Help Please – Download Speed < 8 Mbps on Gen5 for WEEKS
Hello everyone,
Since January 26th I have run 15 download speed tests using testmy.net (average = 30.4 Mbps) and 14 using Speedtest by Ookla (average = 15.1 Mbps) and it appears that my download speeds have returned to normal. This is way, way, way up from the 91 testmy.net tests I ran between January 3d and 25, which averaged 8.2 Mbps.
I do find it interesting that testmy.net tests were twice as fast as Speedtest (based on the average) - note tests were performed in pairs, using the same computer and run within 2 minutes of each other. This result appears to be the inverse of what others have reported when comparing testmy.net and Speedtest. Possibliy the servers chosen are responsible for the difference, as testmy.net seems to be using a site in Dallas and Speedtest is using a site in Los Angeles (approx 100 miles north of me).
Anyway all that being said, I am happy that I things are back to normal, at least for this Hughesnet user. I don't know how the correction was implemented, but I appericate the help from those on this forum and any of then unknown "engineers" that have worked on this issue. I will mark this discussion string Corrected and begin a new string, if the problem returns.
To those still chasing speed issues, I wish you luck and suggest you continue working within this forum to resolve your specific issues.
ciao for now - Skip
My speed is even lower than this recently. And continues to get worse :(
I can idendity what you are going through.
Below is a recommendation I provided to another Hughesnet user having similar problems:
"I have found the best way to get positive and informed attention/action is through this forum. You may have already done this, but if not, I suggest that you open a new message string specific to your situation. I know it will be a pain, but give plenty detail (e.g., what system you are using, modem, data plan, computer type, wired or hard wired connection, speed test results, how long you have been trapped with poor performance, AND any Case Numbers you have). Fortunatly, GabeU an Associate Professor on this forum seems to monitor what is going on and he should see your post. He is very thoughtful and has provided me with valuable advice. He is also able to ping forum moderators and get their attention. Hughesnet people like Amanda and Liz also monitor this forum, they are sharp and have always been helpful with my technical issues."
Good luck.
