bos2420 wrote:That was very stupid of me, gentlemen. Sorry for sending you down the wrong road.
No biggie. We all forget things sometimes. Two days in a row last week I forgot to put my mug in my Keurig before hitting the brew button. Let's just say I had an awful mess, and again, two days in a row. :p
I own a small coffee hut here in MT. Sometimes I forget to put the shot glasses under the portafilter to catch the espresso. So, I get that.
I 'think' I wanted Gen5 when we upgraded a few years ago, but it was not available in our Zip Code then. (It just came out) I have been with Hughes for 15 years, we have no cable. Heck, we still have copper phone lines. The last modem went bad, and I had a router go bad also. That is why I was thinking router.
If anyone has any other ideas, I am open to listen. At this point, I think I will upgrade to Gen 5. Would be nice if I didn't have to pay for the install, but we will see.
