The 24.1.1 code means you've exceeded your monthly data and that your speeds will be throttled until your data resets. You can also buy tokens to reset it before that.
If you have bonus data left, your speed will be normal during bonus time (2 am to 8 am your local time).
Oh, I know. Ive just never had a throttle so hard that it has literally made me incapable of using the internet. AND most importantly, I had data when the problem first began, I didn't run out of Data until later on Saturday
https://testmy.net/quickstats/DanKaiser
Obviously that mega speed test would be the one for when I still had data, and the problem had resolved itself for Saturday
Those mega-spikes are SO annoying. They're some kind of glitch, and the techs will ignore those.
Did you run out of ALL data, or do you still have your bonus data? I ask because the tests won't be very helpful to the techs if you're running them while under FAP. You need to run them while you have data so they show whether there's an issue.
Do you have many devices connected to your network? If so, you may want to disconnect as many as possible from the network so the devices are not competing for system resources. The speed drain is much more noticeable during FAP because there isn't a lot of speed to go around to begin with.
Even though the storm(s) may be gone, sometimes it takes a while for the system to recover.
EDIT: Hopefully the reps here (Liz , Remy , Damian ) will get involved with your case and check your modem, just in case there's an issue there, and indicate whether you should run more tests or do some other kind of troubleshooting.
- Danny895 years agoJunior
Im out of all data right now. The problem began on Wednesday or Thursday, and I didnt post about it until Saturday since I was hoping it would resolve itself I fully ran out of data, Bonus Data, on Saturday, after the speed issues ended
I'll be out of data for 5 days.
Ive thought of that, but ive checked everything that could be potentially eating that data, and theres nothing. I run a pretty simple ship with the internet of things!
And beyond the speeds being slow, maxing at 40kBs(excuse my inconsistancy in typing that out), for whatever reason websites refuse to connect properly or load properly. Its some real dial up flashbacks. As noted in my original post, my modem isnt doing anything strange, no strange lights or blinking patterns, and my dish and dish eye look perfectly fine...from the ground at least. Due to that and the transience of the speed issue, I feel like theres something wrong at Hughes, or I got me a freeloader eating my internet somewhere.... - maratsade5 years agoDistinguished Professor IV
Yeah, something's clearly not right over there. Let's hope the reps on this site chime in today.
These may be stupid questions, but: is your device fully updated to the latest operating system and drivers? Are the browsers all updated to the latest version? Does the slow website issue happen on all browsers? Does the slowness happen if you connect to the modem directly, using a LAN cable?
Yeah, everything is updated enough I believe, and since its a widespread issue I don't think the older computer's oldness is as much an issue...
I just had it trying to do a 25MB test, and it ended up freezing up somewhere in the middle and not finishing at all. Ive checked all avenues for something hogging the data, but I don't think theres anything, and even if there was, this is...beyond the pale unless theyve implemented an Ultra-Throttle
Hope to hear something from tech soon! - maratsade5 years agoDistinguished Professor IV
Yeah, things do look super slow, even for FAP. You may want to stop running tests unless a rep directs you to do so. I don't think these tests you're running under FAP would be useful, plus you're going to end up screaming uncontrollably and pulling your hair out. :)
- 11 months ago
- 11 months ago
