Hi bronccat,
The HughesNet reps on this site will be back on Monday, and to address your speed issues, they require that you follow a specific troubleshooting procedure, which is detailed here: https://community.hughesnet.com/t5/Tech-Support/Think-you-have-slow-speeds/m-p/110034#M74607
Best way is to have 3 tests run 3 times a day (3 in the morning, 3 in the afternoon, 3 in the evening). Tests need to spaced out a bit, and they need to be specific file sizes. Everything is explained in the link I posted above.
Do you still have data? Speeds will tank when you run out.
Good luck; I hope the issue gets resolved soon for you.
I was testing via testmy on 5 ghz band with nothing else online. Will do with laptop and ethernet and space out tests accordingly.
I know I won't get best results via wifi, but .4 MBPS is pretty dire no matter lol
Thanks!
That's pretty bad speed, definitely. When you experience these slow speeds, what's the state code? (the state code can be found here: http://192.168.0.1/#!/home/status).
Also, what's your browsing experience when you measure those speeds? Was slow browsing what led you to run speed tests?
