderation_data:111413","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:111413":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:29869"},"id":"message:111413","revisionNum":1,"uid":111413,"depth":19,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:TechSupport"},"parent":{"__ref":"ForumReplyMessage:message:111411"},"conversation":{"__ref":"Conversation:conversation:111048"},"subject":"Re: Connection Problems- Only with AOL","moderationData":{"__ref":"ModerationData:moderation_data:111413"},"body":"
Okay, that's it.  I'm getting PlayOn Cloud.  I found a site with sample .mp4 files, and playing them on my TV via a USB flash drive works like a charm.  So now I won't even need to use my laptop!  Now, to get a couple of spare flash drives, as I want to download all three seasons of Deadwood, plus a few other things off the top of my head.
Thanks for the info about playing the files directly from a flash drive on a smart TV, bos2420 !  That's going to make it a lot more simple.
","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"228","kudosSumWeight":0,"postTime":"2019-04-12T00:00:05.396-04:00","lastPublishTime":"2019-04-12T00:00:05.396-04:00","metrics":{"__typename":"MessageMetrics","views":6000},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"category:HNSupport/community:ssqng67387board:TechSupport/message:111048/message:111413","repliesCount":1,"readOnly":true,"customFields":[],"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}}},"ModerationData:moderation_data:111416":{"__typename":"ModerationData","id":"moderation_data:111416","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:111416":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:21490"},"id":"message:111416","revisionNum":1,"uid":111416,"depth":20,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:TechSupport"},"parent":{"__ref":"ForumReplyMessage:message:111413"},"conversation":{"__ref":"Conversation:conversation:111048"},"subject":"Re: Connection Problems- Only with AOL","moderationData":{"__ref":"ModerationData:moderation_data:111416"},"body":"
Yeah, that option works well if you don't want to use a laptop.  I have tried that before, though for me the laptop is much more convenient.
","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"228","kudosSumWeight":0,"postTime":"2019-04-12T05:54:57.619-04:00","lastPublishTime":"2019-04-12T05:54:57.619-04:00","metrics":{"__typename":"MessageMetrics","views":5985},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"category:HNSupport/community:ssqng67387board:TechSupport/message:111048/message:111416","repliesCount":0,"customFields":[],"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}}},"CachedAsset:text:en_US-components/tags/TagView/TagViewChip-1728282321000":{"__typename":"CachedAsset","id":"text:en_US-components/tags/TagView/TagViewChip-1728282321000","value":{"tagLabelName":"Tag name {tagName}"},"localOverride":false}}}},"page":"/forums/ForumMessagePage/ForumMessagePage","query":{"boardId":"TechSupport","messageSubject":"connection-problems--only-with-aol","messageId":"111048","replyId":"111123"},"buildId":"OKtI0OLKuXmERTJKBVqYX","runtimeConfig":{"buildInformationVisible":false,"logLevelApp":"info","logLevelMetrics":"info","openTelemetryClientEnabled":false,"openTelemetryConfigName":"hughes","openTelemetryServiceVersion":"24.11.0","openTelemetryUniverse":"prod","openTelemetryCollector":"http://localhost:4318","openTelemetryRouteChangeAllowedTime":"5000","apolloDevToolsEnabled":false},"isFallback":false,"isExperimentalCompile":false,"dynamicIds":["./components/seo/QAPageSchema/QAPageSchema.tsx","./components/community/Navbar/NavbarWidget.tsx","./components/community/Breadcrumb/BreadcrumbWidget.tsx","./components/customComponent/CustomComponent/CustomComponent.tsx","./components/messages/TopicWithThreadedReplyListWidget/TopicWithThreadedReplyListWidget.tsx","./components/messages/RelatedContentWidget/RelatedContentWidget.tsx","./components/messages/MessageListForNodeByRecentActivityWidget/MessageListForNodeByRecentActivityWidget.tsx","./components/messages/MessageView/MessageViewStandard/MessageViewStandard.tsx","../shared/client/components/common/List/UnstyledList/UnstyledList.tsx","./components/messages/MessageView/MessageView.tsx","./components/messages/MessageView/MessageViewInline/MessageViewInline.tsx","../shared/client/components/common/List/ListGroup/ListGroup.tsx","../shared/client/components/common/Pager/PagerLoadMore/PagerLoadMore.tsx","../shared/client/components/common/List/UnwrappedList/UnwrappedList.tsx","./components/tags/TagView/TagView.tsx","./components/tags/TagView/TagViewChip/TagViewChip.tsx"],"appGip":true,"scriptLoader":[{"id":"mixPanel","src":"https://community.hughesnet.com/t5/s/ssqng67387/pagescripts/1726769041000/mixPanel.js?page.id=ForumReplyPage&entity.id=board%3ATechSupport&entity.id=message%3A111123","strategy":"afterInteractive"}]}
