Hi bronccat,
bronccat wrote:
Well I ran several tests yesterday as per instructions (25 DL / 4 UL)
Back home now and will call them to discuss.
Why would you call them?
I also didn't know how long I should give them to respond here.
- bronccat6 years agoJuniorIf I'm on the mountain, this is all I have. I'll be back there first of next week. I had hoped all of this would get resolved on here before I left but with the ethernet connection issue my timing sucked lol
- bronccat6 years agoJuniorYessir! Left it on for this reason.
You rock man, appreciate it! - bronccat6 years agoJuniorA little LOL...
I almost ran a test here (just bc I'm new to "test.my" and realized it would look crazy. I know the location would show but didn't want to muddy the waters ;-) - Liz6 years agoModerator
Good morning bronccat,
Hi bronccat,
Hi broncat,
Screenshots?
Thank you. - maratsade6 years agoDistinguished Professor IV
- bronccat6 years agoJuniorI'm not there and its busy work. No way a video streaming app is going to create slow speed test results.
BTW, this isn't a CO-OP I'm a paying customer and expect better. I'm not going to apologize for my frustration either. - maratsade6 years agoDistinguished Professor IV
Hi bronccat,
Am I to wait a week to drive down there, update my apps, send screenshots proving I did - then run a speed test on a TOTALLY separate device just to prove that it wasn't the streaming apps? Because that's what is being asked of me. - GabeU6 years agoDistinguished Professor IV
Good luck.
- bronccat6 years agoJuniorGabeU
That is absurd, IMO.
Sigh. - Liz6 years agoModerator
Hope that clears things up.
NM
- 11 months ago
- 11 months ago
