Hi bronccat,
She will know because she will check the URL to your results list. And because she's an all powerful, all seeing entity. Or a magical pixie. HN neither confirms nor denies.
bronccat wrote:
My question is - and not to be a smart**bleep** - but how will she magically know that I have run the tests "correctly" and know I am now worthy of a response?
OK, maybe I'm being a little smart**bleep**ed.
They keep track of the posts and what we talk about -- when the tests have been done, she'll check. :)
bronccat wrote:
maratsade LMAO :heart:
I just meant, what would prompt her to check :smileyvery-happy:
- bronccat5 years agoJuniorWell I ran several tests yesterday as per instructions (25 DL / 4 UL)
Back home now and will call them to discuss. - GabeU5 years agoDistinguished Professor IV
Back home now and will call them to discuss.Why would you call them?
- bronccat5 years agoJuniorOf course, that would be my preference. I didn't know if protocol was to talk to both - or?
I also didn't know how long I should give them to respond here. - bronccat5 years agoJuniorIf I'm on the mountain, this is all I have. I'll be back there first of next week. I had hoped all of this would get resolved on here before I left but with the ethernet connection issue my timing sucked lol
- bronccat5 years agoJuniorYessir! Left it on for this reason.
You rock man, appreciate it! - bronccat5 years agoJuniorA little LOL...
I almost ran a test here (just bc I'm new to "test.my" and realized it would look crazy. I know the location would show but didn't want to muddy the waters ;-) - Liz5 years agoModerator
Good morning bronccat,
Hi bronccat,
Hi broncat,
- bronccat5 years agoJuniorLiz
Screenshots?
Thank you. - maratsade5 years agoDistinguished Professor IV
- bronccat5 years agoJuniorI'm not there and its busy work. No way a video streaming app is going to create slow speed test results.
BTW, this isn't a CO-OP I'm a paying customer and expect better. I'm not going to apologize for my frustration either. - maratsade5 years agoDistinguished Professor IV
Hi bronccat,
Am I to wait a week to drive down there, update my apps, send screenshots proving I did - then run a speed test on a TOTALLY separate device just to prove that it wasn't the streaming apps? Because that's what is being asked of me. - GabeU5 years agoDistinguished Professor IV
Good luck.
- bronccat5 years agoJuniorGabeU
That is absurd, IMO.
Sigh. - Liz5 years agoModerator
Hope that clears things up.
