Hi bronccat,
Am I to wait a week to drive down there, update my apps, send screenshots proving I did - then run a speed test on a TOTALLY separate device just to prove that it wasn't the streaming apps? Because that's what is being asked of me.
Hi bronccat,
I've asked our engineers if they can assist in monitoring your site while under normal usage. Please let me know well in advance when you plan to be on site so that engineering can have their monitoring tools set up.
Just go about your business as normal, and document details and timestamps for any issues that arise so that engineering can compare to their analysis.
- bronccat6 years agoJuniorWill do. Can we not try to reset the modem to factory? Seeing at it was working fine whe installed?
If you do that you will be dead in the water until it is re-registered with the help of an authorized tech.
That should only be done as a last resort and while on the phone with said tech.
- bronccat6 years agoJuniorRight. I'm saying after 2 weeks of this and no progress towards a solution or even any ideas that I'm aware of, isn't that a logical step for them take?
Not necessarily.
You're assuming it's a problem with the modem. To me it sounds like something/things local that is/are using the modem. They've already isolated everything between the modem, satellite and internet as being fine, and that's the only logical thing left.
- bronccat6 years agoJuniorThanks Mark - but has to be the modem, IMO - unless Firefox doesn't work correctly with HN and is screwing up the speed tests. But that wouldn't explain every single app / program on every single device struggling with DL speeds.
All the devices being used there are fine elsewhere and were previously fine on that modem. Only thing that could have change to affect wired, wireless and 4 devices - would be the modem / router.
Unless there is some bizarre electromagnetic field that is interfering with wired and wireless transmission speeds. - MarkJFine6 years agoProfessor
Look, I'm not going down that road. There are literally 10 pages of it. Unless you begin to accept that there is something in the way either your devices are configured and/or the way your modem is configured to talk to them, there's no point. What I do know is that wholesale resetting the modem is a bad idea and will make things worse for you.
- bronccat6 years agoJuniorI understand what you're saying and Im not disagreeing with the possibility - I just need someone who as intimate knowledge of these modems to tell me what settings could be affecting both wifi and ethernet, download speeds only - and weren't an issue 3 or 4 weeks ago - across 4 different platforms.
Based.on all those variables, it's a lot more likely that ONE device (the modem) is the culprit.
I've read about the modem resetting dangers, and I won't do it until I'm asked to - but at this point I just want any kind of movement besides them continuing to test and tell me everything is ok on their end. - Liz6 years agoModerator
Good morning bronccat,
No factory resetting the modem unless suggested by our engineers here at corporate. Just let me know when you plan to be on site next so I can give the engineers a heads up. Thanks!
I will let you know. Hopefully on Wednesday. Will they be able to communicate with me via email or text (VOIP Text)?
Thank you, I will tell them to prep for Wednesday. They will be monitoring your site, no need for any communication. Should anything change, please let me know.
- bronccat6 years agoJuniorI would think that actual communication is warranted at this point.
I desperately reached out yesterday via chat (from elsewhere) and was told that "I was informed to inform you that the issue has been sent to the corporate office and that the will be notifying you from their office".
That's was literally what was sent - right before I asked for a transcript twice and was told "Do to security concerns we do not email out information"
Again verbatim.
Also was told on FB messenger that this would be addressed and haven't heard a peep since last week. Nor have my messages been read.
Please put me in direct contact with someone who can address this. - Liz6 years agoModerator
Hi bronccat,
- 11 months ago
- 11 months ago
