Go to the modem's page (http://192.168.0.1/#!/home/status) and post what the number next to State Code is, especially at times when the speed is so slow That will provide some information about what may be going on.
You will also need to post the URL to your My Results page from Testmy.net.
- Danny895 years agoJunior
As of now, my speeds are normal, that started at 6AM
My state code was either FAP Condition or Fully Operational, the whole time. Its been 0.0.0 Fully Operational since 2AM, even when I was unable to load a webpage, and if I attempted to download my game from Steam, it would hold at less than 20KBs(At 6AM when it came back to normal speeds, it went up to 900kbs and even peaked at 2.5MBs!)
I'll post the speeds from TestMy if the problem starts again. Hopefully it won't, but it did this yesterday where in the morning it suddenly fixed itself..and then by night it was extremely slow to the point of not being usable, which is what makes me think theres some other issue. Oh, and I checked further devices, and they all reported the extremely slow speeds during the...slow time
Im having flashbacks to when i was on dial up
Edit: Getting some baseline from TestMy if needed!- maratsade5 years agoDistinguished Professor IV
Let's hope it was a transitory thing, but getting some baseline speed tests would be a good idea, and then running tests if the issue comes back. Hopefully it won't, at least during the weekend.
Make sure that if/when you run the tests at testmy you follow the troubleshooting protocol. Just in case, the full instructions are as follows...
-if testing upload instead of download, use the manual 4MB size upload test file
If you don't know how to disable the WiFi in the HT2000W modem, please see "How do I manage my built-in WiFi modem?" in this PDF. Please be sure to click "Save Settings" after unchecking "SSID Enable" for each of the four tabs individually (2.4Ghz, then 2.4Ghz Guest, then 5Ghz, then 5Ghz Guest).- Danny895 years agoJunior
Starting at 6AM on Saturday started acting right, but last night at 4AM(Monday morning) a storm came through, knocked out my internet for awhile of course, and when it came back its doing this extreme slow speeds
Based on the three 12-25MB download tests ive done, speeds are at 40KBs which I believe is abnormal, and I can barely run any website while its acting up like this. Computer is directly plugged into the modem, WiFi is deactivated. Ive used multiple browsers on this computer, and ive tried another computer and a Nintendo Switch, all with the same results
But obviously its a transient problem. Is there any information on the Beam still being heavily overloaded, or some other kind of issues? I'll edit with my speed tests in a few, its taking awhile but I wanted to have some time between them. I forgot about the special download speed, and over Saturday and Sunday I had done the standard tests. Further more, im on total throttle now, no data for regular times or the bonus zone, but I was in that state all of Sunday and it ran well, speeds on a download showing up as over 200KBs
https://testmy.net/quickstats/DanKaiser
Got the quickstats, I'll do a couple more download tests!
