If the DNS records are corrupted, you have to turn off every device connecting to the modem before rebooting the modem. Failing to do that may just re-corrupt the DNS entry because you're likely repopulating it with the bad one instead of getting the correct one off the internet. The correct procedure is:
1. Turn off all devices (computers, phones, anything connected)
2. Turn off the modem and or any additonal routers by unplugging the power cord from the wall socket.
3. Wait a minute and restart modem/routers.
4. Wait until the system light on the modem is lit and start turning your devices back on.
gaines-
Ahh, the mysteries of the internet. While I don't understand all that, I kind of get what you are saying. However, it has been 10 days, at least. Getting pretty old.
Mark-
Another solution that doesn't make sense to me (NOT a criticizm, just above my pay grade) but I am willing to try anything.
So, tried that. Shut off all the laptops, desktop, and phones (even though they are not connected to the network) Unplugged modem. Made a sammich. Plugged back in, and turned on computers after modem was all lit up. No joy.
I would like to try a new modem. Will contact CS and see if they can read this thread and advise. I hate going through phone support, or even on-line support, as they have to follow the 'book' (and I get that) but I am 22 chapters into the book already, but they have to start on page 1- "Turn the modem off, and turn it on again." Siiiiiigh
- bos24207 years agoJunior
Apparently, this happens with any 'Old Timey' website. :smileyvery-happy:
Just tried to look at a link on Yahoo. Same error message. Figured it was just the link. Tried to go to Yahoo.com. Nope.
Went to the phone hotspot. Loads right up.
I can guarantee you that if the modem is allowing you to get to a web page anywhere at all, it's not broken. There's something else that's route-related. Whether it's your local DNS (which is what my procedure fixes), or the DNS your modem is attempting to use, or (and this is a distinct possibility) the route to AOL is broken. But replacing the modem isn't going to fix any of that.
We've eliminated the first question. To eliminate the second question, go to http://192.168.42.1/dns.htm (you may need to put in your wifi administrator password). Is the "Obtain from ISP" box checked?
Mark,
That address will not connect. Where am I trying to go? Router, or modem?
- gaines_wright7 years agoTutor
bos2420 wrote:Apparently, this happens with any 'Old Timey' website. :smileyvery-happy:
Ah, the plot thickens! Here's what I get running traceroute to aol.com:
traceroute to aol.com (106.10.218.150), 30 hops max, 60 byte packets
1 192.168.42.1 (192.168.42.1) 0.278 ms 0.249 ms 0.231 ms
2 100.67.205.153 (100.67.205.153) 0.470 ms 0.523 ms 0.610 ms
3 dpc6935186182.direcpc.com (69.35.186.182) 627.393 ms 687.188 ms 687.168 ms
4 dpc6935188058.direcpc.com (69.35.188.58) 687.121 ms 707.026 ms 707.022 ms
5 ae13-575.edge3.Denver1.Level3.net (4.28.103.141) 706.975 ms 725.744 ms 725.895 ms
6 * * *
7 PCCW-level3-30G.Dallas1.Level3.net (4.68.110.246) 791.410 ms 791.437 ms 791.389 ms
8 TenGE0-1-0-17.br02.hkg12.pccwbtn.net (63.218.174.61) 981.199 ms 786.976 ms 766.663 ms
9 63-216-176-170.static.pccwglobal.net (63.216.176.170) 756.616 ms 766.603 ms 744.669 ms
10 et-3-3-0.pat1.sgy.yahoo.com (183.177.82.40) 764.490 ms 774.403 ms 838.837 ms
11 ae-5.msr1.sg3.yahoo.com (203.84.209.87) 838.634 ms 789.498 ms 789.302 ms
12 ae-2.clr2-a-gdc.sg3.yahoo.com (106.10.128.5) 789.140 ms ae-2.clr1-a-gdc.sg3.yahoo.com (106.10.128.3) 879.374 ms 779.340 ms
13 lo0.fab1-3-gdc.sg3.yahoo.com (106.10.131.217) 865.655 ms lo0.fab2-3-gdc.sg3.yahoo.com (106.10.131.216) 855.578 ms lo0.fab4-3-gdc.sg3.yahoo.com (106.10.131.214) 889.348 ms
14 lo0.usw2-1-lba.sg3.yahoo.com (106.10.128.239) 889.240 ms lo0.usw1-1-lba.sg3.yahoo.com (106.10.128.238) 869.501 ms lo0.usw2-1-lba.sg3.yahoo.com (106.10.128.239) 859.566 ms
15 w2.src4.vip.sg3.yahoo.com (106.10.218.150) 779.505 ms 779.419 ms 789.324 msAs you can see, yahoo.com shows up several times. Like I said before I'm not sure about what all of this means, but it looks like yahoo.com is on the way to aol.com. Or maybe I should say it's in the way. :>)>
I doubt the modem is your problem. I think the problem is past the Hughes gateway. I'm surprised you haven't heard from a mod about this yet. Like I said, I've seen problems that were similar before.
BTW if you upgrade to gen5, make sure you don't plug the modem in to your system until the bonus period, otherwise you'll take a big hit to your anytime data just for the modem to initialize.
Yahoo, AOL... I think it's all Verizon under the Oath: logo, aka Verizon Media.
