You should like the Gen5. It works pretty well for me. And the HT2000W has built in WiFi, so if anything were to ever go wrong with your own router you'll still it.
That whole Dish and HBO thing is angering a lot of people, especially because of GOT. I'm looking forward to the Deadwood film, as well.
You may even want to take a look at PlayOn Cloud. With it you can download GOT and other things as a file (.mp4) instead of actually having to stream it. It's a great way to be able to take advantage of the Bonus Zone. It streams what you choose to the cloud, then converts it to an .mp4 file for downloading. And what you download you keep, as well. There's no expiration. You then use your media player, like VLC or Windows' built in player, to view the file. And best of all is that there's no buffering, as you're watching the programs/movies from already downloaded files. It's a pretty inexpensive service, as well. You can even schedule the file downloads. You should check it out. It might be worth it for you. I don't have it, myself, but a couple of people on here do, including maratsade. He seems to like it. :)
I'm a big fan of PlayOn Cloud. I just recorded 2 seasons of a show (16 episodes total), all in HD. Set it to record, checked the next day and it was all done (without using my data), then downloaded the episodes (NOT during regular data times, or it would've eaten gigs and gigs), and now I have the files and can watch them and rewatch them whenever. No buffering, excellent picture. The cost for all 16 episodes? $3.20.
- gaines_wright7 years agoTutor
maratsade wrote:I'm a big fan of PlayOn Cloud........
Wow, you guys have finally convinced me! Just in time for the last season of Game of Thrones, and I've got 18 days to learn how to use it.
Please use the app, not the desktop version, as the latter uses data. With the app, I think you get 5 free recording credits, which you may want to use to practice how this works. You need to have accounts with the places you record from. I have accounts with Netflix, Hulu, and Prime. The app will have you login to your account, and then you can set it to record.
