bos2420 wrote:Apparently, this happens with any 'Old Timey' website. :smileyvery-happy:
Just tried to look at a link on Yahoo. Same error message. Figured it was just the link. Tried to go to Yahoo.com. Nope.
Went to the phone hotspot. Loads right up.
Ah, the plot thickens! Here's what I get running traceroute to aol.com:
traceroute to aol.com (106.10.218.150), 30 hops max, 60 byte packets
1 192.168.42.1 (192.168.42.1) 0.278 ms 0.249 ms 0.231 ms
2 100.67.205.153 (100.67.205.153) 0.470 ms 0.523 ms 0.610 ms
3 dpc6935186182.direcpc.com (69.35.186.182) 627.393 ms 687.188 ms 687.168 ms
4 dpc6935188058.direcpc.com (69.35.188.58) 687.121 ms 707.026 ms 707.022 ms
5 ae13-575.edge3.Denver1.Level3.net (4.28.103.141) 706.975 ms 725.744 ms 725.895 ms
6 * * *
7 PCCW-level3-30G.Dallas1.Level3.net (4.68.110.246) 791.410 ms 791.437 ms 791.389 ms
8 TenGE0-1-0-17.br02.hkg12.pccwbtn.net (63.218.174.61) 981.199 ms 786.976 ms 766.663 ms
9 63-216-176-170.static.pccwglobal.net (63.216.176.170) 756.616 ms 766.603 ms 744.669 ms
10 et-3-3-0.pat1.sgy.yahoo.com (183.177.82.40) 764.490 ms 774.403 ms 838.837 ms
11 ae-5.msr1.sg3.yahoo.com (203.84.209.87) 838.634 ms 789.498 ms 789.302 ms
12 ae-2.clr2-a-gdc.sg3.yahoo.com (106.10.128.5) 789.140 ms ae-2.clr1-a-gdc.sg3.yahoo.com (106.10.128.3) 879.374 ms 779.340 ms
13 lo0.fab1-3-gdc.sg3.yahoo.com (106.10.131.217) 865.655 ms lo0.fab2-3-gdc.sg3.yahoo.com (106.10.131.216) 855.578 ms lo0.fab4-3-gdc.sg3.yahoo.com (106.10.131.214) 889.348 ms
14 lo0.usw2-1-lba.sg3.yahoo.com (106.10.128.239) 889.240 ms lo0.usw1-1-lba.sg3.yahoo.com (106.10.128.238) 869.501 ms lo0.usw2-1-lba.sg3.yahoo.com (106.10.128.239) 859.566 ms
15 w2.src4.vip.sg3.yahoo.com (106.10.218.150) 779.505 ms 779.419 ms 789.324 ms
As you can see, yahoo.com shows up several times. Like I said before I'm not sure about what all of this means, but it looks like yahoo.com is on the way to aol.com. Or maybe I should say it's in the way. :>)>
I doubt the modem is your problem. I think the problem is past the Hughes gateway. I'm surprised you haven't heard from a mod about this yet. Like I said, I've seen problems that were similar before.
BTW if you upgrade to gen5, make sure you don't plug the modem in to your system until the bonus period, otherwise you'll take a big hit to your anytime data just for the modem to initialize.
Yahoo, AOL... I think it's all Verizon under the Oath: logo, aka Verizon Media.
- gaines_wright7 years agoTutor
MarkJFine wrote:Yahoo, AOL... I think it's all Verizon under the Oath: logo, aka Verizon Media.
Well, that explains everything! This is all an evil plot by Verizon to sabotage a competitor. :>)>
