Apparently, this happens with any 'Old Timey' website. :smileyvery-happy:
Just tried to look at a link on Yahoo. Same error message. Figured it was just the link. Tried to go to Yahoo.com. Nope.
Went to the phone hotspot. Loads right up.
bos2420 wrote:Apparently, this happens with any 'Old Timey' website. :smileyvery-happy:
Ah, the plot thickens! Here's what I get running traceroute to aol.com:
traceroute to aol.com (106.10.218.150), 30 hops max, 60 byte packets
1 192.168.42.1 (192.168.42.1) 0.278 ms 0.249 ms 0.231 ms
2 100.67.205.153 (100.67.205.153) 0.470 ms 0.523 ms 0.610 ms
3 dpc6935186182.direcpc.com (69.35.186.182) 627.393 ms 687.188 ms 687.168 ms
4 dpc6935188058.direcpc.com (69.35.188.58) 687.121 ms 707.026 ms 707.022 ms
5 ae13-575.edge3.Denver1.Level3.net (4.28.103.141) 706.975 ms 725.744 ms 725.895 ms
6 * * *
7 PCCW-level3-30G.Dallas1.Level3.net (4.68.110.246) 791.410 ms 791.437 ms 791.389 ms
8 TenGE0-1-0-17.br02.hkg12.pccwbtn.net (63.218.174.61) 981.199 ms 786.976 ms 766.663 ms
9 63-216-176-170.static.pccwglobal.net (63.216.176.170) 756.616 ms 766.603 ms 744.669 ms
10 et-3-3-0.pat1.sgy.yahoo.com (183.177.82.40) 764.490 ms 774.403 ms 838.837 ms
11 ae-5.msr1.sg3.yahoo.com (203.84.209.87) 838.634 ms 789.498 ms 789.302 ms
12 ae-2.clr2-a-gdc.sg3.yahoo.com (106.10.128.5) 789.140 ms ae-2.clr1-a-gdc.sg3.yahoo.com (106.10.128.3) 879.374 ms 779.340 ms
13 lo0.fab1-3-gdc.sg3.yahoo.com (106.10.131.217) 865.655 ms lo0.fab2-3-gdc.sg3.yahoo.com (106.10.131.216) 855.578 ms lo0.fab4-3-gdc.sg3.yahoo.com (106.10.131.214) 889.348 ms
14 lo0.usw2-1-lba.sg3.yahoo.com (106.10.128.239) 889.240 ms lo0.usw1-1-lba.sg3.yahoo.com (106.10.128.238) 869.501 ms lo0.usw2-1-lba.sg3.yahoo.com (106.10.128.239) 859.566 ms
15 w2.src4.vip.sg3.yahoo.com (106.10.218.150) 779.505 ms 779.419 ms 789.324 ms
As you can see, yahoo.com shows up several times. Like I said before I'm not sure about what all of this means, but it looks like yahoo.com is on the way to aol.com. Or maybe I should say it's in the way. :>)>
I doubt the modem is your problem. I think the problem is past the Hughes gateway. I'm surprised you haven't heard from a mod about this yet. Like I said, I've seen problems that were similar before.
BTW if you upgrade to gen5, make sure you don't plug the modem in to your system until the bonus period, otherwise you'll take a big hit to your anytime data just for the modem to initialize.
Yahoo, AOL... I think it's all Verizon under the Oath: logo, aka Verizon Media.
- gaines_wright7 years agoTutor
MarkJFine wrote:Yahoo, AOL... I think it's all Verizon under the Oath: logo, aka Verizon Media.
Well, that explains everything! This is all an evil plot by Verizon to sabotage a competitor. :>)>
gaines_wright wrote:BTW if you upgrade to gen5, make sure you don't plug the modem in to your system until the bonus period, otherwise you'll take a big hit to your anytime data just for the modem to initialize.
To prevent any confusion to the OP or anyone else who reads through this thread, the above statement is incorrect. Neither data required for modem activation and initialization, nor that required for a modem software update/upgrade, is deducted from customer data.
Specifically regarding the OP, an upgrade to Gen5 would almost assuredly require a tech visit, at which time the tech would power the new modem to start the activation and initialization process. As well, the OP would receive the initial twenty days of data replenishment that new customers, and those upgrading from legacy plans to Gen5, are given, so even in the event that there was some type of system glitch and the above mentioned data was incorrectly drawn from the OP's data bank, it wouldn't matter.
"To prevent any confusion to the OP or anyone else who reads through this thread, the above statement is incorrect. Neither data required for modem activation and initialization, nor that required for a modem software update/upgrade, is deducted from customer data."
Well, it was definitely correct in my case. I remember because it was the first time I had run out of data since the daily limit days. A friend of mine had the exact same thing happen to him when he upgraded. This was some time ago, things may have changed since then.
"Specifically regarding the OP, an upgrade to Gen5 would almost assuredly require a tech visit, at which time the tech would power the new modem to start the activation and initialization process."
Neither I, nor my friend had a tech do anything We both talked to Hughes on the phone and they sent us new HT2000 modems, and told us to just plug them in to our systems. Unfortunately we both did this during the anytime data period and took a big anytime data hit.
"As well, the OP would receive the initial twenty days of data replenishment that new customers, and those upgrading from legacy plans to Gen5, are given, so even in the event that there was some type of system glitch and the above mentioned data was incorrectly drawn from the OP's data bank, it wouldn't matter."
Again none of that happened with me or my friend. Seems like I remember having this same discussion with you some time ago. If I remember correctly, none of the above applies to a gen4 to gen5 upgrade. I guess gen4 doesn't qualify as a legacy system. "Legacy system" is that kind of like "no hard data limits"? :>)>
Since he's running a HN9000, I guess that would be a gen3 system, and he would probably get the data break also. Seems strange to me that it actually pays to wait 2 generations before updating your Hughes system.
To prevent any confusion to anyone else who reads through this thread, ( Sorry GabeU, I couldn't resist! :>)> ) if you're just going from gen4 to gen5, and are only doing a modem upgrade, I would still advise doing the upgrade during the bonus period. It certainly wouldn't hurt anything to do so and it might save you a big anytime data hit.
BTW what the heck is an OP? Other person?- maratsade7 years agoDistinguished Professor IV
OP = original poster (also original post)
