dzfire's avatar
dzfire
7 years ago
Solved
System will not boot
System stopped working. Tried rebooting, power down, and reset. Only the power light and wireless lights come on. Checked all cabels.
  • Over 12 years and HughesNet has taken care of me again. Thanks Amanda.
  • Looks like I can access 192.168.42.1 through the LAN and access the wifi portion of the router. Still cannot access 192.168.0.1 on the LAN. Wifi connects but no internet.
    • Amanda's avatar
      Hi dzfire,
      This is definitely odd - it could be that another gateway address is set on the device you are trying to use (192.168.1.1). Do you have any other devices you can test? Are all of your lights on the HughesNet modem lit or just a couple, like in your original post?
      Thanks
      • dzfire's avatar
        dzfire
        Only two lights are lit, power and wireless.
  • Sorry, I cannot connect to that even with a direct connection.
    • Amanda's avatar
      Okay, I think I have one last thing we can try before I start making calls around here :)
      If you can get to 192.168.42.1 ...
      Scroll down to the Information box
      under WAN, copy the IP address listed for Gateway and try to browse to that instead
      • dzfire's avatar
        dzfire
        Gateway is 0.0.0.0 with no connection. DNS is 192.168.0.1 with no connection :(
