Hi bronccat,
The HughesNet reps on this site will be back on Monday, and to address your speed issues, they require that you follow a specific troubleshooting procedure, which is detailed here: https://community.hughesnet.com/t5/Tech-Support/Think-you-have-slow-speeds/m-p/110034#M74607
Best way is to have 3 tests run 3 times a day (3 in the morning, 3 in the afternoon, 3 in the evening). Tests need to spaced out a bit, and they need to be specific file sizes. Everything is explained in the link I posted above.
Do you still have data? Speeds will tank when you run out.
Good luck; I hope the issue gets resolved soon for you.
- bronccat6 years agoJuniorThanks. Yes, still have full allotment for month (new customer).
I was testing via testmy on 5 ghz band with nothing else online. Will do with laptop and ethernet and space out tests accordingly.
I know I won't get best results via wifi, but .4 MBPS is pretty dire no matter lol
Thanks!- maratsade6 years agoDistinguished Professor IV
That's pretty bad speed, definitely. When you experience these slow speeds, what's the state code? (the state code can be found here: http://192.168.0.1/#!/home/status).
Also, what's your browsing experience when you measure those speeds? Was slow browsing what led you to run speed tests?
- bronccat6 years agoJuniorLooking for state code. Nothing would load on firestick (like Huku Home, NF, etc) and slow browsing.
