I'm a big fan of PlayOn Cloud. I just recorded 2 seasons of a show (16 episodes total), all in HD. Set it to record, checked the next day and it was all done (without using my data), then downloaded the episodes (NOT during regular data times, or it would've eaten gigs and gigs), and now I have the files and can watch them and rewatch them whenever. No buffering, excellent picture. The cost for all 16 episodes? $3.20.
maratsade wrote:I'm a big fan of PlayOn Cloud........
Wow, you guys have finally convinced me! Just in time for the last season of Game of Thrones, and I've got 18 days to learn how to use it.
Please use the app, not the desktop version, as the latter uses data. With the app, I think you get 5 free recording credits, which you may want to use to practice how this works. You need to have accounts with the places you record from. I have accounts with Netflix, Hulu, and Prime. The app will have you login to your account, and then you can set it to record.
