john.fenley1's avatar
john.fenley1
7 years ago
download speed took a dive 4 days ago
Any tips or tricks to restore the excellent HughesNet service I have had over the last decades?
Date RecordedDownload Result(KBPS)Upload Result(KBPS)
11/21/2018 12:52509518
11/21/2018 11:07633348
11/21/2018 11:04318746
11/21/2018 9:096251854
11/21/2018 9:06372689
11/21/2018 8:1913291850
11/21/2018 8:16934659
11/26/2017 17:2623514394
Thanks, John
  • I had a chance to call tech support and the thought is the modem has failed due to age. I was given the opportunity to rent/lease a new modem and move to a super new 20GB plan (currently 50/50 @ $100), two-year contract while on the same satellite. Is there some else to call? I know, customer retention; just venting. Thanks, John
    You should create a free account at Testmy.net, as these are the only speed tests that HN accepts.  You would then run some speed thests there and the site keeps logs that the mods or engineers can view and analyze.
    Do you have Gen 4 or Gen 5?
        John, make sure to connect your device directly to the modem via Ethernet cable  (this helps determine whether the problem is with the modem).  Also note that  the recommended test file sizes for Gen4 are 12MB for download and 2MB for upload.
        john.fenley1 wrote:
        Gen 4 and will use testmy.net, thnaks, John
