Good news. Install date was moved up from next Fri to next Wed. Yeaaaaaaaaaaaaaaaaaaaa.
Interested in the Playon.tv thing. So I went to take a look.
Wouldn'tcha know....
This site can’t be reached
www.playon.tv took too long to respond.
I tried a couple of different links, several times. No joy.
(No need to try to fix this, just amusing)
Something seems to be a bit goofy with their site today. I just tried it and couldn't get on, though I had no issue during any previous time going there to research it. I just tried again, and now it worked.
I'd try it a few more times, though maybe wait a few minutes. I don't know if the problem is with their site or if maybe there is an upstream provider issue when trying to access it.
