Good morning everyone,
Thank you,
For what it's worth, have similar problem with Amazon. After having spent quite a bit of time trying to resolve it, including powering the satellite modem down, then up again, with no success, someone in this thread mentioned the "reset" button on the modem. So, having tried a lot of other things and even after having powered it off then on with no success, I did use the "reset" button on the modem and somehow that fixed the problem. Don't know for how long, but at least it's clear where the problem resides. Just for info.
Please do not utilize the reset button unless instructed to do so by a tech or rep. Doing so can cause more harm than good, and harm that may require a tech visit to fix, of which you would be responsible for paying. Again, please leave the reset button alone.
