Hi bronccat,
Hi bronccat,
Am I to wait a week to drive down there, update my apps, send screenshots proving I did - then run a speed test on a TOTALLY separate device just to prove that it wasn't the streaming apps? Because that's what is being asked of me.
Good luck.
- bronccat6 years agoJuniorGabeU
That is absurd, IMO.
Sigh. - Liz6 years agoModerator
Hope that clears things up.
NM
Firefox 82.0.2
Laptop
Moving forward I'm going on the assumption this is in your Firefox browser on your isolated laptop running Win 10, so for any data provided, please be sure it was gathered in those same circumstances. If there are other connected devices, delivered speeds are shared amongst them all.-Liz
The email was before, file DL was after.
Page load issue was more prevalent on phone, I only encountered similar on Laptop using FB. I generally don't do much leisure on Laptop.
Also from notes, 10/25 6mb file took a bit over a minute to send. - Liz6 years agoModerator
Which version of Android?
Which browser and version?
Current and last UD 10.21.20
Samsung S8+
Android version 9 - bronccat6 years agoJuniorTo be frank (not Drebin) the testmy results are the absolute best evidence that the slow speeds are real and not a app issue on my end.
I understand what you need to make sure my HW is UTD - but beyond that, testmy tells the tale pretty accurately - Liz6 years agoModerator
Regarding the Android, the latest version is 11 so I suggest updating that. Also, the network analyzer app from Netgear provides a lot of useful insights, like whether there's any interference on the network and suggests which channel to use. On your own you can try troubleshooting your phones with that.
Typically for troubleshooting wifi devices, our engineers suggest first switching networks to see if there's a difference (I see you've tried that), and then to also power cycle the modem and the wifi device.
To power cycle the modem, the power cable should be disconnected from its power brick (not from the back of the modem) for at least 20 seconds before replugging. A device can just be powered down for 20 seconds before turning it back on.
First lets check on the directly connected laptop with wifi on the modem disabled so we're sure it's isolated and gather this info:
Which URLs are you testing (I suggest whichever one's you frequetly struggle with)
How long does each URL take to load?
Have you ever been able to successfully visit that URL?
When did you first notice having difficulty visiting that URL?
What time did you test these URLs?
Is there any difference in page load times if done at different times of day/night? I suggest checking in the morning, midday, and evening if possible.
I know this is a lot to do, but this should be enough to present to engineering if we can't pinpoint a root cause.
Edit: More troubleshooting steps typically suggested by engineering:
Disable uPnP, any difference in load time??
Change security setting from WPA2 to WPA/WPA2 in wifi settings on the modem
Disable IPv6
maratsade wrote:The Chrome app GabeU mentioned was PageLoad times.
Good memory, and close. It was actually "Page load time", but it's no longer available, unfortunately. I still have it though.
I tried the one you linked to, and though the color coding from the most recently opened page spans all open pages, so that part can't be relied on if you have more than one browser page open, the stated load time itself is spot on. I tried it side by side with Page load time, and the numbers were identical every time. :)
Edit: The color coding bleed over may be due to the extension I use for opening new tabs as new windows. When I set Chrome back to default, the color coding worked properly. Still, the numbers are what's important, and they show properly regardless.
The following page load timer seems to work well with Firefox....
$&,@,@ well my lengthy reply disappeared so I'll have to redo all of that later.
I'll say this in response to everything:
1) None of these devices have any issues anywhere else in the world except for on this network.
2) I have tried most all of this - I have even tried another wireless router
3) My phone is UTD according to my phone. Android agrees.
4) ALL THAT REALLY MATTERS IS THAT MY LAPTOP, CONNECTED VIA ETHERNET IS DL WELL BELOW 1MBPS!!!
This is ridiculous. There can't be any better proof that there is a real issue than what I have provided with the logs thus far. All of the other discussion about different devices and URLs is completely wasting my time. - maratsade6 years agoDistinguished Professor IV
You're not a tech or a satellite communications expert; don't tell them how to run their business. They're trying to help you and all you do is bellyache about it.
- bronccat6 years agoJuniormaratsade
Kindly keep your opinion to yourself - and you certainly don't need to start telling me what to do. I'll $&,@ well express my angst at this situation and process if I so please. You are such a HN apologist.
I'd prefer that you recuse yourself from this conversation entirely after this and prior comments you've made. Don't need your static. - maratsade6 years agoDistinguished Professor IV
And as a fellow subscriber, I don't need your ill-mannered, entitled treatment of those who are trying to help you. This is a public place and you're making a fool of yourself in front of everyone. Kindly treat those who are trying to help you with respect.
bronccat wrote:
This is ridiculous.What's ridiculous is that's it's taken nearly two weeks and eleven pages to even get to this point. With the very first reply instructions were given for how to get help. It took nearly a week before you even said "I don't have an ethernet port", which should have been your first response to that first reply, and with the interim being filled up with complaints about the phone reps and various other things.
Then, when the tests are finally does and a rep responds to help you and asks pertinent questions to respond to the plethora of complaints you've made, you decide to start making demands of what you want and what you are willing and not willing to do, as well as making bombastic comments. Either take the help or don't, but for you to treat the people who've tried to help you the way you are is not only ridiculously disrespectful, it's needlessly immature.
Good luck to you.
- 11 months ago
- 11 months ago
