Solved! Go to Solution.
David,
Remy
Weather issues at the gateway can affect your signal too. If there's a problem at the gateway, it's usually temporary. The mods here can probably check your system remotely and see what's going on. Give them some time to respond.
Best to let the mods check to see whether there's an issue at your location or something going on at the ground station. They usually respond within a day or two, but if you're in a hurry, you can always call the customer service number (24/7) or use the chat.
David_78933 wrote:
Thanks. I should have mentioned that there is no weather in Wyoming at the gateway, either.
I've been having this same exact issue starting tonight. I have an older Gen 4 system and I've been suspecting that age is catching up to it. The weather here is fine, clear, sunny, and hot. Best I can figure the gateway is in Montana, the weather is clear there as well. I did some research and people with similar problems have had radio issues. So I called and upgraded to Gen 5 hoping that it upgraded the transmitter as well. Turns out that it doesn't.
I called a tech who had me reboot the system. Of course, it cleared the error state (I had done this before), and seeing that the board was green he didn't see a need to do anything else. So in frustration I just went with the upgrade. It needed to be done anyway, but somehow, I seriously suspect the radio is succumbing to heat/moisture.
Of course, within a half hour it glitched again.
Any help is appreciated. It could be something temporary on Hughesnet's end. I've noticed that recently I've had more glitching, I've just now started watching it more closely.
Don, you will need to start your own topic under Tech Support. Go to the Tech Support page, click on the "start a topic" button and post your issue (you can copy and paste from here). The mods address tickets separately, and it's very likely your post here will go unanswered by them unless it's under its own ticket. The mods are here M-F during business hours.
don_Ell wrote:I've been having this same exact issue starting tonight. I have an older Gen 4 system and I've been suspecting that age is catching up to it. The weather here is fine, clear, sunny, and hot. Best I can figure the gateway is in Montana, the weather is clear there as well. I did some research and people with similar problems have had radio issues. So I called and upgraded to Gen 5 hoping that it upgraded the transmitter as well. Turns out that it doesn't.
They're probably fine. The problem may be at your gateway or it may be issues with your beam. What beam are you on?
David_78933 wrote:
My modem and radio were both replaced two years ago. I would hope those major components would last more than two years, but...? It's definitely hot here in Texas this week, but it gets this hot every summer.
MIS - Missoula, Montana
