Hi bronccat,
Any reason I shouldn't try a factory reset on the modem?
I'm driving to town tomorrow to curse tech support over the phone (no apologies here lmao)
bronccat wrote:
I'm still at675kbb $&#*@(
Yes. A factory reset should only be done for specific reasons and only under the instruction of a HughesNet rep. This is for various reasons, the most important of which is that a reset performed improperly or in the wrong instance can cause more harm than good.
The reps will be back on Monday. Hopefully your adapter will be in soon and you can get a few directly connected speed tests in to start getting the help you need from them. Make sure that when you've run the tests you indicate so so that they can start their troubleshooting.
- bronccat5 years agoJuniorThanks. So they don't work weekends? Great!
I leave here Monday morning. I guess I'll call from home and get some ideas. They have got to master email support or something. No way voip is working at these speeds. - bronccat5 years agoJuniorI hope starlink is for real and available soon. I can't even type real time lmao - there's a delay in the characters appearing
No, sorry, they don't work on the weekends. They're on M-F from approximately 9AM to 6PM EST.
With regard to the typing issue, though separate from the current topic at hand, try restarting your device. Problems like this are normally related to the device or something on it, and it can very often be fixed by restarting that device. Only when it's a remote type fill, like with the online free version of Microsoft Word, does it tend to be related to the internet service.
Began ethernet testing, 25mb, wifi off. Results are the same. Plan to test every 2 hours today.
I DM Liz as I am not sure how to get her attention?
They do not respond to unsolicited PMs.
What she is probably waiting for is for you to run the required tests the required way. Right now, the file sizes are incorrect; they need to be 25MB for download tests and 4MB for upload tests.
A rep will reply on this thread, not via PM.
EDIT:
- Your results URL is https://testmy.net/quickstats/Bronccat
- The reps here work M-F, approximately 9-6.
- Don't expect a reply until you have run the tests the right way, as explained here. You may want to focus your efforts on getting the troubleshooting and testing right.
- For immediate responses, there's chat and phone customer service, but you've been through that and it hasn't worked for you, so stay here, run the tests the way they're supposed to, and wait for a response, which may be next week if you've done the required testing as required.
- MrBuster5 years agoSenior
If your tests are being automatically backed down to a size smaller than 25MB, then you may need to check the option for 'No Forward' to keep the test size at 25MB. This is an image GabeU posted a bit back for someone else.
I am not sure if you are using the automatic testing or not, but you want the 25MB size for the download tests.
Right, as stated above I started running the ethernet test and will do se every 2 or 3 hours. 25 mb down (first was at 1130) and 4 Up.
My question is - and not to be a smart**bleep** - but how will she magically know that I have run the tests "correctly" and know I am now worthy of a response?
OK, maybe I'm being a little smart**bleep**ed.
She will know because she will check the URL to your results list. And because she's an all powerful, all seeing entity. Or a magical pixie. HN neither confirms nor denies.
bronccat wrote:My question is - and not to be a smart**bleep** - but how will she magically know that I have run the tests "correctly" and know I am now worthy of a response?
You can use that '@' sign like you did for me to notify folks -- also, she will probably check this thread this thread again on Monday.
I think maratsade just responding about the smaller tests that were recent, so I was not sure if maybe testmy was backing your size down. I think she will have what she wants with a good batch of these tests.
edit: I see maratsade responded before I was done typing....
the OP needs to get the sizes right or the testing may be rejected by the engineers; Liz is just a conduit. Hopefully the OP will get all the moving pieces right. :)
They keep track of the posts and what we talk about -- when the tests have been done, she'll check. :)
bronccat wrote:
maratsade LMAO :heart:
I just meant, what would prompt her to check :smileyvery-happy:
- bronccat5 years agoJuniorWell I ran several tests yesterday as per instructions (25 DL / 4 UL)
Back home now and will call them to discuss. - GabeU5 years agoDistinguished Professor IV
Back home now and will call them to discuss.Why would you call them?
- bronccat5 years agoJuniorOf course, that would be my preference. I didn't know if protocol was to talk to both - or?
I also didn't know how long I should give them to respond here. - bronccat5 years agoJuniorIf I'm on the mountain, this is all I have. I'll be back there first of next week. I had hoped all of this would get resolved on here before I left but with the ethernet connection issue my timing sucked lol
- bronccat5 years agoJuniorYessir! Left it on for this reason.
You rock man, appreciate it! - bronccat5 years agoJuniorA little LOL...
I almost ran a test here (just bc I'm new to "test.my" and realized it would look crazy. I know the location would show but didn't want to muddy the waters ;-) - Liz5 years agoModerator
Good morning bronccat,
Hi bronccat,
