Hi bronccat,
Hi bronccat,
- bronccat6 years agoJunior
- Liz6 years agoModerator
Hi broncat,
Screenshots?
Thank you. - maratsade6 years agoDistinguished Professor IV
- bronccat6 years agoJuniorI'm not there and its busy work. No way a video streaming app is going to create slow speed test results.
BTW, this isn't a CO-OP I'm a paying customer and expect better. I'm not going to apologize for my frustration either. - maratsade6 years agoDistinguished Professor IV
Hi bronccat,
Am I to wait a week to drive down there, update my apps, send screenshots proving I did - then run a speed test on a TOTALLY separate device just to prove that it wasn't the streaming apps? Because that's what is being asked of me. - GabeU6 years agoDistinguished Professor IV
Good luck.
- bronccat6 years agoJuniorGabeU
That is absurd, IMO.
Sigh. - Liz6 years agoModerator
Hope that clears things up.
NM
Firefox 82.0.2
Laptop
Moving forward I'm going on the assumption this is in your Firefox browser on your isolated laptop running Win 10, so for any data provided, please be sure it was gathered in those same circumstances. If there are other connected devices, delivered speeds are shared amongst them all.-Liz
The email was before, file DL was after.
Page load issue was more prevalent on phone, I only encountered similar on Laptop using FB. I generally don't do much leisure on Laptop.
Also from notes, 10/25 6mb file took a bit over a minute to send. - Liz6 years agoModerator
Which version of Android?
Which browser and version?
- 11 months ago
- 11 months ago
