Wifi drop out
No obvious relationship with the high speed data plan being full or empty.
The wifi light goes out while the wifi RF is down.
I have unplugged and rebooted the indoor unit / wifi ... no affect.
Diagnostic Code: 0051-2005-1200-5126. - Yes, we are throttled right now but it doesn’t seem the matter - it does it on full speed as well.
Ideas?
Hi sepmeier,
I see it's your first post here, so welcome to the community! I'm sending you a new modem to swap out. You can use the box it comes in to send back your old modem; there should be a return label in the outer pouch. Let me know how the new modem works out for you!
- sepmeierSophomoreLiz, thank you! I emailed you my address, though you should have it on file. Thanks again!
- LizModerator
Hi sepmeier,
In the off chance that you don't normally do so, please be sure to keep your modem plugged in so that the reps can run remote diagnostics on it if they deem it necessary. They also may need some personal information from you in order to locate your account, but they'll ask for it to be given via private message, for which they normally provide a link.
Also, at least for the time being, it would be best to not power cycle or reboot the modem, as this will wipe system logs that may be important in determining the cause of the issue.
Hopefully you'll see a reply from a rep soon.
- 6 months ago
- 11 years ago
