Is there a trick to getting the app on a Win10 laptop? I can see how to get it for my phones. I must be doing something wrong. Can't find how to authorize my laptop with Google Play.
(I don't use many (if any) apps on Win10) Use em all the time on the phone.
OK, I just got in to the Play On Cloud website. I guess what I need to do is this.....
Once that recording is complete, an .mp4 file will be ready for you to enjoy. You can download the recorded.mp4 video file from the PlayOn Cloud app onto your mobile device. We also email you a download link to the video so you can download it from anywhere onto any device or computer.
That's right. You set up the download (this is where they deduct the recording tokens from your account), and it works behind the scenes, in the cloud. You can just shut down the app and forget about it. It records in real time (it's a DVR-like thing), so a 1 hour show will take 1 hour to record. When the recording is done, you will get an email with a download link. Unless you pay for storage, the recording will only be stored for 7 days. If you lose the link or the email, you can use the app to get the email resent. If the recording is no longer in storage, you have to re-record it.
With the link, you can download to any device. I think to download to devices like iPhone or iPad you don't need the email, you do that from the app -- BirdDog will know more about this. I download from the link in the email to a flash drive.
- 9 months ago
- 2 months ago
