It's likely the weather interfering with the signal.
EDIT: When the issue is taking place, please post the modem's state code, which can be found here: http://192.168.0.1/#!/home/status
Can't be the weather, thats already gone and there was no storms when this started last week.
Right now my state code is 24.1.1 Download Throttled. Satellite recieve strength is 105
The 24.1.1 code means you've exceeded your monthly data and that your speeds will be throttled until your data resets. You can also buy tokens to reset it before that.
If you have bonus data left, your speed will be normal during bonus time (2 am to 8 am your local time).
- Danny895 years agoJunior
Oh, I know. Ive just never had a throttle so hard that it has literally made me incapable of using the internet. AND most importantly, I had data when the problem first began, I didn't run out of Data until later on Saturday
https://testmy.net/quickstats/DanKaiser
Obviously that mega speed test would be the one for when I still had data, and the problem had resolved itself for Saturday- maratsade5 years agoDistinguished Professor IV
Those mega-spikes are SO annoying. They're some kind of glitch, and the techs will ignore those.
Did you run out of ALL data, or do you still have your bonus data? I ask because the tests won't be very helpful to the techs if you're running them while under FAP. You need to run them while you have data so they show whether there's an issue.
Do you have many devices connected to your network? If so, you may want to disconnect as many as possible from the network so the devices are not competing for system resources. The speed drain is much more noticeable during FAP because there isn't a lot of speed to go around to begin with.
Even though the storm(s) may be gone, sometimes it takes a while for the system to recover.
EDIT: Hopefully the reps here (Liz , Remy , Damian ) will get involved with your case and check your modem, just in case there's an issue there, and indicate whether you should run more tests or do some other kind of troubleshooting.
- 11 months ago
- 11 months ago
