Is there a trick to getting the app on a Win10 laptop? I can see how to get it for my phones. I must be doing something wrong. Can't find how to authorize my laptop with Google Play.
(I don't use many (if any) apps on Win10) Use em all the time on the phone.
the app for the computer is a software package. You need to buy a license for it. But be warned that the desktop version USES YOUR DATA. Only the app version doesn't. The desktop version is also very glitchy.
bos2420 wrote:Is there a trick to getting the app on a Win10 laptop? I can see how to get it for my phones. I must be doing something wrong. Can't find how to authorize my laptop with Google Play.
- BirdDog6 years agoAssistant Professor
- bos24206 years agoJunior
bos2420 wrote:Put that on a USB stick, and plugged that into the back of the smart TV. Worked like a charm.
Does your TV have a special program built in that reads and plays what you have on the flash drive? I have a smart TV, and it has a USB port, as well. I wonder if that would work for me. It would eliminate me having to play the items on my HDMI connected laptop.
I should try to find a .mp4 clip or something somewhere, put it on one of my flash drives, and just give it a try. Now, to find something. :p
- 9 months ago
- 2 months ago
