Hi bronccat,
I also didn't know how long I should give them to respond here.
- bronccat5 years agoJuniorYessir! Left it on for this reason.
You rock man, appreciate it! - bronccat5 years agoJuniorA little LOL...
I almost ran a test here (just bc I'm new to "test.my" and realized it would look crazy. I know the location would show but didn't want to muddy the waters ;-) - Liz5 years agoModerator
Good morning bronccat,
Hi bronccat,
Hi broncat,
- bronccat5 years agoJuniorLiz
Screenshots?
Thank you. - maratsade5 years agoDistinguished Professor IV
- bronccat5 years agoJuniorI'm not there and its busy work. No way a video streaming app is going to create slow speed test results.
BTW, this isn't a CO-OP I'm a paying customer and expect better. I'm not going to apologize for my frustration either. - maratsade5 years agoDistinguished Professor IV
Hi bronccat,
Am I to wait a week to drive down there, update my apps, send screenshots proving I did - then run a speed test on a TOTALLY separate device just to prove that it wasn't the streaming apps? Because that's what is being asked of me. - GabeU5 years agoDistinguished Professor IV
Good luck.
- bronccat5 years agoJuniorGabeU
That is absurd, IMO.
Sigh. - Liz5 years agoModerator
Hope that clears things up.
NM
Firefox 82.0.2
Laptop
- 4 months ago
- 3 months ago
